Vanagon w/ Air Cooled 2.0 Porsche - Pros & Cons?
Vespagetti
Vespagetti is offline
PostPosted: Sun Sep 26, 2004 10:03 pm    Post subject: Vanagon w/ Air Cooled 2.0 Porsche - Pros & Cons? Reply with quote
I have a chance to purchase a '83 Vanagon with a Porsche engine. It looks clean and it drives good but I have no idea what problems I may encounter in the future. The engine has 44k miles, the price is $2500. Thanks...
Tristar Eric
Tristar Eric is offline
PostPosted: Mon Sep 27, 2004 7:37 pm    Post subject: Reply with quote
snap it up! the engine is worth $2500...
Karl
Karl is offline
PostPosted: Mon Sep 27, 2004 8:23 pm    Post subject: Reply with quote
Yeah, right.... I love it when people call the 2.0 a Porsche engine.
The typeIV engine came out 1st in the VW 411/412. Then it was put in the VW/Porsche 914. In Europe it is a VW, here in the USA it is a Porsche.
The ONLY real 2.0 914 engine worth anything is the 73-76 GB engine.
It had 3 studs holding down the intake manifolds and 8.0 compression ratio [flat top pistons]. 100 hp
The Vanagon 2.0 is the CV engine. It, like all the 2.0 bus engines has 4 studs holding down each intake and 7.5 compression ratio [dished pistons].
76-79 bay 2.0 are 7.3 compression ratio and 67 hp.
http://www.tunacan.net/t4/reference/case.htm
Count the intake studs and find the case serial number beginning letters.
johnboy
johnboy is offline
PostPosted: Thu Sep 30, 2004 4:20 am    Post subject: Reply with quote
If you can't recognise a 6 cylinder 2.0 liter Porsche motor by sight, count the spark plug wires. Are there 6? Is there a big upright fan staring you in the face when you look at the motor? Does it have a sexy growl when you bring the revs up that could never be mistaken for the farty sound aircooled volksies make? If so, this could be a 1964 to 1969 911 motor. If this is the case buy it, the motor alone is worth it. If not, and the motor is a Volkswagen Type 4 motor, you have the right to poke the seller in his left eye for getting your hopes up. Now you don't say what flavor Vanagon you have there or what it's condition is. $2500 for a perfect Westfalia with a good Type 4 motor sound like a good deal to me. Maintainence is a snap on these motors and I happen to like the farty sound.
1980 Aircooled Westy
If not me then who, if not now then when?
