Dash grille for tach/gauges?
cdennisg
cdennisg is offline
PostPosted: Sat Oct 11, 2025 10:21 pm    Post subject: Dash grille for tach/gauges? Reply with quote
I picked up this dash grille from a parts stash almost a year ago, and just now I realized it might be a little different. Looking at the various pics of Moto Meter gauges and grilles, I see one slight difference. Check out the bottom left three slots on mine compared to others. Any ideas? Is this grille meant for a different brand, or was it just a different production run?
VDO?
Moto Meter? Can't see the left side slots in this pic.
Mine, with embossed edge around the circular opening, and thicker on the right border...
70bus Premium Member
70bus is offline
PostPosted: Sun Oct 12, 2025 6:15 pm    Post subject: Re: Dash grille for tach/gauges? Reply with quote
For a 3-in-1.
Single gauge
What size is your hole?
Looks like they made a bunch - IF the panels came w/ those gauges.
Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater
cdennisg
cdennisg is offline
PostPosted: Sun Oct 12, 2025 7:34 pm    Post subject: Re: Dash grille for tach/gauges? Reply with quote
ID of the hole is approximately 60mm. The embossed ridge is about 1.5-2mm wide so that diameter is around 64mm.
70bus is offline
PostPosted: Tue Oct 14, 2025 10:15 am    Post subject: Re: Dash grille for tach/gauges? Reply with quote
I happened to be looking at gauges too - I think the first pic I posted must be another manufacturer, or maybe very late in production... most of the ones that say 'original' have the first three slots increasing in size rapidly. Exponentially vs. logarithmically? Dunno, I failed statistics.
Another one with the slots rapidly increasing height.
EDIT - looking at slots, a lot of these look like if you flipped them the slots are 'correct.' I wonder if someone made a backwards mold, either at a competitor to avoid litigation, or just a tired stamper maker at Motometer?
I'd PM someone with lots of collectible knowledge like restojohnny and see what they say.
Craig K
70 Neunsitzer
65 Pritschenwagen
Bub
Bub is offline
PostPosted: Fri Oct 17, 2025 9:00 am    Post subject: Re: Dash grille for tach/gauges? Reply with quote
They also made them with no consideration for aesthetics at all! No contour in the slots at all.
Laughing
hitest wrote:
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was...
56Cabrio
56Cabrio is offline
PostPosted: Fri Oct 17, 2025 9:28 am    Post subject: Re: Dash grille for tach/gauges? Reply with quote
Here are what Grumpys has for sale.
https://grumpysmetal.com/catalogsearch/result/?q=bezel
F#CK CANCER
Make a donation
1956 Rag Top owned since 1988
1963 Hard Top
RIP Dad 4/20/1951 - 2/4/2023
70bus is offline
PostPosted: Fri Oct 17, 2025 10:42 am    Post subject: Re: Dash grille for tach/gauges? Reply with quote
This one says it is VDO for reference so yours is not likely VDO...
https://www.thesamba.com/vw/classifieds/detail.php?id=2730777
Craig K
70 Neunsitzer
65 Pritschenwagen
