Ignition switch replacement wiring only
Norma
Norma is offline
PostPosted: Sun Dec 08, 2024 6:41 pm    Post subject: Ignition switch replacement wiring only Reply with quote
Do I need to take apart the steering column to replace the wiring plug as ratwell describes here?
1976 Bay 2.0
Thank you.
https://ratwell.com/mirror/bclausen/How_to_files/IgnSw/index.html
Injected 2.0 Bay Window
3rd owner of 14 years now!
Fortunately, I was able to travel in Norma Jeanne for 1.5 years, from Eureka to Tijuana. I loved every minute❤️
dodger tom Premium Member
dodger tom is offline
PostPosted: Sun Dec 08, 2024 7:18 pm    Post subject: Re: Ignition switch replacement wiring only Reply with quote
that procedure is for removing the switch.
after the fourth photo r atwell says…..
“From underneath the column cover, pull the three wiring plugs downward from their connectors. One is for the wipers, one for signals, and the final for the ignition switch.”
that’s how you remove/change the wires on a ‘78. i assume the ‘76 is similar.
consult your bentley to make sure.
