My newest 66
swhitcomb
swhitcomb is offline
PostPosted: Fri Oct 10, 2025 11:50 am    Post subject: Re: My newest 66 Reply with quote
Root_Werks wrote:
That is a clean Bug, nice find!
Thank you sir!
The engine is coming out this weekend. Went to take it to a show Saturday morning, and the slight oil cooler seal leak turned into a fountain. It’ll be totally different when it goes back, although it’s going to remain a single port 1300.
My 71 Ghia Been in my family since 1980
My Patina 66
My 74 Ghia
07 Boxster
View user's profile Send private message Send e-mail Visit poster's website AIM Address Facebook Instagram Gallery Classifieds Feedback
swhitcomb
PostPosted: Sun Oct 12, 2025 7:17 pm    Post subject: Re: My newest 66 Reply with quote
So I pulled the engine today. Ever since I bought it, the starter misses a tooth occasionally. I assumed the starter was going bad. Realized today that it was the flywheel.
I had no idea 6v flywheels aren’t available anymore. Luckily I have a good one. Not sure if I’ll have it resurfaced or go to all the expense of going 12v flywheel. The car is already 12v.
The oil cooler seals were leaking. The engine is covered in oil and debris. The exhaust was completely rotten but I knew that. The baffle was missing from the base of the generator stand. The clutch was completely shot. I don’t know how it wasn’t slipping. The axle boots are hard, and broken. The tar board was falling apart and had red overspray all over it. Both the engine, and firewall seal are shot.
Covered in debris
Exhaust valve for number 3
Clutch
Piston/cylinders
Down to a short black
Flywheel I have laying around. It’ll need to be cleaned up and resurfaced
The entire exhaust is going in the trash. I have better heater boxes and a new muffler. It’s going to be an alternator and the ugly regulator screwed to the shroud is going away. I am powder coating all of the tin. I have a few other things planned for it. Hopefully it goes back together with no issues. The heads seamed to be in decent shape, and the bottom end is as well. So, clean up, reseal, going to do a minor refresh on the heads, and put it back together.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Mon Oct 13, 2025 6:20 pm    Post subject: Re: My newest 66 Reply with quote
Started cleaning and assessing today. Blasted the cylinder 3/4 head with walnut shells and cleaned it up quite a bit. I’m still going to clean it up some more, but it’s clean enough now to see what needs to be done. I had already ordered exhaust valves for it. Being a non doghouse engine, there’s no way I was going to tear it apart and not replace them. Well, the end of the valve stems it’s pretty worn, so I now have intake valves on the way as well. I ordered a set of rings for it this morning. I’m going to hone the cylinders. The number 3 exhaust valve appears to be burned. That being said, aside from the valves, the heads appear to be in decent shape. The rest of the engine will clean up nicely. There isn’t excessive endplay on it. I managed to clean up the flywheel I dug up with a wire wheel on a drill. I’ll take it and have it resurfaced.
Before I cleaned them. Absolutely covered in oil. The cooler must’ve been leaking for a long time.
After I walnut shells
Good representation of before and after
The flywheel
My Patina 66
My 74 Ghia
07 Boxster
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Tue Oct 14, 2025 5:53 am    Post subject: Re: My newest 66 Reply with quote
It's good to see someone willing to keep a 1300 as a 1300 at least for a while. I still think it was the best type 1 motor VW ever built.
Big Bill
Big Bill is offline
PostPosted: Tue Oct 14, 2025 6:47 am    Post subject: Re: My newest 66 Reply with quote
I have to agree with Bobs67, my first VW was a 66 with a 1300. I played the 6V flywheel /12V electrical game for 2 flywheels, after the second flywheel started acting up decided to go with a 12V flywheel and the related parts to change it over. That was in maybe 1978 or so, learned a lot about VWs from that car wish I had a few photos of that bug.
wdfifteen
wdfifteen is offline
PostPosted: Tue Oct 14, 2025 6:58 am    Post subject: Re: My newest 66 Reply with quote
I had a 12 volt converted car with 6 volt flywheel and starter and 12 volt solenoid for years - probably 60k miles. I always felt like I was living on borrowed time. When it finally did start giving me problems I put in one of these 12 volt starters with 6 volt gears. It's been working great. $267.00 and no more worries that I'm wrecking the flywheel.
BTW, the 66 engine was my least favorite. The seem to pull head studs out of the case worse than the 40 hp. Maybe it was just my experience.
swhitcomb
PostPosted: Tue Oct 14, 2025 6:08 pm    Post subject: Re: My newest 66 Reply with quote
I don’t know why, but something about this car has screamed at me since I bought it, go vintage speed. Keep it a 1300 and do little things to squeeze a little more power out of it. So, I bought the how to hot rod your VW engine book. Was written in 1970. I want to build it as if it’s the early 70s and I’m buying bolt ons for it. There are just a few things I haven’t decided on yet. It has a 30 pict 3, which would’ve been a bolt on in the 70s, and is a stock VW part giving stock reliability. But, I have a set of dual 34s laying around that would look great on it. They’d obviously have to be jetted down, but would be cool. I’ve owned 14 air cooled VWs over the last 32 years, and never had an engine that wasn’t pretty much bone stock. I’m at a point in my life where I have a little extra money, and want something different.
The 12v starter with a 6v gear is a great idea. Think I’ll swap it out.
The interior is in a box and needs to be installed. Can’t wait to get it done and post it.
I plan on swapping the beam and brakes this winter. Hopefully time permits. My wife is having her Fastback painted and an interior put in it, so I’ll have to disassemble and reassemble it. There isn’t enough time in the day.
That all being said, pulled a few valves out of the heads today. The guides are shot. So, off to the machine shop the heads go.
My Patina 66
My 74 Ghia
07 Boxster
Bobs67vwagen
PostPosted: Wed Oct 15, 2025 3:41 am    Post subject: Re: My newest 66 Reply with quote
From late 1978 until 1981 I drove a 66 bug all over socal and across country and back. It had a 1300 in it that I bought from a gal that wrecked her car for around $125.00. it was probably the best running VW motor I ever had, and I had had 2 brand new ones in the early 70s. The smoothest setup I had on it was a stock 30 PICT-1 with a German 009, and a cheap extractor exhaust with a quiet pack muffler. With the 66 transaxle gearing it was very responsive on local roads, and as you know a little short on over 65 driving, so I did not exceed that speed. I am interested to see how your 70s bolt on enhancements work out. Keep up the good work and thanks for sharing it.
swhitcomb
PostPosted: Wed Oct 15, 2025 6:59 pm    Post subject: Re: My newest 66 Reply with quote
So while I’m waiting on parts, I decided to dig into the engine compartment and cleaning it up a little. Found this mess.
Going to cut it out and replace it.
Also the axle boots are completely shot, but I already knew that.
Removed the engine seal and firewall seal. I have new ones. Kind of dreading putting them in.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Thu Oct 16, 2025 6:27 pm    Post subject: Re: My newest 66 Reply with quote
Cleaned up the case today. There must’ve been 3/8” or more of oil on almost all of it.
This is a piece of the firewall tarboard that was stuck between cylinder 1 and 2.
My Patina 66
My 74 Ghia
07 Boxster
sportin-wood
sportin-wood is offline
PostPosted: Thu Oct 16, 2025 9:01 pm    Post subject: Re: My newest 66 Reply with quote
With all that sludge cleaned off, it HAS to run cooler, too. Nice job!
Dave
1966 Bug project
1973 Thing project
swhitcomb
PostPosted: Tue Oct 21, 2025 4:38 pm    Post subject: Re: My newest 66 Reply with quote
Well, I solved the flywheel problem.
As you may remember, the teeth were chewed up on my old one. I had one in my stash, but it needed to be resurfaced. Got it back today.
Before
After I got it back
Heads go to the shop on Thursday. Took the new exhaust to the shop that coated the one on my wife’s Fastback today.
And then there are the minor things. Ordered some stuff from CIP and wasn’t quite at the $99 for free shipping. So I added a new hood emblem. I ordered the trim a few weeks ago and didn’t realize the hood emblem was in such bad shape. Haven’t put the new trim on yet, but I realized the emblem would looks really bad with new trim.
Can’t wait to get the new trim on.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Wed Oct 22, 2025 5:35 pm    Post subject: Re: My newest 66 Reply with quote
So, last month I bought 2 engines dirt cheap. Didn’t really need them but they were too cheap to pass up. Pulled one of them apart this week. Discovered it had 1300 single port heads in it, opened up for 90.5 pistons. So, I ordered some 88s that slip into the case if the heads are machined for 90.5s. The other engine has a 1500/1600 intake manifold on it. I’ve read you can port the 1300 head and use the later manifold and get more fuel delivery while appearing to be a stock 1300. I’m either going to do that or dual 34s jetted to work with it. Haven’t decided yet.
Anyway, they cleaned up rather nice.
They are going to the same shop that did all the machine work on my wife’s Fastback tomorrow. Going to have new guides, the seats worked, and porting work.
While I’m waiting on parts for the engine, I decided to start installing parts I’ve bought and haven’t put on it yet. Trim looks much better.
Before
After
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Sun Nov 02, 2025 10:06 am    Post subject: Re: My newest 66 Reply with quote
Continued some clean up work this weekend.
As you may remember, I replaced the bumpers back in the summer. The brackets were ugly and rusted. The bolts were pretty much stuck, and I didn’t want to fight them and end up with the mess of broken bolts during show season.
This weekend I started working on fixing that. I ordered new brackets months ago. Powder coated them and started fitting up the bumpers and making it look better last night. Going to finish it up today.
The old rotten ones.
Freely powder coated. Still have to fit the seal up nicely.
Also decided to go a little different direction on the carburetor. Won’t be ready until after the first of the year though, so gives me time to do a lot of other work to it while I wait.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Mon Nov 03, 2025 7:48 pm    Post subject: Re: My newest 66 Reply with quote
Well, that’s better. Powder coated, new rear brackets, and new seals.
Also replaced the grab handle while I was waiting for parts to bake
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Tue Nov 04, 2025 7:02 pm    Post subject: Re: My newest 66 Reply with quote
Got some work done on the Bug after work today.
New glove box installed
New firewall seal installed. Needs a little finessing
New running boards. The others I installed, despite being the expensive reproductions, fit like crap. So, at the suggestion of a friend, I ordered the billet black ones. They are very nice. And look great, and more importantly, fit.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Thu Nov 06, 2025 4:42 pm    Post subject: Re: My newest 66 Reply with quote
Did a little to the Bug today.
Measured the deck height
I ordered a retro sound radio for it, and these speakers and this ugly plywood shelf had to go
Really need to get the new headliner and interior installed. The old stuff looks awful.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Fri Nov 07, 2025 8:03 pm    Post subject: Re: My newest 66 Reply with quote
Worked on the car for about an hour today.
Installed some 3 way 6x9s
Radio comes next week.
Didn’t want to reuse the ugly fuel metal line, so I made a new one out of stainless steel.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Yesterday 1:16 pm    Post subject: Re: My newest 66 Reply with quote
Well, the radio came.
My Patina 66
My 74 Ghia
07 Boxster
swhitcomb
PostPosted: Yesterday 1:36 pm    Post subject: Re: My newest 66 Reply with quote
So, I’ve changed directions a few times now, but I finally have it all locked in I think.
I sent an AH case and a set of 041 heads off to the machine shop a few weeks ago. Friend of mine talked me into buying a 74mm crank. I was going to put it in the original F case and build an 1800. However, the guy doing the machine work said I wouldn’t be happy with that combo because the 1300 heads would limit it. Makes sense to me. So, I dug into my parts closest and found the AH I’d bought almost 15 years ago. Never been line bored and standard thrust. Deep studded on number 3, 8mm studs from the factory, and case savered. Perfect to build something with. So, I will. An 1800. 74x88. Engle 100 cam. 041 heads
So that left me with what do I do about a flywheel now? The new crank is 8 doweled. Really didn’t want to 8 dowel the 6v flywheel. I came up with a solution. Well, rather a solution found me. A friend had a swing axle trans for a 67-68 he’d bought that was rebuilt and never installed in his project.
So, now I won’t have to clearance the 6v trans. The old trans needed to be rebuilt anyway, it popped out of gear and the snycro on 1st was a shot. Just waiting for it all the engine parts to get back from Joe over at eVWParts doing his magic to it. Hopefully I can have it all back together in time for a few shows next year.
My Patina 66
My 74 Ghia
07 Boxster
Page 3 of 4
