Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Sun Jul 18, 2004 11:43 am Post subject: e-brake cable |
Say you got a '67 bus with a '62 small nut trans in it . Which e-brake cable would you use????? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Sun Jul 18, 2004 11:57 am Post subject: |
early cable _________________ -Bryan
Motorwagen LLC
Concord NC |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sun Jul 18, 2004 5:59 pm Post subject: |
Then do you use a later cable when installing a bignut transaxle into a 59? |
Posted: Sun Jul 18, 2004 6:34 pm Post subject: |
singlesquared wrote: |
early cable |
Thanks Bryan. Thats what Taylor K. told me but I figured I would make sure. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
ToolBox Samba Member
Joined: January 27, 2004 Posts: 3439 Location: Detroit, where they don't jack parts off my ride in the parking lot of the 7-11
Posted: Sun Jul 18, 2004 7:16 pm Post subject: |
TimGud wrote: |
Depends. Is it an early 59 or later?
If it is a late 59 it will work without modification. Yuo need to shorten the cables if it is an early 59. |
BryanM Samba Member
Posted: Sun Jul 18, 2004 7:47 pm Post subject: |
the PO PO of my 62 installed a big nut tranny. when I took the rear drums off the OG cables were there and teh PoPo had taken wire and extended the cable all half asses. _________________ -Bryan
Motorwagen LLC
Concord NC |
TimGud Samba Member
Posted: Sun Jul 18, 2004 8:28 pm Post subject: |
ToolBox wrote: |
TimGud wrote: |
It's an early 59 with the shifter closer to the seat. |
Posted: Mon Jul 19, 2004 10:25 am Post subject: |
TimGud wrote: |
ToolBox wrote: |
TimGud wrote: |
I forget how much you need to shorten the cables, I got new ends and had them swedged on at a sailboat rigging shop. |
TimGud Samba Member
Posted: Mon Jul 19, 2004 7:47 pm Post subject: |
ToolBox wrote: |
TimGud wrote: |
ToolBox wrote: |
TimGud wrote: |
Where did you locate the new ends? |
23window Samba Member
Posted: Mon Jul 19, 2004 8:03 pm Post subject: |
one percenter wrote: |
early cable |
Thanks Bryan. Thats what Taylor K. told me but I figured I would make sure. |
you questioned me? |
Posted: Tue Jul 20, 2004 8:30 am Post subject: |
TimGud wrote: |
ToolBox wrote: |
TimGud wrote: |
ToolBox wrote: |
TimGud wrote: |
The boat rigging shop had them in stock. They are not "correct" but fit. |
splitpile Samba's Worst Speller
Joined: May 03, 2000 Posts: 5927 Location: back to living where hell meets the suface
Posted: Tue Jul 20, 2004 8:35 am Post subject: |
TimGud wrote: |
On my DD (early 60) I used the later cable (64 and later) with the big nut. It is way to long so I cut it off, got some dune buggy clutch cable shorteners and put those on. I fill the hole with JB weld before slipping over the cable abd tightened the set screw. 63,000 plus miles and it still held fine. When I lowerd the bus with the straight axle kit, the cables became to short and had to do the whole process over again.
I have had to do this to all my buses being I have converted them all to big nut trannys from small nut _________________ Stocking distributor of "The Funky Green Panels"
"no more hacking my sig line" |
SHSC Samba Member
Joined: February 02, 2001 Posts: 1785 Location: Oklahoma City
Posted: Tue Jul 20, 2004 8:43 am Post subject: Re: e-brake cable |
Say you got a '67 bus with a '62 small nut trans in it :x . Which e-brake cable would you use????? |
But why would you put that tranny in a 67? _________________ DKB |
Posted: Tue Jul 20, 2004 9:50 am Post subject: |
23window wrote: |
early cable |
I've seen that hodge podge you call a 23window. All slapped together with vanagon parts and such. Just kidding, just kidding. You know the respect I have for your knowledge. I was just acting like a Catholic school girl and wanted to get confirmation. (rim shot ) thank you I will be here all week.
Sorry about that hole vanagon parts jibba jabba too. I know better than that. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Tue Jul 20, 2004 9:59 am Post subject: Re: e-brake cable |
SHSC wrote: |
Say you got a '67 bus with a '62 small nut trans in it . Which e-brake cable would you use????? |
But why would you put that tranny in a 67? |
Excellent question my good man. One I ask myself every time I see the bus. The PO or PPO did it for God knows what reason. Its not my bus but rather a friend of mines who I am helping to get it running. We have had no luck coming up with a working 12V big nut, or any big nut for that matter, in the yards around here. It doesnt help that he aint rich. I tried to tell him this wasnt a poor mans hobby when he wanted in but he was determined. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
TimGud Samba Member
Posted: Tue Jul 20, 2004 6:11 pm Post subject: |
splitpile wrote: |
TimGud wrote: |
I have had to do this to all my buses being I have converted them all to big nut trannys from small nut |
That's a good simple fix that sounds like it will hold up. Thanks. |
