Dan_Lockwood Samba Member
Joined: October 03, 2023 Posts: 469 Location: Clare MI
Posted: Mon Nov 10, 2025 11:19 am Post subject: Body Pan Swaps??? |
I know this is a bit earlier than this forum, but I've seen a '57 Beetle for sale that seems to be savable without a ton of money. But the drive line/pan is shot.
My question is this, can the '57 body be bolted to any swing axle Beetle, say '67 back to '57?
Thanks in advance, Dan |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1890 Location: Warren, PA
Posted: Mon Nov 10, 2025 11:30 am Post subject: Re: Body Pan Swaps??? |
You can even put it on an IRS pan by just relocating the rear body mounts. But check your states laws concerning VIN’s my advice would be to only buy the car AND the replacement pan if they each have a valid title. Yes two titles one car, just title it on the cars VIN, but have the valid title for the pan to avoid any issues with proving legal ownership. I’m doing exactly this plan for a 56. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion |
56Cabrio Samba Member
Joined: May 22, 2008 Posts: 2078 Location: San Fernando Valley, CA
Bobs67vwagen Samba Member
Joined: March 27, 2005 Posts: 855 Location: Eastern north carolina
Posted: Mon Nov 10, 2025 3:38 pm Post subject: Re: Body Pan Swaps??? |
| The pan mount change was for the 69 and newer IRS pans where the rear mount is about 1 to 1.5 inches higher so the early body rear mount has to be cut and raised. I agree with pandora to get titles to both vehicles. I am doing this as I jhave a refurbished 74 pan that I will be putting my 67 body on so I can continue to use it while I restore the 67 pan and convert it to IRS. I also years ago put a 56 sunroof body on a 69 pan. |
Posted: Tue Nov 11, 2025 4:38 am Post subject: Re: Body Pan Swaps??? |
| I just wanted to add that 1968 auto stick cars were also on an IRS pan. They did not have a tube for the clutch however so that would be a challenge if using that pan. |
