dingo Banned
Joined: July 19, 2004 Posts: 429 Location: eugene, OR
Posted: Fri Sep 10, 2004 7:34 pm Post subject: Steering/ toe on '84 |
;84 Westy steers like a wobbly drunk...weaving. It sort of reminds me of an older Bus i had with badly adjusted toe-in. Also the right front tire is severly worn on the outside edge..i.e. the tire is literally being dragged.
Does this sound like toe-in needs to be measured and adjusted. Its been a while, so does anyone have suggestions on how to do this procedure ??
Thanks |
TeamSpatula Samba In The Rain
Posted: Sat Sep 11, 2004 9:13 am Post subject: |
Also check for play throughout the front end - including the steering and even wheel bearings. If something is loose and wobbly that will also cause those problems. Bentley has procedures for adjusting the front end - just check everything out while you have it up. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Randy in Maine Samba Member
Posted: Sat Sep 11, 2004 5:14 pm Post subject: |
I would take it to a front end shop to have it all done.
Dangerous like that. |
dingo Banned
Posted: Tue Sep 14, 2004 11:53 am Post subject: |
If i took it to a shop, i would learn NOTHING.
Now that i look at it from the front, it does not seem to be a toe-in issue...its more like the Van is 'listing' (like a ship) on that right front wheel .i.e. instead of the wheel being 90 degrees to the ground, the top part of the wheel is leaning out, and the bottom of tire is pushed in.
Would this be Camber or Caster or some other ?? and what would most likely cause this ?? |
