swharris Samba Member
Joined: September 10, 2010 Posts: 640 Location: N. Orange County
Posted: Thu Feb 27, 2025 9:29 am Post subject: Looking for factory COLOR '62 wiring diagram |
Despite what others have told me, '62 is not like '63 and later(slight differences). I can't find a good, clear factory color diagram for the 1962 bus. Can anyone post a link? The only one I can find here is in B&W(National Automotive Service). |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25875 Location: Olympia Wash Rinse & Repeat
Posted: Thu Feb 27, 2025 3:53 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
If you have a bus without the E-flasher system, then use the 1961 wiring diagram. That will be close enough, and why VW did not issue a wiring diagram for just 1962 model year and thru most of the first half of the 1963 model year (mid DEC1962) when the E-flasher system was introduced. _________________ In Stereo, Where Available! |
Posted: Thu Feb 27, 2025 4:22 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Eric&Barb wrote: |
If you have a bus without the E-flasher system, then use the 1961 wiring diagram. That will be close enough, and why VW did not issue a wiring diagram for just 1962 model year and thru most of the first half of the 1963 model year (mid DEC1962) when the E-flasher system was introduced. |
Mine does have 4way flashers, but there seems to be differences compared to the ‘63-on diagram. My flasher does not have a red knob. Standard black knob. Seems OG.
There might be a pic of the dash in this album (on google photos ) of the truck the day I found it.
https://photos.app.goo.gl/FUrgER6tUKuxKd3y9 |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71477 Location: Phoenix 602
70bus  Samba Member
Posted: Thu Feb 27, 2025 5:23 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
There was a discussion about the knob colors in one of the many flsaher/t-s posts somewhere. Black in first models with hazards.
https://www.thesamba.com/vw/forum/viewtopic.php?t=623421&highlight=hazard+knob
Please tell us a few things as you go through the car, and hopefully it is stock enough to give some answers:
You don't have a pod switch, so where does the power (black wire) to the speedo indicator light come from?
What are the manufacturer's numbers on the turn signal can, and what are the numbers on the terminals?
Do hazards work with ign key off?
I thought at first it was a 'factory 12v' sticker, but it looks more like an electric mailbox flag... what is that red thing w/ a wire at left side of dash?
Whatever you do, IF the wiring is stock, it would be great if you could make a wiring diagram for early emergency-flasher buses with no dash light when you get it straightened out. _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
Posted: Thu Feb 27, 2025 5:26 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
swharris wrote: |
Then most likely your type 2 is a 1963 model. Do you have an image of the M-code plate??? _________________ In Stereo, Where Available! |
Posted: Thu Feb 27, 2025 5:29 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Eric&Barb wrote: |
swharris wrote: |
Then most likely your type 2 is a 1963 model. Do you have an image of the M-code plate??? |
Looks like a '62 in the pics since it has hump seat mounts and flat rear wheel wells. _________________ How to Post Photos
62DoKaGuy Samba Member
Joined: May 22, 2011 Posts: 1290 Location: Surprise, AZ
Posted: Thu Feb 27, 2025 6:01 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Yes, ‘62s had factory 4-ways but with a standard black knob. No dash flasher near the fuel gauge either.
I’ve always found the lack of a ‘62 diagram annoying and just piece together from earlier and later model diagrams to make it work. _________________ ,,Wenige Menschen denken, und doch wollen alle entscheiden.'' -der Alte Fritz
EverettB wrote: |
...I went at it from both ends but going from the rear didn't seem to do anything, although I did spray some rust breaker in there... |
4/62 Double Cab
5/61 Panel (sold)
4/59 Single Cab (sold) |
Posted: Thu Feb 27, 2025 6:40 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
EverettB wrote: |
Looks like a '62 in the pics since it has hump seat mounts and flat rear wheel wells. |
I had a brain fart, mixed up the stale air to fresh air DEC62 change over. Do think the 1962 model year was first for the E-flasher, not sure of the date of that. _________________ In Stereo, Where Available! |
70bus  Samba Member
Posted: Thu Feb 27, 2025 7:18 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
I never found a start date for the system in general, but
Date introduced
29 Nov. 62 -15 Dec. 62
Emergency light (USA)
Now: Control light for
emergency light (M 24)
is the time frame each model apparently gets the dash flasher, OR a lighted knob. Or both?
And
6 Apr. 63
17 Apr . 63
19 June 63
Flashing indicator relay
6 and 12 Volt
No w: Simplified control system
could mean the t/s relay, because the hazard circuit certainly ISN'T simplified!
After June there are pages missing, so no clue if there's more detail later.
Anyways, you folks know more than I, but that's what I was able to dig out of Prog Refinements _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Karl the 70 nine-seater |
Posted: Thu Feb 27, 2025 9:25 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Progressive Refinements dash light entry in the Gallery:
1964-65 have a red colored knob with no light.
You posted this in the past in another thread with a good pic of the red knob:
70bus wrote: |
If your hazard switch does NOT light up, it's a 65 or below.
Anyway, I'm not sure what the difference is when there's no light on the dash.
It could just be one wire to the relay but everything else the same?
I don't know. _________________ How to Post Photos
70bus  Samba Member
Posted: Thu Feb 27, 2025 10:27 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
So the progressive refinements seems to point to late Nov/early Dec 62 as when buses got a dash hazard light above the wiper switch. I don't know if making the knob red with letters 'simplified' the circuit, so can't say that doesn't refer to something else. Any Spring 63 owners want to chime in?
Still no start date for the system as a whole, but Ithik it's discussed in the forums somewhere.
As far as power for the speedo indicator, in 61 it comes from a keyed circuit, so if a hazard system works with key off the wiring would more resemble 63. And since there isn't a pod switch, it could be powered straight from a fuse, or elsewhere like maybe a wiper switch. Do 62 wipers work with key off? :) Power can't go straight to relay as it's a K, ground, from indicator bulb, not 49a.
There can't be many of these transitional buses out there, but that's all the more reason to puzzle out a wiring diagram for them. Some people obsess over SO-42 screws, some obsess over dash wiring... _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Thu Feb 27, 2025 10:37 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
70bus wrote: |
Whatever you do, IF the wiring is stock, it would be great if you could make a wiring diagram for early emergency-flasher buses with no dash light when you get it straightened out. |
Sorry for the delay in response. Blew a heater hose on the way home in the Dakota...water pumpers pfft
Quote: |
You don't have a pod switch, so where does the power (black wire) to the speedo indicator light come from? |
I think you mean no dome light switch on the left of the speedo pod? If so, this is a SC. I don't think they came with a switch since I guess VW assumed you can just reach up/back and flick it on. So to your question I don't know off hand. I'll have to look when I get a chance. This is Oscar's weekend and I have to work the carpet(Video Camera op), but early next week I'll check.
Quote: |
What are the manufacturer's numbers on the turn signal can, and what are the numbers on the terminals? |
I'll check when I get a chance Monday.
I thought at first it was a 'factory 12v' sticker, but it looks more like an electric mailbox flag... what is that red thing w/ a wire at left side of dash? |
Currently no, but they did before my generator saga(separate post), but I feel that is more an issue with a misplaced wire. One of the clips on the fuse box came apart and though I fixed it I think I messed something up as the flasher and turn signals stopped working at that time. I also put back to original the engine compartment wiring and wired up an old Ford 6V "hard start" solonid that was jank city before. Did I mention the truck is 6V? It all works fine and starts great, but maybe the PO messed something up previously, and me putting it to "stock" changed things...I don't know. I know none of that helps until you see what is going on. Monday I promise pics and detail.
LOL. I forgot about that thing on the dash under the gas guage. Those pics were in 2011 when I picked the truck up. If I remember correctly, it was a "manual" ground that some PO hacked into a ghetto turn signal switch...or something like that. I never tried to make it work, but it was a neat hack. If you look closely you can see the harness was cut at the column. I had to buy a replacement (WW) turn signal switch and wired it back in. I got it to work along with the 4 ways, but the indicators in the speedo never worked(there is a good thread over in '58 beetle about this issue but not mine). Speaking of hacks, if you look closely under the radio, you will see a bent "crank" handle and bracket. Take a wild guess what the PO did?
OK, I'll tell you, it was a MANUAL wiper crank! I have never seen another one. Actually quite a good idea if you can't get the motor to work. It was hilarious to tell people to get in and crank the handle. It was always good for a laugh. Funny thing was, all that was wrong with the wiper was it was incorrectly wired up. As I sorted through the turn signal I discovered the issue and got it working.
So, with all that said, I think almost nothing is "original", but I'll let you experts take a gander when I post up pics. Oh, I forgot to mention the DC in my sig is a '62 also. Sadly, she is out of commission for many years(very long sad story), but still here.with me. It is very original with the exception of being converted to 12V. I can check to see if they are similar and wired the same way. I do know that it does have flashers in the same location and it has a black knob. That one did not have a switch in the pod when I got it, but I put one in and used it with backup lights(manual). I seem to remember the indicator light working, but that was almost 20 years ago in '06 when the accident happened so my memory is soft on that one.
1962 DC (before and after...yes that is a Binz. It was for sale that day for 10K and no I was not smart enough to buy it )
https://photos.app.goo.gl/V6Gkdh3MfhnzLmxG9
Posted: Thu Feb 27, 2025 10:39 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Eric&Barb wrote: |
swharris wrote: |
Pretty sure '63s did not have hump back seats and 3 position brackets. '61/'62 only. Anything is possible though. I forgot where the plate is on a SC...pass side bulkhead?? |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15189 Location: Casa de Oro, California
Posted: Fri Feb 28, 2025 6:39 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
EverettB wrote: |
1964-65 have a red colored knob with no light. |
Is this a misprint? |
70bus  Samba Member
Posted: Fri Feb 28, 2025 6:47 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
He means 'a red knob, which doesn't light,' and not 'red knob and no light' _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Posted: Fri Feb 28, 2025 7:00 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
BarryL wrote: |
EverettB wrote: |
Posted: Fri Feb 28, 2025 9:23 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
BarryL wrote: |
EverettB wrote: |
70bus wrote: |
He means 'a red knob, which doesn't light,' and not 'red knob and no light' |
Yes, light on the dash but no lighted knob.
Knob like I posted above and E&B posted too. _________________ How to Post Photos
Kommercial Samba Moderator
Joined: December 28, 2000 Posts: 1175 Location: San Tan Valley, Arizona
Posted: Sat Mar 01, 2025 5:18 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
To confirm your statement swharris, yes 62 had wiring that doesn't match the online Diagrams. I ran into that on my june62 with flashers. I need to get around to finishing my altered color diagram. |
Posted: Tue Mar 04, 2025 5:59 pm Post subject: Re: Looking for factory COLOR '62 wiring diagram |
Kommercial wrote: |
That would be amazing if you could. I would be interested. I need to go out and look at the DC and see if it is the same as the SC that I'm having issues with. |
