Front Tire Fitment Question...
Akimbeau
Akimbeau is offline
PostPosted: Fri Oct 18, 2024 7:47 am    Post subject: Front Tire Fitment Question... Reply with quote
I have a Thing with a stock front end and I was wondering if I put the Monroe Air Shocks up front and give it a bit of a lift, can I squeeze 215/75/15 tires in there? Or do i need to look at 205s? I'm down in Baja and 205s are a bit hard to find.
KAmes
KAmes is offline
PostPosted: Fri Oct 18, 2024 8:13 pm    Post subject: Re: Front Tire Fitment Question... Reply with quote
I have 205/75/15 with front and rear air shock lift on mine and there is plenty of room. The increase to 215/75/15 is small just a hair over 1/2" taller, think 1/4" above the axle line and 1/4" below. The difference in width is equally small. I suspect they will be fine along with any lift, might be ok most of the time without lift.
