Pressure plate bolts
Ted2
Ted2 is offline
PostPosted: Wed Jul 09, 2025 6:18 pm    Post subject: Pressure plate bolts Reply with quote
Hi everyone,
I'm finishing up a 1300 Okrasa build. Its time to install the clutch but I don't have origional m8x20mm bolts.
Are these high strength bolts?
Thanks
[email protected]
JERRY63VW@YAHOO.COM is offline
PostPosted: Thu Jul 10, 2025 9:30 am    Post subject: Re: Pressure plate bolts Reply with quote
Ted2 wrote:
Hi everyone,
Thanks
Why can't you find any ?? They are the same as 1600cc bolts they sell new ones $5 to $12 for the bolt kits ... but if you want to buy them from your hardware grade would be 10.9
Last edited by [email protected] on Thu Jul 10, 2025 9:57 am; edited 1 time in total
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 10, 2025 9:55 am    Post subject: Re: Pressure plate bolts Reply with quote
Yes, high strength. 10.9
Any good hardware store should have them.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Ted2
Ted2 is offline
PostPosted: Thu Jul 10, 2025 10:24 am    Post subject: Re: Pressure plate bolts Reply with quote
Thanks, The grade is the info I was looking for.
Ted2
Ted2 is offline
PostPosted: Thu Jul 10, 2025 11:25 am    Post subject: Re: Pressure plate bolts Reply with quote
Bellmetric has an excellent selection.
Mr. 010
Glenn is offline
PostPosted: Thu Jul 10, 2025 11:27 am    Post subject: Re: Pressure plate bolts Reply with quote
So do most Ace Hardware stores.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
