KamperKitJay BDM Hit Man
Joined: May 13, 2003 Posts: 404 Location: San Diego CA.
vdubrida70 Samba Member
Joined: March 20, 2004 Posts: 391 Location: Whittier, CA
Posted: Tue Aug 17, 2004 12:11 am Post subject: |
sweet, save money because they are reuseable and seal better? it doesnt get much better than this. they are only $19 a steal |
Bugzlife Samba Member
Posted: Tue Aug 17, 2004 12:45 pm Post subject: |
and the oil sump plate gasket , Hmmmmm?
_________________ I'm looking for some rear wheels for my rail( 4lug), 8" wide up to 12" with or without tires, |
Zundfolge Samba Member
Joined: April 09, 2004 Posts: 87 Location: Pittsburgh, PA
Posted: Thu Aug 19, 2004 11:09 am Post subject: |
Has anyone tried these? _________________ 1971 Super Beetle
Eaallred Samba Member
Joined: May 18, 2003 Posts: 5756 Location: West Valley City, Utah
Posted: Thu Aug 19, 2004 1:38 pm Post subject: |
I've run rubber valve cover gaskets before, and they sealed great until the first time I took it down the track and it sucked a gasket in and downed the track with oil. Unlike cork, rubber gets REAL slick when it's oily.
I don't know if the silicone would have this same problem or not, but it would be something I would look out for. _________________ Eric Allred
You have to remember something: Everybody pities the weak; Jealousy you have to earn. |
Terry Cloyd Banned
Joined: March 23, 2004 Posts: 2218 Location: Valley Center "SO CAL"
Posted: Fri Aug 20, 2004 6:44 pm Post subject: |
Eaallred wrote: |
I don't know if the silicone would have this same problem or not, but it would be something I would look out for. |
Gentlemen: If you have sheet metal valve covers, use an awl and punch around the outside perimeter. This will hold cork, as well as rubber gaskets to the valve cover. It sounds like you definately have a breather problem. You need to open up the square area for breathing. Terry |
down and dirty Samba Member
Posted: Fri Aug 20, 2004 6:57 pm Post subject: |
Rubber valve cover gaskets arent new!! _________________ MOVED |
