12mm wheel bolt torque on wide 5
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Bug53
Bug53 is offline
PostPosted: Sat Jul 12, 2025 2:15 am    Post subject: 12mm wheel bolt torque on wide 5 Reply with quote
Going with the spec.'d torque of 72 ft. lbs. and I had to stop.
I have replica BRM's from CIP1, modified a set of thier wheel bolts. On one of the front drums (have to be aftermarket shit) i feel the threeds starting to pull. You just know the feel.
I went with 60ft.lbs. for all the wheel bolts now.
Aftermarket front drums only have about 3/8" of thread in the drum.
How in the hell is that supposed to handle 72ft. lbs.
Been thinking about studs and nuts but then what gives if you have a flat and have to resort to the stock wheel?
The 60 degree wheel nuts for the BRM's I think wont properly mate with the stock wheels.
Thanks in advance for your thoughts.
Never blame lazy people, they didn't do anything.
ps2375
ps2375 is offline
PostPosted: Mon Jul 14, 2025 4:13 pm    Post subject: Re: 12mm wheel bolt torque on wide 5 Reply with quote
That's why I carry a correct set of lug nuts for the spare.
Bug53
Bug53 is offline
PostPosted: Tue Jul 15, 2025 1:06 am    Post subject: Re: 12mm wheel bolt torque on wide 5 Reply with quote
What is the angle of the stock type lug nut?
oprn
oprn is offline
PostPosted: Tue Jul 15, 2025 4:31 am    Post subject: Re: 12mm wheel bolt torque on wide 5 Reply with quote
I believe they are actually ball shaped and as such do not have a specific angle.
Quite frankly I have never been a torque wrench on wheel nuts kind of guy. Dad taught me how to think about what you are doing and trust the feel of it. When all the squish is gone and the pressure comes up hard and quick... you are done. It's really that simple.
I have been swapping wheels and tires on our cars for 60 years now without one single failure using this method. That is a better average than the tire shops I have patronized! In fact I don't let them put my wheels on anymore. I take them in loose and put them back on myself at home.
I do not know of one car manufacturer that supplies torque wrenches with the spare tire. They size the wrench handle length so that the average person changing a flat on the road can get it right 100% of the time.
slalombuggy
slalombuggy is offline
PostPosted: Sun Jul 20, 2025 11:37 am    Post subject: Re: 12mm wheel bolt torque on wide 5 Reply with quote
I used to torque my lug bolts to 50ft/lbs on my buggy even with big sticky slicks mounted on the wheels for autocross. I pulled the threads out of 2 new "german" wide 5 drums at 75lbs. I put 12mm Wurth-certs in all 4 drums and torqued to 50# never had an issue for many years till I went to studded disks.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
