mcdragracer Samba Member
Posted: Tue Jun 24, 2025 6:52 am Post subject: Solex 32 pbic float setting? |
| I'm finally finishing up the restoration on a dual set of 32 pbic carburetors, wondering if anybody has some information on how to properly set the float level and what the measurement number is, much appreciated! |
RUNKLE Samba Member
Posted: Thu Jun 26, 2025 8:42 am Post subject: Re: Solex 32 pbic float setting? |
19mm from the top mating surface of the carb body to the flat surface of the petrol/fuel/gasoline, otherwise known as the meniscus.
How to properly set the fuel level - increase/decrease the thickness of the gasket to the float needle valve, or by adding/subtracting gaskets. The float toggle lever can be bent to adjust for the level of fuel as well. Pre fuel level check prep - atypical Solex protocol.
. _________________ Type 1
Type 3
1968 Squareback |
Posted: Thu Jun 26, 2025 9:05 pm Post subject: Re: Solex 32 pbic float setting? |
| RUNKLE wrote: |
Thanks for the info! |
