Steering Column Shroud
gdtrfb1995
gdtrfb1995 is offline
PostPosted: Sun Sep 21, 2025 2:47 pm    Post subject: Steering Column Shroud Reply with quote
I have a 1978 Thing (made in Mexico) that has a bad ignition switch. I have the steering wheel off, but I can not get the plastic shroud off from around the steering column. This is a single piece shroud and all I can find online refers to a 2 piece shroud. Any suggestions?
el_safari
el_safari is offline
PostPosted: Fri Sep 26, 2025 1:07 am    Post subject: Re: Steering Column Shroud Reply with quote
Hi
Yes, it's been made of plastic since mid-1974.
Sometimes it melts a little in the heat and shrinks, slip downwards.
Cool
La terre n'est qu'un seul pays
71/72KGER Premium Member
71/72KGER is offline
PostPosted: Tue Sep 30, 2025 6:12 pm    Post subject: Re: Steering Column Shroud Reply with quote
I just got a 74 Thing and I'm looking for one.
I have learned that the 73's are metal and starting in 74 they went to plastic re: The Thing Shop, they do not have them and I'm having a hard time finding one.
I'm no help in the disassembly area but I would just advise to go slow as to not break it.
Good luck and please post your findings.
71/72KGER aka Chris
73 Thing
71 Karmann Ghia Vert
71 Super Beetle Vert
wbailey2112
wbailey2112 is offline
PostPosted: Wed Oct 01, 2025 8:25 am    Post subject: Re: Steering Column Shroud Reply with quote
Check the classified ads here and if there are none for sale contact Mike at http://www.thingparts.com
'74 Thing
'83 Westfalia
el_safari
PostPosted: Wed Oct 01, 2025 1:39 pm    Post subject: Re: Steering Column Shroud Reply with quote
partnumber: 113 953 515
also used on Porsche 924...
PostPosted: Wed Oct 01, 2025 4:06 pm    Post subject: Re: Steering Column Shroud Reply with quote
This is the part that I'm looking for and I've looked in the Classifieds and no luck.
I found it at Bug City see below I've never worked with them before.
When I emailed them about this part they were very responsive.
I cannot add this part to the cart so it must not be available.
I called today but it just rang but I'll try again tomorrow.
It's always the small little parts that drive you to distraction.
Chris
Sort by:
Name - Ascending
Ignition Switch, Key Surround Plastic Cover, w/ 2x Lock Tabs, SB 74-79, Used German Aka 477953517
Item#: 113905650S
Used to complete assembly of 113905851PC of housing # 113905851A
View More...
Price: $46.95
73 Thing
74 Thing
74 Thing is offline
PostPosted: Wed Oct 01, 2025 6:00 pm    Post subject: Re: Steering Column Shroud Reply with quote
I'd get in touch with Mike Basso at Thingparts.com to see if he had what you were looking for
https://www.thingparts.com/search.php?search_query=steering&x=0&y=0
Some info in here on removal
http://www.vw-resource.com/ignition_switch_replacement.html#ignition
PostPosted: Wed Oct 01, 2025 6:54 pm    Post subject: Re: Steering Column Shroud Reply with quote
I finally was able to purchase the parts by doing a Google search that lead to a post on this site that had a link to Bug City that worked.
Very odd but it worked.
Thanks for the link to the page for the install directions.
71/71KGER aka Chris
73 Thing
