Last Triumph Samba Member
Joined: October 10, 2006 Posts: 915 Location: Wirral, United Kingdom
Posted: Thu May 08, 2025 12:42 pm Post subject: Door dimension help please |
Bit of a random one, I'm putting a lower inner frame and outer lower skin on a late model door and don't have a reliable reference point for where the bottom edge of the door should be.
I'm just doing the welding and don't have another door or the car to reference, just the door.
Please could someone post the measurement from the swage line to the bottom outer edge of the door both at the front and the rear (assume the same).
Could the measurement be a straight, direct line across the door ends, not following the curve of the door skin, and if possible, in millimeters?
Thanks in advance.
hulbyw Samba Member
Joined: April 24, 2021 Posts: 170 Location: Australia
Posted: Sun May 11, 2025 8:05 pm Post subject: Re: Door dimension help please |
Assumption is the mother of all stuff ups.
My doors are on the car (1968 and not sure what you mean by late model) so measuring in a straight line on the ends is problematic.
I reckon 605mm at the front and 620mm at the rear.
Hopefully someone else on here can also measure for you |
viiking Samba Member
Joined: May 10, 2013 Posts: 3131 Location: Sydney Australia
Posted: Tue May 13, 2025 4:49 pm Post subject: Re: Door dimension help please |
I measured a number of 68 and 70 doors in various states. The best and without damage was:
Rear = 616mm
Front = 610mm
Some doors were similar to yours being that they had no internal skin. I still got similar distances to within a 1-2mm. I was surprised that there was so much difference between the front and rear sides but all measurements showed this. _________________ 1968 1500 RHD Lotus White Beetle since birth. In the hospital for major surgery
Discharged: 1983 Vanagon, 1974 1800 Microbus,1968 Low Light,1968 Type 3 |
