Rombauer Samba Member
Posted: Wed Aug 06, 2025 10:04 am Post subject: Installing an Engine Compartment Light |
Ever have to change a belt in the dark while holding the flashlight with your teeth? Me neither, but hopefully my recent project will eliminate that problem in the future.
The parts included a LED license plate light and a rotary SPST switch obtained from a local FLAPS for about $10. Additionally, I used some scrap aluminum angle, a couple feet of 18 ga. wire, a few spade connectors, some heat shrink tubing, a couple dabs of JB Weld and four small magnets.
Here is a diagram showing the layout and how it was connected to the existing license plate light circuit. Note that the installation is completely reversible. No cutting of existing wires and no new holes drilled in the body. Simply plug and play:
Here is the result, an illuminated engine compartment. Something VW overlooked:
Glenn  Mr. 010
Joined: December 25, 2001 Posts: 80369 Location: Sneaking up behind you
Posted: Wed Aug 06, 2025 10:09 am Post subject: Re: INSTALLING AN ENGINE COMPARTMENT LIGHT |
My flashlight has a magnet on the end so it's not confined to just the engine compartment.
BTW, your generator needs to be rotated 90* clockwise for the cooling vent, in the tin, to properly cool the generator. _________________ Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי |
blsthng Samba Member
Posted: Wed Aug 06, 2025 2:30 pm Post subject: Re: Installing an Engine Compartment Light |
that is a neat idea
thanks for sharing |
KAmes Samba Member
Joined: February 16, 2014 Posts: 917 Location: Illinois
Posted: Wed Aug 06, 2025 5:53 pm Post subject: Re: Installing an Engine Compartment Light |
| I like it! |
Posted: Wed Aug 06, 2025 6:50 pm Post subject: Re: Installing an Engine Compartment Light |
Glenn,
Thanks for the tip. I didn't install the engine but will reclock the generator the next time I have it out.
The Thing Shop Manual indicates that you are correct and my configuration is wrong.
mondshine Samba Member
Joined: October 27, 2006 Posts: 2819 Location: The World's Motor Capital
Posted: Fri Aug 08, 2025 6:46 am Post subject: Re: Installing an Engine Compartment Light |
I use a Hella power socket, mounted where the diagnostic plug used to be.
This thing is wired directly to the battery through a 7.5 amp fuse.
It is also grounded directly to the battery so it can be used when my battery disconnect is switched off.
I use this thing to power a work light, my timing light, and over the winter, with my battery disconnect switched off my Battery Tender plugs in there.
Yarkle  Samba Member
Joined: August 03, 2009 Posts: 1261 Location: the Hills of Western Maine
Posted: Sun Oct 19, 2025 3:36 pm Post subject: Re: Installing an Engine Compartment Light |
is that a regular 12 volt (like a cigarette lighter socket) or the Euro style one? _________________ JuadaLupe 1974 Thing [o\==/o] |
Posted: Sun Oct 19, 2025 3:44 pm Post subject: Re: Installing an Engine Compartment Light |
It's just like the photo.
A standard DIN power socket, (like the one on the dash panel) and plug; commonly available on-line.
A small piece the socket is visible in this photo, (upper right).
Yarkle  Samba Member
Posted: Sun Oct 19, 2025 4:03 pm Post subject: Re: Installing an Engine Compartment Light |
I have a KACO trouble lamp (its only got like 8 foot cord tho), so I have the earlier style socket in my dash. Ill have to see if theres a flat mount one available
Fantastic looking engine bay !
thanks! _________________ JuadaLupe 1974 Thing [o\==/o] |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 549 Location: Northridge, CA.
Posted: Sun Oct 19, 2025 11:24 pm Post subject: Re: Installing an Engine Compartment Light |
V
Volkswagen never overlooked the light in the engine compartment or the trunk.
They offered the Kaco light that would plug into your dash plug and with a long cord would reach the engine compartment or the trunk. Volkswagen of America offered a light that had a built in mercury switch and one simple wire to hook up to a 12v source. The 12v source in the engine compartment was the regulator. The light was very easy to hook up, no switches or plugs, just one wire. I have one in the trunk and one in the engine compartment. |
Glenn  Mr. 010
Posted: Mon Oct 20, 2025 4:28 am Post subject: Re: Installing an Engine Compartment Light |
I have one of those in my Frunk. _________________ Glenn
Member #1009
#BlueSquare
