madster Samba Member
Joined: November 01, 2006 Posts: 221 Location: Rio Grande Valley Texas
Posted: Mon Nov 25, 2024 4:46 pm Post subject: THING transmission in Karman Ghia |
I'm trying to put a 74 VW THING transmission in a Karman Ghia floor pan. Which CV joints/axles would I need? _________________ 1966 BEETLE @ 1973 THING |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80413 Location: Sneaking up behind you
Posted: Mon Nov 25, 2024 4:52 pm Post subject: Re: THING transmission in Karman Ghia |
The Thing flanges are larger so you either need to change flanges or the stub axles. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Posted: Mon Nov 25, 2024 9:01 pm Post subject: Re: THING transmission in Karman Ghia |
Thank you. _________________ 1966 BEETLE @ 1973 THING |
germansupplyscott Samba Member
Posted: Wed Nov 27, 2024 12:53 pm Post subject: Re: THING transmission in Karman Ghia |
| Glenn wrote: |
| The Thing flanges are larger so you either need to change flanges or the stub axles. |
Are the Thing stub axles the same length as a Beetle/Ghia IRS stub axle?
(don't know this either way but suspect the Thing stub axle is different, so changing the flanges on trans might be the simpler way to do the swap) _________________ SL |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15604 Location: Deep in the 405
Posted: Thu Nov 28, 2024 7:59 pm Post subject: Re: THING transmission in Karman Ghia |
You have several choices.
1. Use your Ghia axles and use a Ghia CV on one end of the axle and a Thing CV on the other end. Bug & Ghia use 90mm CV joints. Thing & Bus use 100mm CV joints. You won't need to do anything to your Ghia chassis or the Thing transaxle.
2. You can change the CV flanges on the transaxle and use Bug CV flanges. Then use all your Ghia axles and CV's.
3.You can change the stub axles on the Ghia to Thing stub axles and use the Thing axles and CV's.
If you're building a mild streetcar with 100 HP engine or less just do #1 or #2 whichever is easiest for you.
If you're building a big stroker engine and will see any drag racing #3 will be the strongest.
The Thing transaxle is geared lower than the Ghia trans
74 Ghia (AN code) transaxle has a 3.88 R&P with 3.78/2.06/1.26/.89 gears
74 Thing (AV code) transaxle has a 4.12 R&P with 3.78/2.06/1.26/.93 gears.
Scott... Bug & Thing stub axles are the same length and interchangeable, they just use different sized CV joints. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Nov 28, 2024 10:56 pm Post subject: Re: THING transmission in Karman Ghia |
| vwracerdave wrote: |
Scott... Bug & Thing stub axles are the same length and interchangeable, they just use different sized CV joints. |
Good info above and good to know what the stub axles. _________________ SL |
Posted: Sat Nov 30, 2024 6:24 pm Post subject: Re: THING transmission in Karman Ghia |
Great [quote="vwracerdave"]You have several choices.
2. You can change the CV flanges on the transaxle and use Bug CV flanges. Then use all your Ghia axles and CV's. _________________ 1966 BEETLE @ 1973 THING |
Glenn  Mr. 010
| germansupplyscott wrote: |
Good info above and good to know what the stub axles. |
Porsche 924 are the same. _________________ Glenn
Member #1009
#BlueSquare
