Oversized door hinge pin
balljoint
balljoint is offline
PostPosted: Sat Jun 14, 2025 3:18 pm    Post subject: Oversized door hinge pin Reply with quote
Any one ever used the oversized pins (15.5mm) from WW?
Wanna find out what's involved as from what I see i would need two reamers, one for the upper and lower hole that has an interference fit with the pin on the door side, and one for the middle hole that has some clearance that the pin rotates in that attaches on the frame.
Also is there any other fix beside using an oversized pin?
It doesn't have much meat on that middle section with that 15mm pin(pic)to machine and press in a bushing to use a stock pin...??
It's an ongoing journey, never forget where you came from....
65 rhd Beetle
72 rhd kombi
aeromech
aeromech is offline
PostPosted: Sat Jun 14, 2025 9:37 pm    Post subject: Re: Oversized door hinge pin Reply with quote
I upsized the pin once but it was a 1966 bug
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jun 14, 2025 9:46 pm    Post subject: Re: Oversized door hinge pin Reply with quote
is it the door weld on that has the wear, or the bolt on?
balljoint
PostPosted: Sun Jun 15, 2025 5:23 am    Post subject: Re: Oversized door hinge pin Reply with quote
The door side is not susceptible to wear as it is made to hold the pin hard in place as mentioned before with a press fit.
I have only taken apart one hinge so far and the top hole has slightly more clearance than the bottom, +-14.98mm vs +-14.90mm....Not sure if this is done intentionally, if so then I might need 3 reamers!...Will have to check the others.
But yea....the bolt on side (pic) suffers all the wear as it is the pivot point
65 rhd Beetle
72 rhd kombi
SGKent is offline
PostPosted: Sun Jun 15, 2025 8:01 am    Post subject: Re: Oversized door hinge pin Reply with quote
Angus II wrote:
Hello,
Yes, they remove out the top. The early doors had the hinge "half" welded on by the factory, no screws to be messed with. Have fun getting them back in, it's not a straight shot with a punch and hammer. But, you can use a very large c-clamp too press them back in.
