silverfox Samba Member
Joined: December 14, 2003 Posts: 57 Location: Singapore
Posted: Sun Aug 15, 2004 5:40 am Post subject: 356 gauges conversion |
Is there any way to convert a 57 mechanical Tach to a electrical one? |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76945 Location: Sneaking up behind you
Posted: Sun Aug 15, 2004 5:49 am Post subject: |
Only to replace the internals with a electronic unit keeping the original face and can. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Aug 15, 2004 7:59 am Post subject: |
Thanks. Know of any place that does? |
doveblue3 Samba Member
Posted: Sun Aug 15, 2004 3:54 pm Post subject: |
silverfox wrote: |
I believe pelican parts does it. Check their website, they talk about it on there. |
bathtub57 Samba Member
Joined: August 31, 2004 Posts: 155 Location: Ascot, UK
Posted: Tue Aug 31, 2004 8:40 am Post subject: |
I'd suggest North Hollwood Speedometer www.nhspeedometer.com
No affiliation etc etc
Mark
57A Coupe |
TC/TeamEvil Samba Member
Posted: Sat Sep 18, 2004 7:18 pm Post subject: |
I replaced my 356 tach mechanicals with those fom a 914. It's a very easy job, you can easily do it yourself. It's a straightforward conversion and the results are VERY nice. While everything's opened up it gives you the chance to clean the gauge face and repaint the pointer. It ends up looking like new!
Luck,
TC |
VW356fun Samba Member
Joined: December 06, 2004 Posts: 9 Location: Northern California
Posted: Tue Dec 07, 2004 6:37 pm Post subject: Electric Tach |
I know that Palo Alto Speedometer in Palo Alto, California sells a Electric Tach that looks just like the stock tachs that work with a cable. They show up on Ebay from time to time. |
myb356 Samba Member
Joined: October 14, 2004 Posts: 408 Location: bay area california
Posted: Sun Jan 16, 2005 10:17 pm Post subject: |
dude, the sweep of the 914 tach needle is different from the 356. The 356 reads 6k at about the same amount of sweep the 914 is at 7k. Is the 914 tach adjustable? I put 924 internals in my 356 tach. It is adjustable. I had to hook up another adjuster to slow it down enough to match the 356 dial. I put the adjusting knob on the outside for easy tuning. You could speed it up a bit and save you engine's life... Them things are expensive |
