kevinm Samba Member
Joined: September 08, 2008 Posts: 133 Location: Minneapolis, MN
Posted: Wed Nov 05, 2025 8:58 pm Post subject: OEM Shift Rod Boot: Drain holes? |
I was working on the shift linkage and noticed that the factory shift rod boot (020301261A) has tiny drain holes at the peaks of the shift bellows. I never noticed this before and don't believe the aftermarket parts have this feature.
Here's the factory part:
Note the holes in the bellows. Do you think these are intended to drain water, or instead is it an acknowledgement that the selector shaft seal eventually leaks oil?
_________________ 90 Syncro Westy, "Ludwig" |
Sodo Samba Member
Joined: July 06, 2007 Posts: 10831 Location: Western WA
Posted: Thu Nov 06, 2025 7:01 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
Interesting observation.
Perhaps Air holes?
This boot would reflate / unflate when you move the shifter left/right real fast in the neutral area of your shift pattern.
Keep in mind some fellers can be “rather energetic” when shifting.
Going from reverse to 1st “real fast” with a couple extra dunka-dunks.
You know the type.
It could just “pull off” the boot - if unable to re-flate.
Never know what kinda funky thing some feller gonna do with his shifter boot.
( feasible….. but written as an “Ode to Duncan” ) _________________
....KTMs, GasGas, SPOT mtb
E1 Samba Member
Joined: January 21, 2013 Posts: 8752 Location: Westfalia, Earth
Posted: Thu Nov 06, 2025 7:06 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
Inflate-deflate makes sense, especially if a cheaper rubber blend that’s prone to cracking.
Or maybe the holes are to get lube in there, though am unsure of orientation… which way’s up? _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19084 Location: Retired South Florida
Posted: Thu Nov 06, 2025 8:42 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
| Holes down. Pressure equalizing makes the most sense. The shift shaft seal would have to be completely worn out for it to leak. I doubt the engineers designed a boot with a lube letter outer for a failure well beyond the warranty distance. |
E1 Samba Member
Posted: Thu Nov 06, 2025 9:20 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
Thanks Mark.  _________________ If ever twice as rich, we’re gettin’ a double-wide
zerotofifty Samba Member
Posted: Thu Nov 06, 2025 9:25 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
Yes, water drain holes. That is why there is a hole at each low point assuming you orientate the holes down. If for air only, then the holes would not need placed on each low point. Their location indicates water drainage was a consideration. Point the holes down. Of course water drain holes will also serve for air venting, but for air venting, the holes need not be at each low point.
Dual function. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
Sodo Samba Member
Posted: Thu Nov 06, 2025 11:18 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
At the bottom is the most logical location to clear.
90wt oil would plug the holes (for air) on cold days.
They are likely for both air and oil.
I suspect kevinm is making the connection to water pumps
which almost always have weep holes to inform you that the bearing is getting wobbly and a new waterpump should be planned. _________________
....KTMs, GasGas, SPOT mtb |
Sodo Samba Member
Posted: Fri Nov 07, 2025 8:58 am Post subject: Re: OEM Shift Rod Boot: Drain holes? |
| Sodo wrote: |
| Never know what kinda funky thing some feller gonna do with his shifter boot. |
thats 020301261A stretched over a CNC shifter cup.
A custom shifter cup with no drain hole BTW….  _________________
Van den Broke Samba Member
Joined: May 20, 2012 Posts: 237 Location: Victoria, Canada
Posted: Sat Nov 08, 2025 8:27 pm Post subject: Re: OEM Shift Rod Boot: Drain holes? |
| The shifter rod boot on my old Ford Escort has similar holes in it, so I think this is standard engineering practice. |
Posted: Sat Nov 08, 2025 9:01 pm Post subject: Re: OEM Shift Rod Boot: Drain holes? |
| Van den Broke wrote: |
Engine Ear Ring. I think I will get some for my engine  _________________ Sorry About That Chief.
Words to live by. |
