Orangebug65sunroof Samba Member
Posted: Sat Aug 03, 2024 4:37 pm Post subject: Cip1 valve gaskets |
Seriously CIP1!
What is up?
Response from customer service when ordered gaskets all buckled due to them being oversized...I guess
" I have spoken with my engine tech and he told me that all the gaskets tend to do that. You can apply a small amount of rtv adhesive to hold the gasket in place, let it dry and then install."
Pair from local auto parts store.
Some things I just don't get like why my valve covers keep leaking! |
Joey Samba Member
Joined: August 12, 2005 Posts: 5374 Location: Nova Scotia - Canada
Posted: Sat Aug 03, 2024 6:09 pm Post subject: Re: Cip1 valve gaskets |
I bought a 10 pack of Elring brand valve cover gaskets from CIP1 a few years ago and they too were oversized and buckled like yours. Their response to my complaint was also “use glue or RTV”. However, I just bought a 25 pack of Elring valve cover gaskets from them last week and they fit perfectly. _________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3104 Location: Memphis
Posted: Sat Aug 03, 2024 10:01 pm Post subject: Re: Cip1 valve gaskets |
I've always used the elring valve cover gaskets and they tend to do that just a bit. There's kind of a magic science to putting on valve cover gaskets from what I've gathered!! The pair I just put on this week were Elring; I used Hylomar universal blue to make them tacky enough to stay put on the valve cover. _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
OldSchoolVW's Samba Member
Posted: Sun Aug 04, 2024 5:53 pm Post subject: Re: Cip1 valve gaskets |
Or ... just get the reusable silicone gaskets. My experience has been that they fit well, seal well and save time (no cleaning, scraping, prepping with sealer ... just install them dry). Yes, yes ... they are quite a bit more expensive than the cork and neoprene gaskets, but they can be used over and over and over again. Just another option to consider. _________________ Tom
"Following distance is proportional to IQ."
"If you don't do it this year, you will be one year older when you do." Warren Miller
'63 Beetle Sedan
'69 Beetle Sunroof
'70 Beetle Sedan
'73 Type 3 Fastback |
wcfvw69 Samba Purist
Posted: Sun Aug 04, 2024 8:17 pm Post subject: Re: Cip1 valve gaskets |
I've bought nice fitting top brand valve cover gaskets that fit well over the years. I had never glued them to the valve covers over the past 40 years. I then had one move up while driving down the freeway causing a decent leak despite the bails being tight.
Now? I just glue them to the valve covers as insurance that that doesn't happen again. A few extra minutes to glue them in or to remove the old gasket and re-glue in a new one is worth it to me. _________________ Contact me at [email protected]
The Samba member since 2004.
richparker Samba Member
Joined: November 24, 2011 Posts: 7158 Location: Durango, CO
Posted: Sun Aug 04, 2024 9:22 pm Post subject: Re: Cip1 valve gaskets |
I’ve been using the VS 26062 C Blue Striped FelPro gaskets, as posted above. They have been working just fine for me. I get them from my local Autozone for $8/pair. I use Permatex Aviation to adhere them to the covers. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
PWB Samba Member
Posted: Mon Aug 05, 2024 7:49 am Post subject: Re: Cip1 valve gaskets |
Just curious, are your valve covers original vw stamped?
When I bought my car, a previous owner had replaced only one of the valve covers with an aftermarket reproduction. Gasket set fit fine on the genuine VW side, and buckled same as yours on the aftermarket.
Issue may be with the covers, and not the gaskets. Just a thought.
That being said, it looks like there are gaskets being made which fit better with aftermarket covers, which I was unaware of. |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 926 Location: Lanark County, Ontario, Canada
Posted: Mon Aug 05, 2024 11:53 am Post subject: Re: Cip1 valve gaskets |
Poor storage will render cork gaskets misshapen or crumbly dry and useless. The cork gaskets should be glued in to prevent gasket creep. Some genuine VW valve covers have a short raised ridge inside to prevent gasket sag at the top center, a desirable feature.
The silicone gaskets seemed like a great idea but are more slippery and can also shift and leak. BTDT, had a mess. Too slippery to glue. A better solution would be a reusable silicone gasket with an embedded thin metal reinforcement to maintain the shape and prevent gasket creep. But if that existed, would people pony up for it? _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
kvasilak Samba Member
Joined: February 28, 2024 Posts: 39 Location: Minnrsota
Posted: Mon Aug 05, 2024 2:19 pm Post subject: Re: Cip1 valve gaskets |
I bought a set of silicone gaskets, I don't remember where from. And the swelled so bad oil was dripping all over of the maybe second drive.
Replaced with a pair of neoprene from jbugs and so far so good, only a few drives but a lot more hours!
I'm not a fan of cork, they should be glued and sealed, then replaced every time |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3593 Location: San Diego
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10187 Location: Oregon
Posted: Mon Aug 05, 2024 4:59 pm Post subject: Re: Cip1 valve gaskets |
Awsome! Thanks for posting that link.
When ACN closed operations down. I thought that was the end of the supply chain for those metal/cork sandwich valve cover gaskets. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Posted: Tue Aug 06, 2024 4:53 pm Post subject: Re: Cip1 valve gaskets |
Thanks for the link. Checking on international shipping.
Still leaking out the bottom. Based on the indentation I’m guessing the bung is not tight enough….
