CJM722 Samba Member
Joined: November 24, 2002 Posts: 462 Location: Hamilton OH
Posted: Sun Sep 12, 2004 7:26 pm Post subject: aircooled vanagon 80' cold start issue |
when you go to start it.. you have to hold the gas for a long time before it idles on its own, the motor is all stock.. what could the problem be.. also, after running for a long time, if you go to start it it does the same thing. _________________ 70 Square
74 1303
74 Westy
88 Jetta GLI-- sold and wercked by the new owner |
Randy in Maine Samba Member
Posted: Mon Sep 13, 2004 3:42 am Post subject: |
What have you done so far?
Tune up?
Vac leak search?
Idle adjust?
Timing check?
Fuel pressure test?
Temp sensor II clean and tighten? |
CJM722 Samba Member
Posted: Mon Sep 13, 2004 7:15 am Post subject: |
none of that..
i need a bently on it i guess.. _________________ 70 Square
74 1303
74 Westy
Posted: Mon Sep 13, 2004 8:32 am Post subject: |
It could be your first order from the bus depot or where ever you go.
I use my Bentley all of the time.
Consider some new plugs, fuel/air/oil filters, points and condensor (if you use them), and ignition wires in with the order. I would be thinking about replacing those fuel lines if it hadn't been done in the last 3 years. MIght literally save the bus. |
TeamSpatula Samba In The Rain
Posted: Mon Sep 13, 2004 9:06 am Post subject: |
If nothing else, do a visual inspection of the engine compartment - look for loose wires or vacuum hoses, bad connections, etc. Often you can see something popped loose, or a cracked vacuum line or something like that. Wiggle connections & joints and make sure they're tight - sometimes a vacuum hose will be just loose enough to leak, but it will still look ok until you wiggle it. Good luck, _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Poor Realist Samba Member
Joined: August 25, 2003 Posts: 305 Location: Stockholm SWE
Posted: Mon Sep 13, 2004 5:18 pm Post subject: |
CJM722 wrote: |
none of that..
i need a bently on it i guess.. |
Look for the aircooled only version of the 80-83 Vanagon Bentley manual. You'll save about $70 by not buying the current version (80-91)
www.bookfinder.com -- ISBN 0837603536 |
