Consequences of a reversed fuel filter?
summerof78
summerof78 is offline
PostPosted: Fri Aug 15, 2025 9:33 am    Post subject: Consequences of a reversed fuel filter? Reply with quote
I'm looking at a 1970 T1 and the guy admits it won't start/run.
He sends me a pic of the engine and the first thing I notice is the filter is on backwards!
Can permanent damage result from this on an ACVW engine, or is it just a silly, reversible mistake, so to speak?
Lookin' for a wheel stamped 5/66
KTPhil Premium Member
KTPhil is offline
PostPosted: Fri Aug 15, 2025 10:04 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
No damage, unless it was clogged with crap and THEN put on backwards, which would send the gunk into the carb.
Filter shouldn't be in the engine bay anyway, unless its metal and clamped to something so it doesn't shake. Put a metal one (and write the date on it) and mount it next to the tranny.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
summerof78
PostPosted: Fri Aug 15, 2025 10:49 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Thank you. From what I could make out from a web search is that performance would certainly suffer and it could screw up the fuel pump from continued backwards pressure.
busdaddy
busdaddy is offline
PostPosted: Fri Aug 15, 2025 11:00 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
It depends on how clean the tank and system is, if it's making lots of crap a rreversed filter will clog up quickly (less surface area), if it's fairly clean then you may never notice an issue.
But look at it as an indicator of the skill level of the person maintaining the car, count on many other surprises.
Слава Україні!
summerof78
PostPosted: Fri Aug 15, 2025 11:12 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Certainly crossed my mind! Shocked
KTPhil is offline
PostPosted: Fri Aug 15, 2025 12:01 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Yes, this is a warning!
Like when I found a PO had "bridged" the front clutch cable eye and the pedal arm with a big PAPER CLIP, being too lazy to unhook the back and do it again. I thought back to the sale discussion where he proudly said he had rebuilt the engine recently... surprisingly, the engine lasted a couple more years!
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
scottyrocks
scottyrocks is offline
PostPosted: Fri Aug 15, 2025 2:04 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
If that's all that's causing it to run poorly, and he's selling it in not running condition, you could be sitting on gold.
– D. Tartt, 'The Goldfinch'
summerof78
PostPosted: Fri Aug 15, 2025 2:26 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
That thought also crossed my mind, but not sure how realistic that is. Probably more wishful thinking on my part... d'oh!
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Sat Aug 16, 2025 5:13 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
If you can post the picture that was sent to you, more "faux pas " may be revealed.
summerof78
PostPosted: Sat Aug 16, 2025 9:09 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Not a very good pic, but have at it!
Bobs67vwagen
PostPosted: Sat Aug 16, 2025 10:43 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Hard to see any detail on that photo. I can see the left side fan housing tube to the muffler is either missing or not connected which if run like that for a while is not a good sign. Kind of surprising to see the one year only reflectors on brackets from the bumper still there. Alot of those are long gone.
PostPosted: Sat Aug 16, 2025 4:15 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
It looks like maybe the vacuum line came off the carb.
I'm not sure that would affect idle but it could drive like crap with the distributor not advancing
summerof78
PostPosted: Sat Aug 16, 2025 5:59 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
That vacuum line has definitely seen better days.
zerotofifty
zerotofifty is offline
PostPosted: Sun Aug 17, 2025 7:13 am    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Likely none
Sorry About That Chief.
Give Peace a Chance.
Words to live by.
KTPhil is offline
PostPosted: Sun Aug 17, 2025 1:49 pm    Post subject: Re: Consequences of a reversed fuel filter? Reply with quote
Maybe this helps:
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
