bomberbob Samba Member
Posted: Tue Sep 24, 2024 10:59 am Post subject: Re: Where to start |
Some say older cars without all the electronics is OK to weld with batteries still connected. I don't want to assume the risk, so I disconnect mine. _________________ 1968 Beetle torn apart again
1990 Jetta GLI megasquirted, burning E85 (currently in storage)
2004 Jetta turbo GLI
Marion, Iowa |
CT440ROD Samba Member
Posted: Tue Sep 24, 2024 8:47 am Post subject: Re: Where to start |
If i weld on body do you need to disconnedct both batteries ? |
Posted: Mon Sep 23, 2024 7:15 pm Post subject: Re: Where to start |
I would try one of those stud pullers, I don't have one but I would buy one to try. It welds a stud to your metal, you take a slide hammer and pull the dent, then you snap off the stud and grind off any residue. This way you don't drill any holes and make it worse. Those mold lines are going to make it tough.
Second option would be to drill out spot welds where available, and cut that piece out, and bend a new piece and weld it in. Spray cavity wax up in there after the weld is done so the rust doesn't show up later. _________________ 1968 Beetle torn apart again
Marion, Iowa |
Posted: Mon Sep 23, 2024 10:47 am Post subject: Re: Where to start |
Posted: Mon Sep 23, 2024 5:29 am Post subject: Re: Where to start |
Been a millright for 40 years so I have tools. no way to get behind from bottom or inside. |
63 vwnotch Samba Member
Joined: December 31, 2002 Posts: 764 Location: Riverside,CA Econo Motors
Posted: Sat Sep 21, 2024 11:33 am Post subject: Re: Where to start |
Depends on what kinda tools you have. Can you access the body damage from inside? many variables here and we need more info and or pics _________________ WANTED: 67 earlier Type 3 seats, Z rests |
Posted: Fri Sep 20, 2024 6:54 am Post subject: Where to start |
85 westfilia going to try and fix this dent. any ideas where to start ?
thanks |
