Front brake drum puller.
Ovally
Ovally is offline
PostPosted: Sun Nov 03, 2024 3:27 pm    Post subject: Front brake drum puller. Reply with quote
About 10 years ago I replaced the ball bearings with roller bearings and now it is difficult to remove the front drums.
VW used this puller to remove the front brake drums.
Would this Gedore puller work?
https://www.gedore.com/en-at/products/puller-tools...--8025300#
Thanks.
VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018
Dan22
Dan22 is offline
PostPosted: Sun Nov 03, 2024 7:57 pm    Post subject: Re: Front brake drum puller. Reply with quote
Sure. As long as it pushes on the spindle. Hard to tell with that picture what it is pushing on.
1-0900722 die langsame grüne Schildkröte
https://www.thesamba.com/vw/forum/viewtopic.php?t=765074
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sun Nov 03, 2024 8:52 pm    Post subject: Re: Front brake drum puller. Reply with quote
We would just slide hammer them off.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
Ovally
Ovally is offline
PostPosted: Mon Nov 04, 2024 10:54 am    Post subject: Re: Front brake drum puller. Reply with quote
OK thanks, I'll see how I can fix this without destroying anything.
Never had any problems with ball bearings.The drums always came off easily.
I experience the same as "billmetric" wrote in 2008:
""I have installed the roller bearing conversion onto other customers former ball bearing cars and I personally wouldn't do it to my own cars, the roller bearings tend to be such an extremely tight fit to the axle that they require some filing to get them to slide onto the axle, even with major filing the inner bearing tends to stick on the axle and pulls the seal out any time the drum needs to come back off, that gets to be a real pain when the bearing has to be pried off and if its really on there the seal can get in the way of removing the stuck bearing resulting in messing up the seal just trying to pry the bearing off the axle, theres just something about the size of the roller bearing inner diameter which is smaller than the ball bearing races, the inner races should not be a loose fit though as it will sometimes spin on the axle stub and wear down the diameter even more, I usually just hand file the axle to get a nice snug but removable fit with the inner ball bearing race then take a nice sharp center punch and make a light dimple in the axle shaft to keep the new bearing race from rotating, with the small ball bearing race it doesnt matter if it stays on the axle it will not pull the seal off every time you pull the drum""
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Ovally
Ovally is offline
PostPosted: Wed Nov 06, 2024 7:19 am    Post subject: Re: Front brake drum puller. Reply with quote
A friend made me an extractor ring with a larger outside diameter than the VW one so I could use my 3 arm puller.
The drums with the bearings came off in a straight line without damage to the grease seal.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
Busstom
Busstom is offline
PostPosted: Thu Nov 07, 2024 11:17 pm    Post subject: Re: Front brake drum puller. Reply with quote
Very neat tool, it's like a hybrid of the two you showed above.
cory464 wrote:
Ovally
Ovally is offline
PostPosted: Fri Nov 08, 2024 10:42 pm    Post subject: Re: Front brake drum puller. Reply with quote
Thanks.
""Goed gereedschap is het halve werk" is a Dutch proverb = "Good tools are half the work" that indicates that with the right tools it can be done faster, easier and better.
VW Bug Oval 1953
VW Bug 1200 D motor
Eric&Barb
Eric&Barb is offline
PostPosted: Sun Nov 10, 2024 4:47 pm    Post subject: Re: Front brake drum puller. Reply with quote
Have you loosened up the brake shoes from the drums by adjusting the brake stars???
In Stereo, Where Available!
Ovally
Ovally is offline
PostPosted: Sun Nov 10, 2024 11:52 pm    Post subject: Re: Front brake drum puller. Reply with quote
Of course I did.
The VW puller can be seen in the Repair Manual Bug 1952-1957.
Regards.
VW Bug Oval 1953
VW Bug 1200 D motor
