auslander Samba Member
Joined: January 07, 2003 Posts: 1831 Location: Heart Of Dixie
Posted: Wed Aug 04, 2004 10:16 am Post subject: 1914 Build/ Need some opions |
I have a couple of questions : 1.Do you check the CC of each side of the head, if the cc's are different would you run a different shim to get the cr the same on each side?
2.What is the highest cr you can run on pump gas?
3.Is 9.5 cr to much for a motor that will be driven as semi daily driver that will go to the strip occasionaly
4.When you have chromoly pushrods do you set them up just like regular ones?
I bought nothing but quality parts and I want this motor to be built as close to perfect as possible, so im in no hurry to build it. I've read of people mocking up the motor without any sealants, is that just to check it for clearance? The set up for my 1914 motor is:
69 DPR crank
94 cylinders and pistons
web 110 284º 256º 0,435" 11,05 108º/ web lifters
straight cut steel/steel gears
Scat 1.25 ratio rockers/ chromolly pushrods
040 heads with 35x32 /50.6cc, dual springs, 3 angle valve job, manley valves, dual springs
12.5 flywheel
stock rods
kennedy stage 2 pressure plate, daiken heavy duty disc
As for the carbs I have the 46IDK Kadron kit and a set of 40 Dellortos I will try them both but do need jetting recommendations for the Dellortos
everything has been balanced _________________ Zombie
Wandering...Have you found what your looking for?
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
Time's Tide will Smother You
"You can't throw a rock in Long Beach without hitting a tweaker" Steve Tucci |
DanLarson Samba Member
Joined: February 20, 2004 Posts: 128 Location: RTP, NC
Posted: Wed Aug 04, 2004 10:33 pm Post subject: Re: 1914 Build/ Need some opions |
Quote: |
1.Do you check the CC of each side of the head, if the cc's are different would you run a different shim to get the cr the same on each side? |
If they don't match, you need to have them machined to match
Quote: |
2.What is the highest cr you can run on pump gas? |
That's a big debate.
Quote: |
3.Is 9.5 cr to much for a motor that will be driven as semi daily driver that will go to the strip occasionaly |
9.5 might be ok with that cam. I've run 9:1 with an Engle 110 and 1.25 rockers with no problems on 93 octane.
Quote: |
4.When you have chromoly pushrods do you set them up just like regular ones? |
Set chromoly's at 0, just enough to still rotate the pushrods by hand. |
nsracing Samba Member
Posted: Thu Aug 05, 2004 9:33 pm Post subject: 1915cc build up |
HI Fellows,
Hi Dan, How is the new engine build going?
The head choice is too small. Go bigger like 40mm x 35.5mm...at least. The 1915cc is pretty big.
The barrels are all the same. If the case is decked flat also, what would it do if you shim one of the barrels? Do you think you will have the head sit flat also? No sir.
Dan is right. You get the head chamber matched. Do not shim anything unless you shim them all the same.
If you were closer to Va, I can help out a little. Then again, I see machine work from California too.
Good luck. NSR |
Eric21 Samba Member
Posted: Sat Aug 07, 2004 10:40 am Post subject: 1914 |
in a answer to the cr qusetion 8.7 on pump gas for a air cooled is as high as i would go. I have a 1914 that is at 8.75 :1 and it screams I also run 104oct in it. |
a_67vdub Samba Member
Joined: April 06, 2003 Posts: 504 Location: Long Beach
Posted: Sat Aug 07, 2004 12:42 pm Post subject: Re: 1914 |
Eric21 wrote: |
It's completely dependant on the cam because different cams bleed different amounts of compression. |
Posted: Sat Aug 07, 2004 10:26 pm Post subject: |
Ive been thinking about the cr i want to run, and I'm going to go somewhere between 8.7 -9.1 range. I think I will be happy with it _________________ Zombie
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
philip1 Samba Member
Joined: March 11, 2004 Posts: 334 Location: wales, UK
Posted: Tue Aug 10, 2004 12:40 pm Post subject: |
wot u goin on bout eric? ive gt a m8 who runs a oval frm da monte carlo with a 1914, runnin bout 9.5 compression, 1.1 or 1.25 rockers, ported heads and i thnk a 120 cam! and its fine, but his doin mor head work, and a bigger cam
im 17 and buildin a 2007, h beam rods, fk10 cam, 1.4 rockers, 40x37.5 heads fully polishd ported, an 44's, and a 9.5 cr, then in feb/march goin for round port 42x37 with bit mor porting, still gna b daily driver, and mor than enuf go for killing da boy racers.
if the cars goin like mine, go for bout 8.7 - 9cr max
good luck tho |
kekonaiii Samba Member
Posted: Tue Aug 10, 2004 12:59 pm Post subject: Re: 1914 Build/ Need some opions |
[quote="auslander"]I have a couple of questions : 1.Do you check the CC of each side of the head, if the cc's are different would you run a different shim to get the cr the same on each side?
One thing to consider is the elevation you are at. What every you set the comp at California won't be the same in Colorado...It changes from sea level to mountain top...
Your heads should all match. Check them all unless you totally trust your machinist.
I ran 9.1 with 92 octane in a 1835cc that ran 13.6 in the 1/4 mile. But the octane and compression thing has be a debate for years.. Everyone has there own theory.. |
Posted: Tue Aug 10, 2004 1:55 pm Post subject: |
This is the first hipo motor that im building and have visualized the assembly, i know the heads were machined right but wasn't sure if i should check them myself, and wasn't sure if i should check each of the cylinders and pistons for the deck height to see if they were all the same, I think the highest i would go with the cam would be 9.1 compression. _________________ Zombie
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
Posted: Fri Aug 13, 2004 12:21 am Post subject: |
auslander wrote: |
This is the first hipo motor that im building and have visualized the assembly, i know the heads were machined right but wasn't sure if i should check them myself, and wasn't sure if i should check each of the cylinders and pistons for the deck height to see if they were all the same, I think the highest i would go with the cam would be 9.1 compression. |
I wouldn't push it more then that either. Now days the gas is not as good as it was back 20 years ago. If you are sure then go ahead BUT!!!! It only take a few minutes to CC the heads, time well spent.. |
Posted: Fri Aug 13, 2004 9:27 am Post subject: |
My heads are good, they were done by AJ Simms, and he recommended that I go with 9.1 compression and set the heads up to run it, then I got the 46 kit and he said that I could go as far as to run 9.5:1 compression. But i would rather be cautious then have a blown up motor and my money down the toilet. What problems do you see with my combo, and what suggestions do you have, let me know, thanks _________________ Zombie
66 POS Bus
69 Class 11 Beetle
71 Cat-Look Beetle
64 Old Skool Baja
74 "Swamp" Thing
!!! F**k Cancer !!!
