bnam Samba Member
Joined: July 02, 2006 Posts: 3456 Location: El Dorado Hills CA/ Bangalore, India
Posted: Mon Jun 23, 2025 10:39 pm Post subject: Unusual (?) remote oil filter |
I saw this filter set up in a car that was at our meet over the weekend. I've not seen this before. Anyone have any experience or knowledge about this filter?
It appears to have the input (?) from the T-adapter at the pressure switch location, and the return seems to be thru the stud that it is mounted on - which is one of the studs for the alternator stand.
Seems like a convenient setup that does not have any issue with exhaust clearance etc. and could be retrofitted more easily.
Byas _________________ 1971 1302LS Convertible (RHD) owned since '74
Click to view image
1952 Citroen TA 11BL |
Molly HasaBeetle Samba Member
Posted: Mon Jun 23, 2025 10:45 pm Post subject: Re: Unusual (?) remote oil filter |
I don't know anything about it, but I want it. Very, very badly. That is beyond awesome! @_@ |
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 79419 Location: Sneaking up behind you
Posted: Tue Jun 24, 2025 3:51 am Post subject: Re: Unusual (?) remote oil filter |
Not unusual, they've been around for a number of years.
I forget it's origin. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8840 Location: Sunset, Louisiana
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 1017 Location: South Florida
Posted: Tue Jun 24, 2025 8:25 am Post subject: Re: Unusual (?) remote oil filter |
When you change that filter, how do you avoid making a big mess?
Sure don't want oil on fan belt or crank pulley! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 4463 Location: viroqua wi.
Posted: Tue Jun 24, 2025 8:49 am Post subject: Re: Unusual (?) remote oil filter |
MrGoodtunes wrote: |
You need to park on a steep hill  |
Root_Werks Samba Member
Joined: December 31, 2007 Posts: 1050 Location: San Juan Islands
Posted: Tue Jun 24, 2025 9:22 am Post subject: Re: Unusual (?) remote oil filter |
Kinda cool, haven't seen that before either. _________________ When I set my timing, why do I flush, then take a pee? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33023 Location: Hot Arizona
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 242 Location: Eastern north carolina
Posted: Tue Jun 24, 2025 1:15 pm Post subject: Re: Unusual (?) remote oil filter |
Cusser in your experience did these filters offer any real improvement over a stock VW system? |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 10998 Location: Oregon
Posted: Tue Jun 24, 2025 1:25 pm Post subject: Re: Unusual (?) remote oil filter |
Bobs67vwagen wrote: |
Q-Dog wrote,
Quote: |
That is a bypass filter, not full flow. Better than nothing, but not by much. |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!  |
Cusser Samba Member
Posted: Tue Jun 24, 2025 2:17 pm Post subject: Re: Unusual (?) remote oil filter |
I do not know, as the only engines we tore down and rebuilt were private customers' cars.
But we had maybe 50 rental dune buggies and maybe 10 VW sedans, and I remember most of the dune buggies had these filters on their engines. These buggies were built elsewhere and purchased by Sun Buggy Rentals, used a full-size VW pan, and sat four.
I would guess that such filters do help some, as particles suspended in the oil would get filtered out; it's just that some of the oil would go through the filter on each rpm, some would not, so any particles may not be caught by the filter as quickly as on a full-flow filter system. Remember that when oil is cold it goes through the relief valve system and doesn't get filtered even on a full-flow filter system. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue Jun 24, 2025 5:42 pm Post subject: Re: Unusual (?) remote oil filter |
Thanks for the reply Cusser as I had never seen one of those before. Maybe they were not very common on the East coast. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 35832 Location: Conejo Valley, CA
Posted: Wed Jun 25, 2025 8:44 am Post subject: Re: Unusual (?) remote oil filter |
A bypass filter was good enough for early Porsche 356 engines, so it must have done SOME good!
One comment about these was (emphasis mine):
Quote: |
The 356 oil filter is a bypass filter which means that it samples a portion of the oil with each pass and filters much smaller particles than can a full flow filter. Bypass filters don't need a bypass valve and use a different filter medium than full flow filters. Filtration of 95% of particles larger than 1 micron seems possible. There is probably a trade off between the filter particle bypass size and the flow, and probably an optimum for our engines. |
Then again, if you want a really unconventional filet setup, go for one of these vintage filters!:
_________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Mikemck356 Samba Member
Joined: October 27, 2024 Posts: 18 Location: Ann Arbor
Posted: Wed Jun 25, 2025 8:53 am Post subject: Re: Unusual (?) remote oil filter |
Then there was the filter that used a roll of toilet paper. |
KTPhil  Samba Member
Posted: Wed Jun 25, 2025 9:12 am Post subject: Re: Unusual (?) remote oil filter |
Mikemck356 wrote: |
That is the Stilco I posted above. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
Posted: Wed Jun 25, 2025 9:48 am Post subject: Re: Unusual (?) remote oil filter |
I wonder how long Stilco stayed in business with a " lifetime guarantee" on this? |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2862 Location: HdG, MD & NJ
Posted: Wed Jun 25, 2025 11:26 am Post subject: Re: Unusual (?) remote oil filter |
Don’t know if that’s the Purolator system. I sold one, recently. There was a kit probably from Brazil that was available years ago. I think it went between the cooler and case. You had to trim the bottom of the fan shroud for it.
Edit: Found the pic of mine. It looks the same. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
Cusser Samba Member
Posted: Wed Jun 25, 2025 12:09 pm Post subject: Re: Unusual (?) remote oil filter |
Mikemck356 wrote: |
What kind of crap was that? _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn  Mr. 010
halfassleatherworks Samba Member
Joined: December 09, 2018 Posts: 803 Location: Reno NV
Posted: Wed Jun 25, 2025 1:07 pm Post subject: Re: Unusual (?) remote oil filter |
As good as a full flow? No, but Better then a screen? Yes, and it will filter the oil as long as the Engine is running, it is hooked to the main oil supply before the bypass. |
