Calibrating stock speedo?
MTT3107
MTT3107 is offline
PostPosted: Mon Nov 10, 2025 6:10 pm    Post subject: Calibrating stock speedo? Reply with quote
Is there a way to (re)calibrate/adjust the stock speedometer ?
My regular 205/70R15 tires were rubbing on the fenders, after I adjusted the beam on my bug to the ride height I liked.
I did not want to go to a narrowed beam, so I switched to smaller and lower profile tires, 195/60R15.
This solved the rubbing problem, but, on the other hand, made the Speedo very optimistic…. Smile Smile
70mph on my phone’s GPS speedo will show almost 80 mph on the car speedo.
glutamodo Premium Member
The Android
glutamodo is offline
PostPosted: Tue Nov 11, 2025 12:21 am    Post subject: Re: Calibrating stock speedo? Reply with quote
There is no magic dial you can turn or anything like that.
The speedometer works by magnetic inductance and calibration is dependent on the tension of the return spring. (the odometer, on the other hand, is a counter of wheel revolutions and is keyed to a specific tire circumference.)
You can try to remove the speedometer needle and repositioning it, or the carrier it fits onto, to a different spot on the center spindle. But this will be hit or miss as to the results you might get. And you might break the needle.
By the mid 70s VDO was printing an alignment mark for intended pretension point of the speedometer needle, you have to pull the needle over the stop peg as in this photo. You can see the needle is pointing at it.
Andy T.
MTT3107
MTT3107 is offline
PostPosted: Tue Nov 11, 2025 4:12 am    Post subject: Re: Calibrating stock speedo? Reply with quote
Thanks for that info, I will check my speedo.
The Android
PostPosted: Tue Nov 11, 2025 4:55 am    Post subject: Re: Calibrating stock speedo? Reply with quote
I didn't even get into how to take the speedometer apart, the glass will at least have to come off. Speedometers made up through model year 1971 are built a bit better than the 72-up one in the example photo. Which was part of this thread:
https://www.thesamba.com/vw/forum/viewtopic.php?t=179776
and another one of a mid 60s speedometer where I totally dismantle it
https://www.thesamba.com/vw/forum/viewtopic.php?t=327535
Andy T.
72Pstroke
72Pstroke is offline
PostPosted: Tue Nov 11, 2025 7:20 am    Post subject: Re: Calibrating stock speedo? Reply with quote
I am not sure of the years, but VW used 90 mph speedos and 100 mph speedos.
You can put a 90 mph face on a 100 mph speedo, and vise versa.
You can achieve a 10% correction by doing this.
The odometer will still be wrong though.
bugger-off
bugger-off is offline
PostPosted: Tue Nov 11, 2025 9:00 am    Post subject: Re: Calibrating stock speedo? Reply with quote
I went to a 185/55R15 so I could fit one in the spare well.
Simple and easy, this is what I did...
MTT3107
MTT3107 is offline
PostPosted: Tue Nov 11, 2025 12:35 pm    Post subject: Re: Calibrating stock speedo? Reply with quote
I already had that speedo apart, cleaned it, replaced the gels, etc.
YouTube is your friend…. Very Happy
Almost everything which one doesn’t know how to do, has already be done and documented by somebody else…
MTT3107
MTT3107 is offline
PostPosted: Tue Nov 11, 2025 12:39 pm    Post subject: Re: Calibrating stock speedo? Reply with quote
@bugger-off :
Simple and easy, yes….
But I couldn’t live with that…
I’d rather keep my overly optimistic speedo as it is, and go by the gps speedo on my phone.
bugger-off
PostPosted: Tue Nov 11, 2025 12:49 pm    Post subject: Re: Calibrating stock speedo? Reply with quote
MTT3107 wrote:
@bugger-off :
Yeah, I get it. You may find that as you get older, the "little" stuff isn't as important and doesn't bug you quite as much*. A few years ago, those little MPH labels I stuck on my clock would be totally unacceptable. Now I'm just happy to have another day to drive it.
*But don't get me started on my fuel gauge! Laughing
bsairhead
bsairhead is offline
PostPosted: Tue Nov 11, 2025 2:11 pm    Post subject: Re: Calibrating stock speedo? Reply with quote
Had a "Baja" in high school, 1978. My bud in front in his dads Lincoln on the C.B. me in the bug with my ch.14 walkie talkie. Him calling out 25 me saying a # and my girlfriend making note. So I had black grease pen marks at 25, 45, 60 on my speedo. Worked for me.
viiking
viiking is offline
PostPosted: Tue Nov 11, 2025 3:05 pm    Post subject: Re: Calibrating stock speedo? Reply with quote
So here's a little side question that I have been wanting to answer for a while.
Does a kmh speedo face read correctly when a mph face is exchanged and vice versa. It looks like the 80kph lines up with 50mph, 60 with 100.
I have an original speedo in mph and Australia went metric in 1974. To avoid using the "ugly" stickers to do the conversion, can I just source an original kmh face and just change it? I mean was there any physical difference (nut holes etc)between the two. My gut says that there are none, but has anyone actually done it?
hulbyw
hulbyw is offline
PostPosted: Wed Nov 12, 2025 3:42 am    Post subject: Re: Calibrating stock speedo? Reply with quote
Local instrument specialist offered to re calibrate my speedo. I didn't get him to do it however he told me it involved disconnecting the cable from my speedo and he would then connect a device that he had to measure the number of turns of the cable over a measured distance of a mile. Once he had the data he could re calibrate. The cost was around $150 Australian dollars.
MTT3107
MTT3107 is offline
PostPosted: Wed Nov 12, 2025 7:05 am    Post subject: Re: Calibrating stock speedo? Reply with quote
You don't need a "device" for that...
Simple mathematics will do it...
Example :
The front tires on my bug right now are 195/60R15
The 195 is the tires width in mm, 195 mm
The 60 means that the shoulder height of the tire is 60% of the width or 117mm.
Multiply by 2, and add the rim diameter, 15 in, or 381 mm
Wheel (rim + tire) diameter : 615 mm, or 24.12 in
wheel circumference : diameter x Pi = 24.12 x Pi = 75.77 in
63360" in a mile :
That wheel ( and the speedo cable) will turn 63360/75.77 = 836 times over the course of 1 mile
bugger-off
PostPosted: Wed Nov 12, 2025 7:13 am    Post subject: Re: Calibrating stock speedo? Reply with quote
So, simple mathematics aside, I thought you wanted your clock to display the correct MPGs.
vamram Premium Member
vamram is offline
PostPosted: Wed Nov 12, 2025 7:24 am    Post subject: Re: Calibrating stock speedo? Reply with quote
Example :
Multiply by 2 , and add the rim diameter, 15 in, or 381 mm
63360" in a mile :
When I retire (sooner than later at this age) i'm going to take a remedial math class for seniors....!!
I totally don't get where these numbers come from:
Multiply by 2 (multiply WHAT by 2...??), and add the rim diameter, 15 in, or 381 mm
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
bugger-off
PostPosted: Wed Nov 12, 2025 7:44 am    Post subject: Re: Calibrating stock speedo? Reply with quote
I didn't even read that. I use https://tiresize.com/calculator/ for all of my tire computations.
MTT3107
MTT3107 is offline
PostPosted: Wed Nov 12, 2025 10:35 am    Post subject: Re: Calibrating stock speedo? Reply with quote
That is the way to determine the diameter of the rim/tire combo..
Like I explained, the dimension of the shoulder of the tire is determined by the tire dimension, in my case 195/60R15..
the shoulder dimension of the tire is 60% of the tires width, 195 mm in this case, so the shoulder height is 195x0.6= 117mm.
That value that is multiplied by 2, an added to the diameter of the rim, 381mm, which the gives you the dimeter of the rim/tire combo, 615mm in this case.
Not rocket science...
MTT3107
MTT3107 is offline
PostPosted: Wed Nov 12, 2025 10:37 am    Post subject: Re: Calibrating stock speedo? Reply with quote
That calculator does exactly the calculations I explained.
pondoras box
pondoras box is offline
PostPosted: Wed Nov 12, 2025 10:57 am    Post subject: Re: Calibrating stock speedo? Reply with quote
Damn mathletes!
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop (Arschloch)
1973 standard bug (Dirty Gertie)
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
vamram is offline
PostPosted: Wed Nov 12, 2025 11:18 am    Post subject: Re: Calibrating stock speedo? Reply with quote
Like I said, I'm in line for a senior math refresher. Dancing
Click to view image
Save the Supers!!
