Andymon Samba Member
Joined: February 24, 2015 Posts: 399 Location: Medford, OR
Posted: Fri Jul 04, 2025 8:20 am Post subject: Hi lift jack bumper mounts |
Does anyone know if there are mounts out there that would work for a hi lift jack on the stock front bumper? Not the chrome bumper but just the black steel one? _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
jimf909 Samba Member
Posted: Fri Jul 04, 2025 9:37 am Post subject: Re: Hi lift jack bumper mounts |
The stock "bumpers", whether steel or fiberglass, were non-structural bumper covers concealing the structural bumper. If you want to jack from the front or rear of the van there would need to be a jack mount attached to the structural bumper.
I've often thought of welding mounts like the one below to provide a jack mounts at the front and back of the van. Say, mount four of the circular mounts, carry one jack and lift the corner that needs to be lifted. That sounds similar to your farm jack idea.
https://www.amazon.com/FZZD-Trailer-Vertical-Adjus...&psc=1
_________________ - Jim
Butcher wrote: |
This is the main fault with DIY'ers, they get together on these forums and pat themselves on their backs spreading bad information. |
Guilty as charged.
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8372 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Fri Jul 04, 2025 9:49 am Post subject: Re: Hi lift jack bumper mounts |
…or do you simply want to carry your jack on the front bumper? That’s been done:
https://vancafe.com/twin-peaks-hi-lift-jack-mounti...UqDg82ci--
PS: Not at all sure which “black bumper” you mean, any black steel bumper is probably aftermarket but may be exactly what is shown in the link.
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Fri Jul 04, 2025 9:51 am Post subject: Re: Hi lift jack bumper mounts |
[quote="jimf909"]The stock "bumpers", whether steel or fiberglass, were non-structural bumper covers concealing the structural bumper. If you want to jack from the front or rear of the van there would need to be a jack mount attached to the structural bumper.
I'm looking for mounting brackets (mounts) to be able to mount the hi lift jack to the front bumper. Not jacking points. _________________ "Blanch" '85 Westy
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7164 Location: Honolulu,Hawaii and France
Posted: Sat Jul 05, 2025 1:38 am Post subject: Re: Hi lift jack bumper mounts |
[quote="Andymon"]
jimf909 wrote: |
I'm looking for mounting brackets (mounts) to be able to mount the hi lift jack to the front bumper. Not jacking points. |
It's too flimsy, you'll have to make some sort of factory fog light brackets that go around the bumper to the chassis, for the front.
For the rear using the bumper brackets as anchors. _________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
SteveMc Samba Member
Joined: December 19, 2013 Posts: 213 Location: Alberta, Canada
Posted: Sun Jul 06, 2025 7:52 pm Post subject: Re: Hi lift jack bumper mounts |
Yeah, no way that would work for the front OEM bumper that I'm hoping for. _________________ "Blanch" '85 Westy
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4546 Location: East Kootenay, British Columbia
Posted: Sun Jul 06, 2025 8:19 pm Post subject: Re: Hi lift jack bumper mounts |
Andymon wrote: |
Yeah, no way that would work for the front OEM bumper that I'm hoping for. |
Yes you can make it work. I bought one similar to the GW one, but a lot less $ (found online, sorry don't remember where).
Requires drilling holes through the front crash support that is under the flimsy stock bumper. Add a spacer on top of that to match the void between body and bumper and then match holes through bumper. Attach with bolts long enough to pass all the way from top to bottom.
I installed one on the front of my Westy; even though it has a RMW bumper, the mounting is the same, as the RMW bumper is plate steel and not strong enough to support a 2" receiver. Bit of work but end result is very sturdy.
Not a very close up pic but you can see it here:
I use mine for either Hi-Lift (using the GW adaptor) or a pressurized water tank:
_________________ Currently:
All that's needed for evil to prevail is for good people to do nothing.
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Mon Jul 07, 2025 9:24 pm Post subject: Re: Hi lift jack bumper mounts |
[/quote]
Thanks but that's more work than I want to do. _________________ "Blanch" '85 Westy
