Where to install the loudspeaker when a clock is already here ?
philoo68
philoo68 is offline
PostPosted: Tue Nov 19, 2024 8:27 am    Post subject: Where to install the loudspeaker when a clock is already here ? Reply with quote
Hi guys,
I have a 53 zwitter (so with the oval dash) with a VDO clock installed in the chrome grill in the middle of the dash. And I also have a radio. Where do you install the loudspeaker when the clock is already in the way ? I assume there are a lot of DIY possibilities, but I am looking for a proper way to dissimulate the loudspeaker behind the dash.
Thanks ! Very Happy Very Happy Very Happy
Phil
KTPhil Premium Member
KTPhil is offline
PostPosted: Tue Nov 19, 2024 8:53 am    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
I've seen folks make up speaker boxes as a rear seat arm cushion that looks like these:
Hiding in plain sight! Hidden wires or Bluetooth connects to your radio/stereo.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
philoo68
philoo68 is offline
PostPosted: Tue Nov 19, 2024 12:15 pm    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
Great idea, but I am looking for a more vintage solution with a vintage Loudspeaker Very Happy
I am thinking about making a spacer, holder for the LS behind the clock but the sound may be awfull..
Wiggy
Wiggy is offline
PostPosted: Tue Nov 19, 2024 1:14 pm    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
You just need the distance ring that goes behind the clock. Then you should be able to get a speaker in there fine.
Kevin "Wiggy"
My 58 Ghia Vert
My 51 Split 11G
My 57 Deluxe
My 56 Oval
56Cabrio
56Cabrio is offline
PostPosted: Tue Nov 19, 2024 1:28 pm    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
What Wiggy said
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
philoo68
philoo68 is offline
PostPosted: Wed Nov 20, 2024 3:35 am    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
56Cabrio wrote:
What Wiggy said
that looks good, but actually I have the distance ring, but the clock is still too deep to allow the LS behind the grill. The back cover with the grooved
nut for the clock is for beauty purpose only ?
splitjunkie
splitjunkie is offline
PostPosted: Thu Nov 21, 2024 5:35 am    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
Do you have one of these spacer/adapter that allowed a larger speaker to be installed and gave more clearance.
Are you using an original speaker or a modern one? The cone depth of lot of modern speakers isn't as deep as older speakers. As you suggested, you could make a spacer out of plywood to push the speaker back to give more clearance. If you do a neat job cutting it and paint it black, it would look like it was a factory part.
Chris
sinclair
sinclair is offline
PostPosted: Sat Nov 23, 2024 5:18 am    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
Pop the clock in the glovebox and free up the speaker space?
AlteWagen
Troll
AlteWagen is offline
PostPosted: Sat Nov 23, 2024 5:02 pm    Post subject: Re: Where to install the loudspeaker when a clock is already here ? Reply with quote
Surprised no one mentioned the Motorola speaker
Ninamashr wrote:
I even ran the external controls for a lil while...
Some other period options
https://www.thesamba.com/vw/forum/viewtopic.php?t=563565
Official Dual Carb Thread
