Removing wax From Primer
Adriel Rowley
Adriel Rowley is offline
PostPosted: Sun Dec 01, 2024 6:36 pm    Post subject: Removing wax From Primer Reply with quote
Did a search and not finding a clear answer: will wax and grease remover, such as DuPont DX330 remove wax from primer?
Thanks in advance! Very Happy
Please consider I am Autistic, so I process information differently and still working on social skills. Thanks.
Dad's 1964 Beetle purchased September 1968.
https://www.thesamba.com/vw/forum/viewtopic.php?p=9252810#9252810
1971 Sunroof Squareback with Fuel Injection
http://www.thesamba.com/vw/forum/viewtopic.php?t=219811&highlight=squareback+rejuvenation
viiking
viiking is offline
PostPosted: Sun Dec 01, 2024 7:23 pm    Post subject: Re: Removing wax From Primer Reply with quote
What sort of primer? Epoxy?
Adriel Rowley
PostPosted: Sun Dec 01, 2024 9:33 pm    Post subject: Re: Removing wax From Primer Reply with quote
Not sure, what ever VW used.
Why ask if epoxy? Would that be the least prone to absorb since a sealer?
viiking
viiking is offline
PostPosted: Sun Dec 01, 2024 10:10 pm    Post subject: Re: Removing wax From Primer Reply with quote
Yes. Epoxy is very resistant to chemicals.
If it’s VW primer then any of the wax removers should work but make sure you let it dry so no excess remains in the primer.
Adriel Rowley
PostPosted: Mon Dec 02, 2024 2:50 pm    Post subject: Re: Removing wax From Primer Reply with quote
Would there be a wax to choose over another?
I don't have the funds or space to epoxy primer the whole, just tired of seeing the mess the paint shop did and hard not to suspect took advantage of a weak man (he became that way after FDA approved treatment gave him cancer of the pallet and gave him a very soft voice). So until do, thinking give Ruby a coat of wax, keep from the prior rust getting worse and the original paint shines up nicely; lot of places were not sanded before coating with paint (most of the coachwork primer was not used).
viiking
viiking is offline
PostPosted: Mon Dec 02, 2024 6:44 pm    Post subject: Re: Removing wax From Primer Reply with quote
Ok.
Are you saying you want to wax the car to stop it from deteriorating, hence the question:
“If I ever want to paint the car at a later date, will I be able to remove all that wax?”
Adriel Rowley
PostPosted: Mon Dec 02, 2024 7:02 pm    Post subject: Re: Removing wax From Primer Reply with quote
viiking wrote:
Ok.
Trouble is this forum has a bad habit of going off topic especially when a loaded question. Thus why a generic and simple question. Wink
67ctbug
67ctbug is offline
PostPosted: Tue Dec 03, 2024 3:10 pm    Post subject: Re: Removing wax From Primer Reply with quote
Do not wax the car, it will cause more problems down the road and do no benefit.
'67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote:
...or the PO envied the terrorists' bus in "Back to the Future". Laughing
mukluk wrote:
He's fine, just waiting for the dragon in winklepickers to move out of his lane.
Adriel Rowley
PostPosted: Tue Dec 03, 2024 3:49 pm    Post subject: Re: Removing wax From Primer Reply with quote
So then leave the bare steel to rust or is there a better sealer?
67ctbug
67ctbug is offline
PostPosted: Tue Dec 03, 2024 6:41 pm    Post subject: Re: Removing wax From Primer Reply with quote
Any rattle can primer and paint will be better and safer than wax. How much metal are we talking about?
'67 Beetle L41
'74 Westfalia
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
Mike Fisher
Mike Fisher is offline
PostPosted: Fri Dec 06, 2024 12:25 pm    Post subject: Re: Removing wax From Primer Reply with quote
I would spray gloss clear coat on from rattle cans if you want to protect/keep it original permanently.
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
Mike Fisher
PostPosted: Mon Dec 09, 2024 3:58 pm    Post subject: Re: Removing wax From Primer Reply with quote
viiking wrote:
Ok.
Adriel has a habit of asking Weird questions about things we've never done and always faults us for giving him "Off Topic" answers! Laughing
viiking
viiking is offline
PostPosted: Tue Dec 10, 2024 4:26 pm    Post subject: Re: Removing wax From Primer Reply with quote
viiking wrote:
Ok.
I have an autistic (read brilliant) grandson who asks “different” questions so
I am aware of how he processes things. So I was just trying to help Adriel “normalise” the question for the rest of us dumb-ass-es. Not sure if it was successful.
Mike Fisher
PostPosted: Wed Dec 11, 2024 9:09 am    Post subject: Re: Removing wax From Primer Reply with quote
Yes, wax will work fine for now.
You shouldn't have any trouble removing it & its gases.
Even if it takes a year to afford 2 dozen spray cans it's okay since paint or clear is in your future.
You should buy a gallon of clear and spray it yourself!
