jon lauzon Samba Member
Posted: Thu Oct 21, 2004 5:00 am Post subject: best carbs for1776cc square? |
i was just wondering what you all thought is the best choice for carbs on a 1776 in a square. ive had a couple of bad 34 webers. just didnt seem to work right. thanks for your input |
69sqbck Samba Member
Joined: August 12, 2004 Posts: 311 Location: Savannah, GA
Posted: Thu Oct 21, 2004 8:04 am Post subject: carbs |
Need some engine info: what cam; rockers; distributor etc... are you running. I am running dual weber 34 ict carbs on my 1776 square but had to re-jet them to get them right. |
Posted: Thu Oct 21, 2004 10:25 pm Post subject: |
i have not built the engine yet. but most likley it will be a stock cam, crank and heads. i just am getting every thing all together now. thanks |
Posted: Fri Oct 22, 2004 6:49 am Post subject: carbs |
Jon:
This is what I ended up doing to get the carbs running right on my 1776. Keep in mind that my engine setup is different than yours.
Finally, success!!! After a long and cold winter I have gotten around to jetting my dual 34ict's. I have seen many posts here about what size jets to run so here is what I found. 1776 engine, 041 heads (40 intake 35.5 exhaust valves, semi-hemi cut, 7.8 to 1 C/R, dual high rev springs, stock rockers, stock fuel pump, .009 distributor, engle 110 cam. I am running the stock F78 emulsion tubes, stock .50mm pump jets, stock .40mm pump exhaust valves, stock 1.75mm needle valve and stock 1.60mm air corrector jet. The changes are as follows: removed the stock .52mm idle jets and installed .55mm idle jets, removed the stock 1.30mm main jets and installed 1.40mm main jets. The car is driven at 1305 foot elevation. The improvement is very noticable, she runs like a champ now. No stumble through the entire power band. Hope this helps anyone having a problem with jetting. _________________ Don't think of yourself as an ugly person, think of yourself as a good looking Monkey!!!!!
1968 Ghia Vert
1969 Type 3 Squareback
1969 Type 3 Fastback
(o)\|/(o) Sole Designs, VW Restorations, Savannah, GA |
63SunNotch Samba Member
Joined: October 27, 2003 Posts: 118 Location: Riverside CA
Posted: Fri Oct 22, 2004 7:08 pm Post subject: |
I picked up some 40 dual webers from CB Performance with the short manifolds for type 3. I'm running a 1776 engine in my Notchback. _________________ Please PM me whatever you are smoking!
LadyVW wrote
Yes, my snatch wears a sweater and looks like a chihuahua. |
Posted: Sat Oct 23, 2004 10:28 pm Post subject: |
would i be able to put on 40 kadrons with short manifolds? i have these already, but set up for a bus. |
Bobnotch Samba Member
chillz1 Samba Member
Joined: August 03, 2002 Posts: 869 Location: Where You Least Expect
