Windisch Samba Member
Joined: October 30, 2014 Posts: 403 Location: Sacramento, CA 95822
Posted: Fri May 24, 2024 7:33 am Post subject: 914-4 engine main bearings wear? |
When I acquired my carb-converted car, there was pretty extensive water contamination/dilution of the engine oil (so much so that the oil had a uniform 'mocha white' coloration to it), probably caused by water entrainment due to someone unknowingly cleaning the engine bay with a pressure sprayer.
I changed out the engine oil and filter ASAP and although the oil pressure appears to be good and there aren't any apparent oil leaks anywhere (other than the usual small seeps that air-cooled VW type engines typically have), there is a strange sort of noise that can best be described as a 'low rumble/grinding' sound that seems to come from the engine. The noise is of somewhat low intensity and slightly variable in noticeability while the engine is operating but the thought occurs to me that perhaps the main bearings suffered some abnormal wear from being run with the H20-contaminated oil.
I'd appreciate inputs and opinions on this from other experienced 914 people. Further, are there any effective means of determining whether or not there is any main bearing damage other than a tear-down? Is this possibility capable of being ruled out by a competent Porsche shop?
Additionally, are there any oil additives that would help ameliorate any possible existing excessive wear, proactively? I am presently using full-synthetic oil but I have been advised to switch to an oil that has ZDDP additives (ZINC-DIALKYL-DITHIOPHOSPHATE), since apparently flat-tappet engines (such as the Type-4) benefit from use that type of oil.
Thanks! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Der Volkswagen ist ein Ausdruck der deutschen Kultur der Allrad Art ...
[The only irrefutable evidence we have that intelligent life truly exists elsewhere in the Universe is the fact that so far it has NOT contacted humanity...] |
Wolfgangdieter Samba Member
Joined: June 25, 2008 Posts: 1990 Location: FL Panhandle
Posted: Fri May 24, 2024 10:32 am Post subject: Re: 914-4 engine main bearings wear? |
My go-to oil for VW/Porsche air-cooled engines is Valvoline VR2 Racing Oil. It has a high zinc and phosphorus formula. It is readily available and not expensive. I don't use synthetic oil in air cooled engines - it seems to leak more than old dino oil. _________________ CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 22941 Location: Oklahoma City
Posted: Fri May 24, 2024 10:44 am Post subject: Re: 914-4 engine main bearings wear? |
Windisch wrote: |
Thanks! |
Record the sound and post it.
As for the oil, yes, it should have THE RIGHT AMOUNT of ZDDP.
I posted a link to this a couple of weeks ago. Lake speed Jr is the bomb on oil technologvy. Great video that explains why not enough ZDDP is bad and also why excessive ZDDP is just as bad or worse.
https://www.thesamba.com/vw/forum/viewtopic.php?t=791567
On the oil....there are numerous good oils for flat tappet cams. The Valvoline VR-1 racing is a great oil for ACVW.
In the synthetic range...start here on the Mobil-1 site. The question at the top of the page was asked about using their synthetic oils and mixing with a bit of racing oil to tune the content.
https://www.mobil.com/en/lubricants/for-personal-v...or%20oils.
On an engine that is long past break in, you an probably get away with the 0W-40 as it has 1000ppm ZDDP.
Ray |
Posted: Fri May 24, 2024 2:14 pm Post subject: Re: 914-4 engine main bearings wear? |
[/quote]
Ray[/quote]
Thanks for that, Ray. I'll try to capture the sound and post, as you suggest. May take me a few days to do so, however. I recently began using CASTROL EDGE EUROCAR full synthetic 5w40 oil in my 914-4 engine and I've sent off an inquiry to CASTROL about ZDDP, but have not heard from them in reply just yet. [I am told that VALVOLINE RACING OIL and the STP additive are both good bets for ZDDP protection but that it's probably a good idea to switch back to mineral-based oil with ZDDP in it, from what all the indicators seem to suggest. _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Fri May 24, 2024 6:26 pm Post subject: Re: 914-4 engine main bearings wear? |
If you have not watched that link in My last post you should.
One of the problems with Ester based synthetic oils that seem to be close to having enough zinc and phosphorous....is that they typically have too much detergent which fights the zddp and causes issues with OUR applications so you have to choose carefully. Ray |
Posted: Fri May 24, 2024 6:58 pm Post subject: Re: 914-4 engine main bearings wear? |
Hi Ray. Yes, as regards the deleterious effect of detergents on zinc/phosphate efficacy, that certainly seems to be true (I did watch that video you mentioned and it is excellent). I've been looking into all this a bit over the past several hours and of the best oils generally recommended for flat-tappet, older engines, VALVOLINE VR-1 Racing Oil seem to be at the top of the heap with a ZDDP rating of about 1300 ppm. Second best appears to be LUCAS Hot Rod Oil for older racing machines, although it has ZDDP ratings of closer to 1800-2000, which may be too much (apparently due to a tendency for too-high Zinc/Phosphate levels to suffer problems such as undesired viscosity increases and oil-channel clogging due to detergent interactions, etc.).
Word has it that most full-synthetic oils now have a ZZDP rating of around 800 ppm, but a natural mineral oil base with about 1200 ppm (ZDDP) or so (10w30) would appear to be the better choice for an older street machine.
Still haven't found out what the Zinc/Phosphate additive rating of the CASTROL EDGE EUROCAR oil I currently use in my car is but I would expect when I hear back from Castrol, it will likely turn out to be in that 800 ppm range just like most of the other modern synth. oils.
Most interesting information, Ray, and I must admit that heretofore I was completely ignorant of the critical nature of and need for Zinc/Phosphate additives in older engine motor oils. Just goes to show me that despite all our (my) knowledge ("shade-tree" in my case), there's still a vast amount of often crucial awareness that remains hidden beyond our (my) personal experiential horizons! Thanks for opening that particular chapter for me in 'The Care & Feeding of Older Vintage Air-sucker Engines.'! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Sat May 25, 2024 7:38 pm Post subject: Re: 914-4 engine main bearings wear? |
Windisch wrote: |
Most interesting information, Ray, and I must admit that heretofore I was completely ignorant of the critical nature of and need for Zinc/Phosphate additives in older engine motor oils. Just goes to show me that despite all our (my) knowledge ("shade-tree" in my case), there's still a vast amount of often crucial awareness that remains hidden beyond our (my) personal experiential horizons! Thanks for opening that particular chapter for me in 'The Care & Feeding of Older Vintage Air-sucker Engines.'! |
I believe at some point....Lake Speed has recommended some oils for us air cooled people. I will look around.
I REALLY want to run synthetic in type 4. The friction is so much lower....as long as it can be formulated to not cause other issues. Ray |
Posted: Sun May 26, 2024 8:01 am Post subject: Re: 914-4 engine main bearings wear? |
Yeah, Ray, I'd be interested in hearing about anything you discover in that regard. Even if my engine's main bearings DO have a bit of premature wear (due to that H20-in-oil matter I went into earlier in this thread and others), I'm hoping that use of the perfectly suited oil for my 914 may help to ameliorate and overcome any possible adverse possibilities. Have a memorable Memorial Day! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Mon May 27, 2024 7:58 am Post subject: Re: 914-4 engine main bearings wear? |
I use CASTROL EDGE (Eurocar) full-synthetic oil in my 914's engine, so I sent oiff an inquiry requesting more specific information on that oil's ZZDP (zinc/phos) content to CASTROL's HQ. Below is their reply:
Thank you for contacting Castrol North America.
Classic cars with flat tappet cam engines represent a special case in regard to engine oil lubrication. These engines have valve train configurations that require elevated levels of ZDDP (zinc dialkyl dithiophosphate) anti-wear for proper protection of the flat tappet camshaft and its lifters. Insufficient concentration of ZDDP will lead to premature wear and failure of the camshaft and lifters. Current ILSAC GF-5 and GF-6 fuel economy grade engine oils are designed for the extended life of the catalytic converters in modern passenger cars and have industry-mandated limitations on the amount of sulfur and phosphorus within the oil.
Castrol EDGE Euro 5W-40 A3/B4 contains a typical Zinc level of 1000 ppm and a typical Phosphorus level of 900 ppm.
The following Castrol oils are blended with a high zinc and phosphorus content to help prevent premature aging, wear, and metal fatigue on engines with high-tension valve springs or performance modifications that create high contact pressure and extreme internal temperatures:
• Castrol GTX Classic 20W-50 (Conventional Oil Formula)
Features/Benefits:
Zinc (1400 ppm)
Specially formulated to provide unsurpassed wear protection for classic and collector cars, as well as racing applications
Compatible with gasoline and alcohol-based fuels
• Castrol EDGE 5W-50 (Full Synthetic Oil Formula)
Features/Benefits:
Zinc (1250 ppm)
Excellent cold temperature properties
High-temperature viscosity (SAE 50) is suitable for use in many classic car applications
Castrol always recommends following the guidelines of the engine manufacturer for the recommended oil (i.e., SAE grade, API rating, and manufacturer specifications) specific to your application. Please consult your mechanic/engine rebuilder regarding the suitability of the 20W-50 or 5W-50 viscosity grade in your engine.
Thank you again for contacting Castrol; we value your patronage!
Castrol Customer Relations
1-888-CASTROL (1-888-227-8765)
Hours of Operation: Mon – Fri: 9 am - 7 pm ET
Looks as if CASTROL EDGE has just about the perfect levels of ZZDP in it for our older, flat-tappet engines! _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Mon May 27, 2024 12:20 pm Post subject: Re: 914-4 engine main bearings wear? |
Windisch wrote: |
Features/Benefits:
Zinc (1400 ppm)
Features/Benefits:
Zinc (1250 ppm)
Looks as if CASTROL EDGE has just about the perfect levels of ZZDP in it for our older, flat-tappet engines! |
Interesting! The problem is that the 50W viscosity is a bit to high for average driving with our oil cooler bypass system. There is vrtually no reason on a stockish type 4 engine that we should be using 50W.
I am going to see what websites Lake Speed has. With all of the questions he has been asked, I am sure that he has somehwere made recommendations for air cooled VW.
The other issue is not just ZDDP...but how much calcium...which is a detergent and ends of screwing up the zddp.
Also, keep in mind that Lake Speed started out with the "Joe Gibbs" brand of oils which became Driven oils.
Here is a link to their site with recommendations for air cooled VW engine oils:
https://drivenracingoil.com/c-1389364-shop-by-appl...e-oil.html
Their GP-1 oils are synthetic blends. Their DT-50 series are full synthetic.
They have a 10W-40, a 10W-30 and a 15W-40 synthetic blend all made for flat tappets and have ~1200 ppm ZDDP.
The Driven and Joe Gibbs break in oils are pretty much the best out there. This is the stuff Jake Raby was using and is also what the type 4 store sells.
https://lnengineering.com/products/driven-racing-oils.html
Ray |
Posted: Mon May 27, 2024 4:15 pm Post subject: Re: 914-4 engine main bearings wear? |
Copy all that, Ray, and thanks. I'll do a bit of reading-up on those sources. _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Thu May 30, 2024 8:27 am Post subject: Re: 914-4 engine main bearings wear? |
By the way, I recently contacted a local area engine modifier & rebuilder of some repute (Bryan, at Late Night Air Cooled VW, in Chico, CA) with a question about what sort of oil he recommends to his VW clients. His response was that he prefers synthetic of the 20w50 grade, not 10w30, for his engines. Of course Chico (CA) is situated in a very hot part of the Sacramento Great Valley, so high-quality synthetic (with the right Zinc/Phos. composition) of that weight would seem to be better suited to summer's often 105+ ambient temps there.
The range of air-temps encountered in the particular area one lives in would, to the perfectionist, have some significant bearing upon matters such as what oil would be preferable to use in one's VW/Porsche AC-engined car, of course. Just sayin'... _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Joined: December 28, 2016 Posts: 308 Location: atlanta ga
Posted: Thu May 30, 2024 12:13 pm Post subject: Re: 914-4 engine main bearings wear? |
you could raise the idle to 2500 rpm then pull one plug wire at a time and see which cylinder lessens the noise. Could be anything even a valve out of adjustment, a loose guide, an exhaust leak, but at least this way you could localize it |
Posted: Thu May 30, 2024 1:21 pm Post subject: Re: 914-4 engine main bearings wear? |
[email protected] wrote: |
Useful advice, George. Thank you. I'm dying to learn exactly what's going on with that 'intermittent grinding rumbly' noise...whether it's an engine problem OR a transaxle source. Strangely, when the engine is idling, after a run (or stopped briefly at a stoplight), is when it's most noticeable. That original episode finding the grossly contaminated oil ("oil milkshake") jn the sump when I got the car is what's pushing me to suspect main engine bearing wear, but it could be anything, of course...even a tranny out of whack, some way or another. I'll try the selective engine spark plug wire pull and see what my observations are, at any rate.
By the way, referring to a separate thread I left earlier today on potential 914 'automatic activation' fire suppression systems (as long as you're on the SAMBA forum today), any thoughts on that to share with us? I'm sure you've come across numerous stories and accounts of 914 engine fires in your vast experience with the type! Although I now have carbs instead of a FI system, the thought of a fire in my car is always at the fringe of my awareness. The 'other' VW air-cooled vehicle of mine (my '73 VW Bug) had an engine fire some time before I got the car...there's still vestigial evidence of it on the engine lid grill louvers (although the car has since had a completely new powerplant installed and otherwise bears no further scars of that event). _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
Posted: Thu May 30, 2024 6:00 pm Post subject: Re: 914-4 engine main bearings wear? |
Windisch wrote: |
The range of air-temps encountered in the particular area one lives in would, to the perfectionist, have some significant bearing upon matters such as what oil would be preferable to use in one's VW/Porsche AC-engined car, of course. Just sayin'... |
Far too many people have had bad luck with 20/50 in a type 4. It produces too high of a pressure even in 70 degree weather.....if your engine is in great shape with a tight pu.p and bearing fit. This causes oil bypass and hot running.
Nothing in Cali short of Death Valley is any hotter than central and West Texas and Oklahoma in the summers. Even in this climate....20/50 is rarely needed.
Also ask if he builds type 4....or just type 1 and 3. It makes a difference.
I do not use 30 weight in the summers bit it works well. I typically use 40 weight in most type 4.
Ray |
Posted: Thu May 30, 2024 6:26 pm Post subject: Re: 914-4 engine main bearings wear? |
Bryan at Midnight Air-Cooled in Chico (CA) principally rebuilds and and modifies Type-1 engines. Uncertain about Type-2s but I rather suspect he does those. Without actual word from him on Type-4s, I am reasonably certain he doesn't normally work on Type-4s, though. [Not sure about Type-3s.]
I admit I was surprised to hear of his recommendation for 20w50 myself! I would have instinctively grabbed 10w40. Speaking of engine heating effects, my 914 engine had the so-called Type-4 'Cooling flaps' removed from the rebuild, something that was apparently popular back in the late 80s period. I intend to have a set (and governing thermostat) reinstalled on my engine at the earliest afforded opportunity. _________________ 1973 Standard Beetle, 1974 VW/Porsche 914-4, 1.8 liter
