Looking for the best tires for my lowered ghia
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
ILoveModdingDasAuto
ILoveModdingDasAuto is offline
PostPosted: Wed Aug 20, 2025 1:00 pm    Post subject: Looking for the best tires for my lowered ghia Reply with quote
I will be lowering my 68 Ghia (balljoint front, swing axle rear) on 2.5" drop spindles and clicking the rear accordingly.
Using stock wheels (4.5") until I decide to get smart and get new ones. I don't want rubbing if possible, and I'd be fine rolling the fenders if I really need, I also don't want to go with super skinny tires because I want to be able to brake good and handle, etc. If anyone has idea that would be appreciated thanks!
Dfasty
Dfasty is offline
PostPosted: Sun Aug 24, 2025 6:38 am    Post subject: Re: Looking for the best tires for my lowered ghia Reply with quote
Real 914 wheels. 5.5 wide with et of 40 or 41
70 fastback automatic 06 invader
Rob Combs
Rob Combs is offline
PostPosted: Tue Nov 04, 2025 6:39 pm    Post subject: Re: Looking for the best tires for my lowered ghia Reply with quote
I use the Vredestein sprint classic in 155 SR15 on my 71, which is lowered by beam adjusters about 1.5 inches.
They work pretty well but I can lock them up if I panic brake.
If your spindles push your wheels out too far you might have clearance problems with that size.
Edit - just saw this post has been out there a while. Hope you got it resolved.
oprn
oprn is offline
PostPosted: Sat Nov 22, 2025 7:16 am    Post subject: Re: Looking for the best tires for my lowered ghia Reply with quote
If you lower a swing axle very much you will want motorcycle tires on the rear. They are designed with tread up the sidewall where you will be running. Standard car tires should not be run that way.
Bruce
Bruce is offline
PostPosted: Sat Nov 22, 2025 3:07 pm    Post subject: Re: Looking for the best tires for my lowered ghia Reply with quote
Pictures or it never happened.
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
