Fastback Attitude?
Max Welton
Max Welton is offline
PostPosted: Tue Jun 25, 2024 2:26 pm    Post subject: Fastback Attitude? Reply with quote
Using a level, I find that the door-sill on my fastback is perfectly level. Does that sound right?
Max
1967 Type-3 Fastback
Bobnotch
Bobnotch is offline
PostPosted: Tue Jun 25, 2024 3:22 pm    Post subject: Re: Fastback Attitude? Reply with quote
Max
Use your level and compare it with the tunnel. If both are the same, and it should be level.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Max Welton
PostPosted: Tue Jun 25, 2024 4:16 pm    Post subject: Re: Fastback Attitude? Reply with quote
They are the same Bob. I guess my question is: is level about right for stock?
Max
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Jun 25, 2024 4:23 pm    Post subject: Re: Fastback Attitude? Reply with quote
Yes, level is the stock attitude, assuming the gas tank is full and the frunk is about half full of crap. Laughing
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Max Welton
PostPosted: Tue Jun 25, 2024 6:07 pm    Post subject: Re: Fastback Attitude? Reply with quote
Thanks! I really didn't want to adjust the rear ride height again. Wink
Max
Bryan67
Bryan67 is offline
PostPosted: Tue Jun 25, 2024 8:20 pm    Post subject: Re: Fastback Attitude? Reply with quote
Assuming the ground its on is level too
If you`re going to do something, do it right.
Bobnotch
Bobnotch is offline
PostPosted: Wed Jun 26, 2024 5:48 am    Post subject: Re: Fastback Attitude? Reply with quote
Yup, I think it's called out in the Bentley manual that way. Level ground, and level tunnel. They call it out that way to make sure ALL suspension adjustments are done for a starting point.
Same applies with KTPhil's comment about the fuel level. Not sure about the half frunk full of crap, but I think they also add 150 pounds on the drivers side floor to simulate a driver.
Tram wrote:
Tram wrote:
