Quick timing gun question
yel-mel
yel-mel is offline
PostPosted: Wed Dec 04, 2024 1:55 pm    Post subject: Quick timing gun question Reply with quote
What is the best place to grab pos,neg, & ground besides the coil ?
I have a newer style timing gun & am currently setting my rpms.
Thanks
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Wed Dec 04, 2024 2:56 pm    Post subject: Re: Quick timing gun question Reply with quote
The battery.
runamoc Premium Member
runamoc is offline
PostPosted: Wed Dec 04, 2024 3:06 pm    Post subject: Re: Quick timing gun question Reply with quote
If it has an alternator, get pos. from the B+ stud and ground from the housing of the alternator too
Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Dec 04, 2024 3:28 pm    Post subject: Re: Quick timing gun question Reply with quote
THIS
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
67rustavenger
67rustavenger is offline
PostPosted: Wed Dec 04, 2024 7:56 pm    Post subject: Re: Quick timing gun question Reply with quote
If the car has a generator, Use a auxiliary battery to power the timing gun.
]'ve used a aux battery for years to time my generator equipped engines.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu Dec 05, 2024 9:32 am    Post subject: Re: Quick timing gun question Reply with quote
I've gotten away on a generator car using either the gen output (but only at low rpm so the voltage is not too high), or even the coil wire (I know, a no-no), but I don't recommend either!
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
runamoc is offline
PostPosted: Thu Dec 05, 2024 10:30 am    Post subject: Re: Quick timing gun question Reply with quote
I have a 009 distributor Cool can't set the timing at low RPMs.
KTPhil is offline
PostPosted: Thu Dec 05, 2024 10:35 am    Post subject: Re: Quick timing gun question Reply with quote
My suggestion for the 009 folks is to set it at high rpm as is proper practice, then lit it get cold and using a test light, manually rotate the engine and see where it comes on, then put a paint mark there on the pulley. You can then set it static and cold without any fancy tools.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
zerotofifty
zerotofifty is offline
PostPosted: Thu Dec 05, 2024 10:48 am    Post subject: Re: Quick timing gun question Reply with quote
I get the light power off the generator/alternator in 12 volt cars. In case of my 6 volt Bug, My light is 12 volt, so I get 12 volts from a my near by 12 volt car or from my 12 volt jumper battery.
Always have a battery cover on your battery in your Bug. Seat spring can short the battery if they touch, and the result can be the seat catching fire, You may be fine, until a heavy object or person is set, or sits over the battery, then poof, you got a fire. Happened to someone I know when a bunch of kids piled into the rear seat. He had no battery cover. He was able to get out and toss the burning seat cushion out of the car in time to save the car. Seat wrecked.
wdfifteen
wdfifteen is offline
PostPosted: Thu Dec 05, 2024 12:54 pm    Post subject: Re: Quick timing gun question Reply with quote
+100
I do this when using a 12 volt timing light on a 6 volt car.
I don't know about your experience, but I found out the painful way that you need to ground the timing light to the car! Mine is a 50 year old Sears light with a metal body, so this might not apply to other lights, but the current from the spark plug wire has to go somewhere, and in my case it was to me.
Dangermouse
Dangermouse is offline
PostPosted: Thu Dec 05, 2024 3:32 pm    Post subject: Re: Quick timing gun question Reply with quote
Same wrt using a 12V timing light for 6V car but doubly so when it comes to reading dwell. I could not get an accurate or stable dwell readout when using a fancy digital timing light (powered by a separate 12V battery) until I added an additional ground wire back to the vehicle; it was perfect after that.
Do not follow me, for I may not lead. Do not lead me, for I may not follow. Do not walk beside me either; actually just bugger off and stand over there will you.
