Timing / Idle Questions - 1978 Bay Window T4 2l FI
chrmcc
chrmcc is offline
PostPosted: Sun Dec 08, 2024 9:04 am    Post subject: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
Hello, I recently noticed my bus running a bit rough and the exhaust smelling rich.
Some pertinent history - about two years ago the points burned up during a long trip, at that time I swapped the distributor w/a Pertronix electronic w/vacuum advance and a Pertronix coil. I also replaced plugs and cables. At the time I thought I set the timing right, but I am questioning that at this point, I think I focused on the idle timing of 7.5 @875, not the all-in w/o vacuum @3500+
Today, I looked at the plugs, lots of black soot, definitely running rich. I cleaned them up and reinstalled. Then I warmed it up good. I noticed idle was at ~950 RPM with timing of ~18 degrees.
I set the adjustment on the AFM to about the mid-point which brought the idle down just a tad, it had been at 3/4 open.
I adjusted the fuel at the screw near the throttle linkage, I could damn near screw it all the way down before it brought the idle down (but also got rougher). I opened it about 1-1 1/2 turns and it stabilized.
With the timing light connected and vacuum advance disconnected, I loosened and adjusted the distributor. I adjusted the idle via the distro to 875 which brought the timing down to ~4 degrees. However, now revved to 3500 the timing was around 28 degrees, which I believe is what we want.
I decided initial timing be dammed and locked the distro down.
When I reconnected the vacuum and revved it to 3500 the timing was ~40. Is that expected, and ok? Again, I verified w/o vacuum it was 28 at 3500.
It drove well afterwards and seemed to have better power but I am wondering why I cannot get the both the initial timing and all-in within spec. I am questioning my choice of distro/electronic ignition.
I plan to add an AFR, head cylinder temp, and oil temp gauge to get better insight.
Thanks in advance!
Chris McC
78 VW Sunroof Bus - mostly stock 2000cc FI
99 Porsche 996 Cab - stock 3.4 flat six
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Sun Dec 08, 2024 10:01 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
Look at that. A fellow Houstonian.
18 degrees at 950 sounds like too much. Is this with the vacuum hose connected? If so it sounds like something is pulling too much vacuum.
If you have something pulling too much vacuum changing the distributor won't fix it unless the vacuum canister is the problem.
Bring it over to me and I can take a look at it for you.
busdaddy
busdaddy is offline
PostPosted: Sun Dec 08, 2024 10:39 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
chrmcc wrote:
......... but I am wondering why I cannot get the both the initial timing and all-in within spec. I am questioning my choice of distro/electronic ignition. .........
Well don't keep it a secret, what distributor do you have?
It sounds like you have multiple little issues, how long have you had theis bus and what has been done to it in the way of tune ups and injection system maintenance?
Слава Україні!
chrmcc
chrmcc is offline
PostPosted: Sun Dec 08, 2024 11:55 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
What part of town are you in? I am NW Houston, Cypress area.
Thanks in advance!
Chris McC
VWNOS.com
heimlich is offline
PostPosted: Sun Dec 08, 2024 11:57 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
I'm right next to you at 290 and the beltway. There are some other people close by that can help you as well.
chrmcc
chrmcc is offline
PostPosted: Sun Dec 08, 2024 12:06 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
The distributor is a Pertronix D186504 with integrated electronic ignition.
The bus has been in the family since 81, I have had it since my dad passed in 2022. Overall, the bus has about 230k miles, the current engine has about 70k. My dad was great about routine maintenance but really did nothing else unless it broke.
I drove it from AZ to TX, that's when the points burned up and I swapped out the distributor w/electronic and replaced plugs and cables.
I replaced suspension and steering components, fuel filter, air filter, oil, and lubed everything but have not done much beyond that.
Thanks in advance!
Chris McC
VWNOS.com
heimlich is offline
PostPosted: Sun Dec 08, 2024 12:08 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
Do you have the original distributor that you replaced?
raygreenwood
raygreenwood is offline
PostPosted: Sun Dec 08, 2024 1:13 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
If it WAS running well at some point with the distributor you have....the LAST thing you do is tweak the AFM adjustment.
So you have a Pertronix Single vacuum/dual advance distributor right? Tis one?
https://www.jbugs.com/product/186504.html?abalt=1&...DgEALw_wcB
Becuase it has mechanical advance as well as vacuum, as idle speed increases, if it begines mechanical advance you will see extra timing when you put the light on it at idle. While the may not be correct...the function is NORMAL>
The first thing you should be looking for is WHY the idle speed has increased which is most probably what is causing the advance.
Typically when you have a vacuum leak in L-jet, it bypasses the AFM flap so you run lean. Since you are not running lean (the black plugs)....the first things to check are fuel pressure and a properly functioning fuel pressure regulator.
At idle, the vacuum should be at about its highest. This causes the rising rate fuel pressure regulator to drop fuel pressure.
If the regulator is shot or teh vacuum line is leaking or disconnected, you get maximum fuel pressure at idle.
This will run you rich. It can also run idle a little bit high as its extra fuel. As long as there is enough air coming in to support combustion....instead of stalling/flooding, it may idle higher which is what can give you higher idle timing.
You have a lot of things to check before you start tweaking the AFM. Ray
chrmcc
chrmcc is offline
PostPosted: Sun Dec 08, 2024 3:24 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
Good information. It was running well, gradually got rough, its running pretty well again but has me wondering how the fuel mixture got so rich, requiring adjustments.
What you described about the fuel pressure makes a lot of sense. I will test fuel pressure and function of the regulator. I found another thread on the subject. https://www.thesamba.com/vw/forum/viewtopic.php?t=175058
Thanks in advance!
Chris McC
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Sun Dec 08, 2024 5:14 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
Chris,
As an FYI-
If your bus is going to be a long term keeper for you, consider replacing that Chinese distributor. I've autopsied the Pertronix and most of the other Chinese distributors and to be frank, they are junk like most poorly made VW parts from China.
The original distributors are vastly superior to the Chinese clones. Most of the Chinese distributors I've autopsied were sent in from customers who couldn't get their VW to run right with them. The customers wanted to know what was wrong with them. So, I autopsied them, shared my findings and threw the parts in my metal recycle bin.
I'm not trying to sell you anything but rather, give you and others a heads up.
Cheers-
The Samba member since 2004.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sun Dec 08, 2024 6:19 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
you can't have something "pulling too much vacuum" it's fucking impossible
manifold vacuum is 15-22 inHg at idle and the same is true at ported vacuum be it a carburetor or a throttle body
The only way those numbers change is at altitude but that's not a problem here.
Get your original distributer rebuilt. Bill (sparkwerks) is the man for this.
I wouldn't go fiddle fucking with anything until you get that china distributor out of the equation.
Sadly, people think "new is better" and it's just not the case anymore. Please, reach out to Bill. He'll get you dialed in, THEN we can see what you have going on once we get this dialed in to factory specs
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Wildthings
Wildthings is offline
PostPosted: Sun Dec 08, 2024 8:11 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
The stock distributor has two return springs for the centrifugal weights, one uses thin wire and a tight coil and is under tension at all times. The second one uses larger wire and has a loose coil and is not under tension until the centrifugal timing has already advanced by 10° or so. Your symptom could be because the spring with the smaller diameter wire either broke or came off it's pegs.
I agree with others that the Pertronix distributors are trash. I thought nearly twenty years ago that this might be a good way to get around the problem with low quality Bosch points so bought one, it pretty much had problems right out of the box so I got the vendor to send me another one which also had problems right out of the box, so I sent them both back and installed a Pertronix ignition module in my old distributor, but it failed after a few months so some non Bosch points went in anf I have had no problems since.
VWNOS.com
heimlich is offline
PostPosted: Sun Dec 08, 2024 9:11 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
This is another common problem. Usually, you will see the timing jumping around because of this.
Bill Schwimmer
Bill Schwimmer is offline
PostPosted: Mon Dec 09, 2024 8:29 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
I am curious if you have one of the aluminum aftermarket timing scales. I chased my tail for a bit timing my bus. I matched up an OE plastic scale to it. And they are wayyyy off to the retarded side.
Wildthings
PostPosted: Mon Dec 09, 2024 9:24 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
I put marks on my fan shroud decades ago that shows TDC and 7.5° BTDC as determined by using a piston stop. I have a plastic scale and can easily verify it by comparing it to the mark on the shroud and time the engine even if the scale were to be damaged.
mikedjames
mikedjames is offline
PostPosted: Mon Dec 09, 2024 11:28 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
With ported vacuum if the throttle plate covering the hole is slighly uncovering it at " idle, " the ported pressure drops from atmospheric as the hole is uncovered down to about half atmospheric.
So messing with the throttle endstop screw to fix a different problem causes too much advance at idle, made worse by the engine running faster and winding on centrifugal advance.
The $15 China distributors are made to have more maximum advance than a Bosch. Because that makes them seem more exciting.
My China distributor is sawn off and used as a No1 indicator for setting valves alongside crank fire system. Best use for a Chinese part...
Ancient vehicles and vessels
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Dec 09, 2024 11:36 am    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
this guy gets it Applause
Jake Raby wrote:
Brian wrote:
raygreenwood
PostPosted: Mon Dec 09, 2024 1:25 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
In my last comment I said that a vacuum leak would bypass air past the AFM flap and cause a "lean condition" and not the rich condition you are gettintg.
That is both correct and incorrect. Let me clarify please.
On this crude diagram, IF....you have a vacuum leak that is leaking anywhere BETWEEN the AFM aand the OUTSIDE of the throttle body (TB)....that air bypasses the AFM and gerts no fuel assigned to it so it WILL cause a lean condition.
This would NOT cause your black spark plug or your excessive idle timing issue.
HOWEVER:
If you have a vacuum leak into the intake system DOWNSTREAM/inboard of the TB....while this will still bypass air around the AFM...causing a lean condition of some level (could be big or small depending on the vacuum leak size).....because the air leak is actually on the HIGH VACUMM side of the TB....it can cause several other issues.
1. The leak I first described (between the AFM and TB) only affects fuel mixture. It does not affect VACUUM level.
2. The second type of air leak (downstream of the TB)...simultaneusly affects fueling by bypassing the AFM (lean input) but it also reduces vacuum.
This mimics a "throttle open" position. You are getting air past the throttle flap. While one might see that still as lean....the actual vacuum leak CAN or WILL affect the vacuum operated fuel pressure regulator.
At idle with no vacuum leaks, the rising rate fuel pressure regulator should give you about 28 psi. When you open the throttle and vacuum bleeds off you can get up to 36 psi of fuel pressure.
If you are idling and 29 psi of fuel pressure is what you should have...that is considered "100%" at idle. This means that every 1 = 3.517% of your fuel mixture.
So if you have a vacuum leak at idle on the inboard side of the TB....lets say you are at 36 psi when you should be at 29 psi. ...thats 7 psi too high ...with each 1 psi worth 3.517%....you could easily be 24.6% too rich across the board at idle.
So....with a small amount of extra air leaking in AND extra fuel being added in because of that vacuum loss....you would easily see a rich burn, higher idle speed and higher idle timing...IF...centrifugal advance is kicking in due to the high idle.
A quick check. At idle, pull the vacuum hose off of the advance unit. If the idle timing drops down again...and/or you feel suction at that small vacuum hose....then either your throttle is not closing all the way or the throttle plate is worn out. With the throttle plate fully closed there should be no vacuum advance signal.
Next check. Put a gage on the fuel rail. If yoyur fuel pressure is higher than 28-29 psi at idle....well...you have found the issue. To find out why....Take a hand vacuum pump and apply vacuum to the fuel pressure regulator while idling. If the pressure drops to 28-29 you have verified that the regulator is working.
Start checking for vacuum leaks now. Check the 0-ring between TB and plenum, runner boots, injector seals, and vacuum line or gasket to the intake plenum all the way to the gaskets between runner and cylinder head.
Ray
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Dec 09, 2024 3:10 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
assuming (and I know better than to do that) everything was ok before the pertronix install, I feel that this is what is happening.
The advance is coming in early due to a garbage part. but, it would 100% make sense to make sure the whole system is (vacuum) leak free
and, I'll echo the timing scale thing. make sure you have a legit scale otherwise you're just never going to get things right
Jake Raby wrote:
Brian wrote:
raygreenwood
PostPosted: Mon Dec 09, 2024 3:32 pm    Post subject: Re: Timing / Idle Questions - 1978 Bay Window T4 2l FI Reply with quote
I would buy that.....but its not clear yet. It "sounds" like he put the P-tron in and drove it for a while no problems. And yes, with a little age it could have shit the bed.
But.....while for sure the P-tron crapping out could cause high idle timing....it's not likely to cause heavy enrichment.
Yes.....we could speculate that the rich reading on the plugs is due to poor ignition....poor spark.....maybe a weak coil? But there would also be a lot more running problems.
This started two years ago when he replaced the old distributor....and he is just noticing now?
My bet is that this thing has not been driven much or sat for a year plus. That sitting still alone is a killer on the FPR.
Not saying you are wrong about the distributor being shit. But, I think he should check the basic before he swaps anything in or out and most especially before he starts tweaking with the AFM.
Ray
