Doorskin replacement issues
NEPAbeetle
NEPAbeetle is offline
PostPosted: Sun Sep 15, 2024 3:34 pm    Post subject: Doorskin replacement issues Reply with quote
Cut the existing door skin and unfortunately the panel “popped” in the wrong direction. So now the existing metal is roughly a 1/2” below the new. Am i kind of screwed at this point or is there a way to brace it and weld?
far rider Premium Member
far rider is offline
PostPosted: Mon Sep 16, 2024 12:06 pm    Post subject: Re: Doorskin replacement issues Reply with quote
Not sure I follow. Cut in the wrong direction? So horizontal not Vertical? Ice versa? Anyway I have a replacement door repair panel (passenger door. ) Youre welcome to it if you want to pay shipping .
67 zenith blue sunroof
Contentment; when what you have is what you want.
bomberbob
bomberbob is offline
PostPosted: Tue Sep 17, 2024 7:01 pm    Post subject: Re: Doorskin replacement issues Reply with quote
Can you post another photo, but stand back a little bit so we can get the big picture of your question?
1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa
NEPAbeetle
PostPosted: Fri Sep 20, 2024 3:27 am    Post subject: Re: Doorskin replacement issues Reply with quote
Sorry for the confusion. I cut the door lengthwise near the top and the existing panel dove downward under the new panel.
Slow-N-Rusty
Slow-N-Rusty is offline
PostPosted: Fri Sep 20, 2024 12:44 pm    Post subject: Re: Doorskin replacement issues Reply with quote
Some simple butt welding clamps should get that aligned while you tack things together.
NEPAbeetle
PostPosted: Mon Sep 23, 2024 3:41 pm    Post subject: Re: Doorskin replacement issues Reply with quote
Didn’t expect it to come up with the clamps as much as it did but looks like it’ll be okay. Thanks for the tip.
bomberbob
PostPosted: Mon Sep 23, 2024 7:05 pm    Post subject: Re: Doorskin replacement issues Reply with quote
I did the same thing you did, the door skin had the square door handle hole which was not right for my door. Brazilian door. I cut it below the door handle horizontally, but instead of butt welding edge to edge, I used the flange tool to flange the edge, and then I used panel epoxy to glue the two together. I think the flange added some strength. What you are doing should work fine as long as you don't put too much heat in one spot and cause a warp.
Marion, Iowa
