jberger Samba Member
Posted: Mon Oct 04, 2004 8:51 am Post subject: Where did you learn to whine like that? |
While my engine was out for a pesky oil leak I decided to swap tranny’s for my lower mileage spare. Put a new ball in the nose cone, new gaskets and seals all around, disassembled\cleaned\lubed the clutch fork... any who, its all back in now and this tranny whines pretty loud in 1st, 2nd, and 3rd. It doesn't grind or rattle just a loud gear whine, like a race car Any body else have a whiny tranny? |
Blaubus Samba Member
Posted: Mon Oct 04, 2004 9:01 am Post subject: |
i have seen that before, twice, almost always whines loudest in 1st and 2nd. |
Posted: Mon Oct 04, 2004 9:05 am Post subject: |
Good? Bad? Keep driving? |
ratwell Samba Member
Joined: April 26, 2003 Posts: 8717 Location: Victoria, BC
Posted: Mon Oct 04, 2004 9:18 am Post subject: |
Never drove the other bus. The current unit in my 79 was getting uncomfortably loud, so I figured I had nothing to loose putting in the other. The new one shifts nice and is smooth, just whines. While changing the gaskets I visually inspected the internals and found nothing obviously wrong with them. |
Posted: Mon Oct 04, 2004 9:39 am Post subject: |
There are so many shims, feeler gauge and backlash measurements during a rebuild I'm not sure if the noise can entirely be attributed to visibly worn gears. _________________ '78 Westfalia CDN
'76 Doublecab
Read the Baywindow FAQ |
Posted: Mon Oct 04, 2004 9:45 am Post subject: |
I agree, just wondered if gear whine is common in these transaxles. |
steve74baywin Samba Member
Joined: December 29, 2003 Posts: 452 Location: FL - Tampa
Posted: Mon Oct 04, 2004 10:15 am Post subject: |
This is a really obvious question, and judging by your post you seem to do good thorough work,,, But,,,,,How is the oil in the Tranny? Nice new clean synthetic gear oil? _________________ Steve |
Posted: Mon Oct 04, 2004 10:26 am Post subject: |
New gear lubricant 80w90 |
Posted: Mon Oct 04, 2004 11:20 am Post subject: |
jberger wrote: |
Only if they are worn. Mine has 70k and it's quiet. My buddy has 134k and his is very noisy in all gears. _________________ '78 Westfalia CDN
'76 Doublecab
DeathBus WILD MAN!
Joined: February 29, 2004 Posts: 4384 Location: Birmingham, Alabama
Posted: Mon Oct 04, 2004 2:42 pm Post subject: |
have a friend with a 77 tranny in a 72. The tranny set for awhile before he put it in. he changed the gear oil (which had turned the consistancy of molassis) and stuck it in. It would whine in 2nd and 3rd, so he drove it for 1k then changed the gear oil again. Once again it was real thick. He put new oil in and ran it for another 1k, the whine got quieter, but didnt go away, so he changed the oil again, now you can barely hear the whine. _________________ 65 Bus, 72 Bus, 63 bus, 98 Golf, 92 Cabrio, 71 Fasty
In the shop a 62 Bus and a 79 bus |
Posted: Mon Oct 04, 2004 2:46 pm Post subject: |
Sweet, I'll keep my fingers crossed as a reman unit is not in the budget. |
