Scandell Samba Member
Joined: April 02, 2007 Posts: 251 Location: Redondo Beach, CA
Posted: Wed May 23, 2007 9:53 pm Post subject: Front Window Frame HELL Restoration |
Did you restore your front window frames? WHAT A PROCESS! YIKES! I am going to have them sanded and repainted... but I have a few questions:
I have read and reread all available info of the forum about this subject...
1. How do I remove the riveted latches in pics 4 and 5?
2. How many pieces does the window frame disassemble to? (It kinda looks like another piece is supposed to come out of the vent location of the frame.)
3 How in the world do you slide the surrounding vent window rubber in?
4. I noticed that their are two movebale screw points on each side of the window frame(Picture 2)...won't new paint fuse them stuck??
5. Am I supposed to slide rubber up that shaft in picture 3?
Moderator note:
Here are a few links to a vent wing press tool inside other Bus restoration or other threads:
https://www.thesamba.com/vw/forum/viewtopic.php?p=4566733#4566733
https://www.thesamba.com/vw/forum/viewtopic.php?p=8031551#8031551
https://www.thesamba.com/vw/forum/viewtopic.php?p=7737787#7737787
A user also posted a video here in this post:
https://www.thesamba.com/vw/forum/viewtopic.php?p=10006283#10006283 _________________ "Come on over...and we can work on it together."
the.fordhams Samba Member
Joined: February 11, 2004 Posts: 483 Location: Charlotte, NC
Posted: Thu May 24, 2007 3:33 am Post subject: |
Just done mine so I can give my view on some of the processes;
1. did not do mine,
2. looks like you have all the pieces apart and accounted for - except maybe the vertical bar between the sliding windows or is that laying on the horizontal part? anyway make sure the tabs are on top and bottom of this vertical piece
3. start at the bottom near the pivot and carefully tuck each edge in with a blunt flat blade screwdriver. I started with one side and then used the screwdriver to tuck in the other. No sliding.
4. they will but they'll free off again. Use a tap and I'm sure the process of cleanign the threads will free off the trapped nut plate.
5. Again just tucks in with a screwdriver - I was confused which way round this goes but I'm sure its with the blades towards the glass if that makes sense.
The hardest thing for me was sliding that damn long piece around the outside of the frame - I used plenty of silicone spray and then carefully pushed and pulled around the tight bend with a pair of pliers.
Good luck,
Al _________________ 63 OG Turkis Bug Patina air ride
65 OG Safari Beige Notch project
65 OG Pearl White SO42 Patina
67 SO42 project
03 Eurovan Weekender
08 Touareg 2 V6
WANTED :
Bob King VW dealer Wilmington NC dealer tag surround and any Literature for 03 Weekender |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9016 Location: Portland, OR
Posted: Thu May 24, 2007 1:55 pm Post subject: |
I disassembled ours for blasting and here is my experience.
I left the vent wing latch base in place as it was not broken. Also left the lock tab in place and just duct taped it off for blasting. If they need to be removed, you need to grind the head off the rivet.
The paint won't freeze anything into place so badly that it can't be moved again.
That little wind deflector piece is supposed to be gray when you are all done with painting and reassembling.
Use Windex to assist with getting the seals to slide in the channels. |
Posted: Thu May 24, 2007 5:31 pm Post subject: |
| Major Woody wrote: |
That little wind deflector piece is supposed to be gray when you are all done with painting and reassembling |
Wind Deflector piece? _________________ "Come on over...and we can work on it together." |
Posted: Thu May 24, 2007 6:25 pm Post subject: |
The little curved piece that goes in the bottom corner of the vent window. I too did not remove my latch or latch plate and had mine blasted and painted. Just mask off with some good stuff.
Did the wind deflector come in chrome for deluxes or was it grey or body color?
67 SO42 project
08 Touareg 2 V6
WANTED :
Posted: Thu May 24, 2007 7:39 pm Post subject: |
| I don't know and I should have been clearer that it would be gray for a commercial family vehicle. I saw that the vent pivot latch base was black and that it was a late deflector and just reacted with "that one should be gray" |
Posted: Wed Sep 19, 2007 9:32 am Post subject: An Update |
1 Down...1 to go.
Kevin T Samba Member
Joined: February 06, 2006 Posts: 123 Location: Sandwich Islands
Posted: Wed Sep 19, 2007 9:49 am Post subject: |
| Lookin good! what did you use for paint? |
BarryL  Samba Member
Joined: November 01, 2004 Posts: 15449 Location: Casa de Oro, California
Posted: Wed Sep 19, 2007 9:57 am Post subject: |
| Some deflectors are bare aluminum. Don't know when that occurred. |
lurkinstock Samba Member
Joined: September 04, 2006 Posts: 420 Location: n. ga.
Posted: Wed Sep 19, 2007 10:11 am Post subject: Re: An Update |
| Scandell wrote: |
1 Down...1 to go.
Scandell, those look awesome! Can you describe the process you used? Did you have to trim in any spots? You make me want to do mine real soon!! _________________ " Southern Comfort Vintage Volks "
**The Grand Ole Dubs of the South**
52 split
59 single cab |
Posted: Wed Sep 19, 2007 10:17 am Post subject: |
That looks good.
When you clamp them back into the door, you will need to notch the bead side of the base seal where the angle changes near the center post, on the inside. Glue the butt ends of the "bead" together with 3M Weatherstrip Adhesive (the HD black stuff not the gorilla snot) and then use tape to hold them onto the door while you're installing the door frame into the door or they'll be pulled apart. Use K-Y Jelly to help the frame slip in. Pull the tape out at the last minute.
Once you get it into the door, you'll need to clamp the door frame to the door in order to suck it down tight onto the base seal. I used several gigantic bar clamps and started with the back edge of the door. When you get to the front, you won't be able to use the bar clamp becuase of the angle of the door frame. At that point you could use a vice grip quick grip bar clamp between the vent window opening (move the seal out of the way temporarily to avoid damaging it) to hold it in place tightly while you install and secure the 4 bolts that hold the front portion of the frame into the door.
Don't tighten the two nuts under the sliding door run channel until last. If you try to use them to pull the frame down, you run the risk of tweaking the run channel.
Before you install the door frame, run a tap through all your threads to get the paint and rust out, and use anti-seize.
There is another thread here with instructions on properly mashing the vent window rivet (use a steel ball bearing and a pair of vice-grips with the jaws ground flat/smooth). Following those instructions, I was able to get my vent window rivet installed perfectly.
Wait to finally tighten the vent window pivot nut until after you have installed the vent window rivet. Leave it loose. |
Riff Raff Shivering Sambian
Joined: October 25, 2004 Posts: 3097 Location: Alberta
Posted: Wed Sep 19, 2007 10:33 am Post subject: |
| the.fordhams wrote: |
Al |
The wind deflectors (I call them Nike swooshes) are painted upper body colour on my 60 Mango Standard and 61 SWR/BG de Luxe. _________________ The greatest obstacle to discovery is not ignorance, but the illusion of knowledge
- Daniel Boorstin |
Posted: Wed Sep 19, 2007 10:36 am Post subject: |
That looks good.
When you clamp them back into the door, you will need to notch the bead side of the base seal where the angle changes near the center post, on the inside. Glue the butt ends of the "bead" together with 3M Weatherstrip Adhesive |
What do you mean "notch the bead side"?
Also...what are the two flappy parts on each end of the base seal for? _________________ "Come on over...and we can work on it together." |
Posted: Wed Sep 19, 2007 10:47 am Post subject: |
Process: (I'll go into more detail later")
1. Dismantle ONE of your frames. (Use the other as a constructed reference)
2. SandBlast all 5 main parts (Removed latch and latch plate with drill)
3. Lightly Sand then Spray some self-etching primer on the bare metal.
4. Bought some white-blue paintscratch.com spray cans... ($90 bucks & a 3 week fiasco)
5. Spray Painted all parts
6. Sprayed a light clearcoat on top...just because the SS paint I bought wasn't quite shiny enough. ($5 Clear coat from Pep Boys)
7. Riveted a WW new latch and latch plate. (Non-Stock Stainless Steal Pop Rivets. yikes. lol (Rivet Gun and Rivets $25))
8. Installed WW rubber and felt kit. ($90 per frame )(Very Easy to do...took 30 minutes)
9. Placed Windows back in...screw long latch plate and bottom main part in place.
STILL TO DO:
10. Install Vent Glass and Seal.
11. Install Vent Wing Window...
12. Install Onto Bus.
THEN DO IT AGAIN! _________________ "Come on over...and we can work on it together." |
jazzed Samba Member
Joined: August 03, 2002 Posts: 630 Location: Eugene, OR
Posted: Wed Sep 19, 2007 12:20 pm Post subject: |
You'll have fun with 10 and 11, trust me  |
Posted: Wed Sep 19, 2007 1:25 pm Post subject: |
| Scandell wrote: |
That looks good.
Also...what are the two flappy parts on each end of the base seal for? |
The inside (side facing the interior of the bus) of the base seal is raised and rounded, like a rounded bead. It will bunch up on the inside where the angle of the door changes. You have to cut some out, right where you already cut a hole for the center post of the frame to go down inside the door.
I don't know what flappy parts you're referring to. Mine was just one continuous extrusion--WCM material I got from CIP1. |
zozo Samba Member
Joined: October 15, 2005 Posts: 5216 Location: South of Ol' San Antonio
Posted: Wed Sep 19, 2007 3:28 pm Post subject: |
| jazzed wrote: |
Amen to that! A PITA of biblical proportions. |
Posted: Wed Sep 19, 2007 5:06 pm Post subject: |
| zozohead wrote: |
| jazzed wrote: |
Anything can be accomplished with enough lube.  |
Posted: Thu Sep 20, 2007 12:15 am Post subject: |
I got my rubber from WW...and the base trim doesn't need any holes to be cut out. The center hole is already cut. FYI _________________ "Come on over...and we can work on it together." |
Stocknazi Samba Member
Posted: Thu Sep 20, 2007 10:25 am Post subject: |
| BarryL wrote: |
i think that was a 67 thing. my 67 deluxe has the alumimum deflectors, it's an early 67 _________________ WANTED:
Thomas Jefferson |
