Drag link Stuck!!! How i would remove it better?
novetti
novetti is offline
PostPosted: Sat Oct 23, 2004 9:31 am    Post subject: Drag link Stuck!!! How i would remove it better? Reply with quote
I'm removing my front beam assembly today from the bus.
I removed all the cables, transmission rod, etc....
But the drag link is stucked in the pivot arm!
I bumped it hard with a mallet, but is didn't moved...
Am i doing this in the wrong manner? Do you have any better idea how can i remove it?
I took a picture from the drag link end. It's in the gallery...
Thanks in advance
Julio
Widefiveguy
Widefiveguy is offline
PostPosted: Sat Oct 23, 2004 9:42 am    Post subject: Reply with quote
Try pressing the ball joint back into the arm. That will hold the shaft so you can remove the nut. Oh I didnt read it all. I just saw ur photo and thought u couldnt get the nut off. Do you have a pulley puller? Or a pickle fork, be very carefull with these as you can tear the rubber boot.
View user's profile Send private message Send e-mail AIM Address Yahoo Messenger MSN Messenger Gallery Classifieds Feedback
Hella Bro
Hella Bro is offline
PostPosted: Sat Oct 23, 2004 10:25 am    Post subject: Reply with quote
You need a small puller, or a tie-rod pickle fork tool to seperate the joint from the arm. The design of the stud on the ball joint is tapered for a tight fit, that's why it wont break loose easily.
VWBobby
VWBobby is offline
PostPosted: Sat Oct 23, 2004 10:34 am    Post subject: Reply with quote
What I do is...
-Losen the nut until the end of the stud is Flush with the top of the nut. This will protect the threads and the end of the balljoint.
-Soak the balljoint end with penetrating fluid, where it enters into the pivot arm.
-Wedge a pickelfork into the arm and smack the handle until it is very snug under the joint.
-Tap the end of the joint sharply a few times.
-Go back to tapping the end of the handle to snug up the pickle fork.
-Repeat until your ears are ringing and your fingers lock up from arthritis.
BINK!
-Remove nut, enjoy...serve with a side of coffee.
Very Happy
If your tie rod ends, or drag link ends are bad anyway, use a little heat to make the process go much faster. Just don't heat anything up too much or you can weaken the metal.
60kombi
60kombi is offline
PostPosted: Sat Oct 23, 2004 10:52 am    Post subject: Reply with quote
I just replaced mine yesterday....I used a pickle fork. Granted I was replacing mine so I was not worried about damage. Reguardless what others may say, you can remove the ends without damage to the joint or rubber boots. Mine came off without any damage. You do not need to go out and buy a $80 hazet press to remove them. Take your time. It only took about two minutes to remove.
Mike
novetti
novetti is offline
PostPosted: Sat Oct 23, 2004 11:38 am    Post subject: Thanks.... Reply with quote
Thanks for all inputs...
I will go back to shop now, and smack that thing it until i get deaf....
I'm pretty sure it's the original drag link, so it's stucked in there for over 35 years...
I will post if i was lucky or not removing it...
Julio
Lind
Lind is offline
PostPosted: Sat Oct 23, 2004 1:31 pm    Post subject: Reply with quote
pounding on your steering components is a bad idea. the picklefork is the wrong tool. just upstream from the forward drag link ball joint is the pitman arm shaft which is held snuggly into the steering box with brass bushings. I have a feeling that hammering on them would not be good.
there is a special tool for this. you can see pictures of it in your bentley manual. hazet makes the tool, so do several other tool manufacturers. I think that it costs between $75-$100. it is money well spent. my tie rod popper tool is the most commonly borrowed tool by my friends.
I am of the opinion that if you are going to do the work, get the right tools. not having the right tools can cause you to break other things by using the wrong tool (like a picklefork). one of the reasons that shops charge so much to do the work is because they have tens of thousands of dollars invested into their tools.
Wanted:
Clara Premium Member
Clara is offline
PostPosted: Sat Oct 23, 2004 2:33 pm    Post subject: Reply with quote
wot Lind said
last time I replaced a drag link was on my 61... I ended up removing the pitman arm with the aid of Eric E. and the Persuader. Then his hazet tool popped the drag link end off the pitman arm like butter... was no room to use the tool with pitman arm installed. there was factory scribe marks for how to reinstall the pitman arm... so no worries about getting it on the splines wrong.
60kombi
60kombi is offline
PostPosted: Sun Oct 24, 2004 5:06 am    Post subject: Reply with quote
Although my drag link was original, I did not have to pound the joint to remove the end. Just a couple of firm taps. Granted mine was not rusted at all. I do agree that really pounding the suspension is not a good idea. If you need to do that to remove the joint its time to find another method. (rent a tool). If you are a full time mechanic and replace ball joints often fine, buy the tool. I just dont think the ordinary joe out there is going to be doing that. Regardless of the method, soak the joint good with penetrant prior to starting.
Mike
novetti
novetti is offline
PostPosted: Sun Oct 24, 2004 7:43 am    Post subject: I will borrow a correct size pulley puller from a friend Reply with quote
I just have big pulley pullers that were not adequate for this job.
So i will pick one with the appropriate from a friend....
That would solve this problem (i think).
I already soaked the joint with oil...sure it will help.
I'm removing the front beam, engine and transmission to start my sheetmetal work. I will skip to the engine removal until i could get the pulley puller, probably tomorrow.
Thanks
Julio
dstefun
dstefun is offline
PostPosted: Sun Oct 24, 2004 10:04 pm    Post subject: Reply with quote
I agree with Lind - and the proper tools are not that expensive. I use a $29 tool and can get every single rod end off in less than 10 minutes with no damage. I did it the other way for too many years before I got smart. It's actually fun working with the proper tools. Shocked And now my kids aren't picking up any new words to use at school. Wink
Don't use a pickle fork unless you don't want to save the parts as it's almost guaranteed to destroy the rubber boot.
This is what I use http://www.thetoolwarehouse.net/shop/OTC-7315A.html $29 plus shipping.
Admin update: New link:
https://www.thetoolwarehouse.net/otc-tools-equipment-7315a-P28145.aspx
Other people like this one http://www.thetoolwarehouse.net/shop/TA-61900.html $11 + shipping
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus
novetti
novetti is offline
PostPosted: Tue Oct 26, 2004 5:06 pm    Post subject: Used a pulley puller borrowed from a friend... Reply with quote
It's really easy to do that with the right tools.... Very Happy
http://www.thesamba.com/vw/forum/album_page.php?pic_id=93805
I'm tooking the engine and tranny out next weekend...
The engine removal i already did it before..no problems...but the tranny removal not.
Any secrets or clues on removing the transmission?
Thanks
Julio
dstefun
dstefun is offline
PostPosted: Tue Oct 26, 2004 11:34 pm    Post subject: Re: Used a pulley puller borrowed from a friend... Reply with quote
Thanks
Julio
Here's how to remove the tranny ... http://www.type2.com/library/drivetra/tranrem.htm
62 SC & 66 Bus
novetti
novetti is offline
PostPosted: Wed Oct 27, 2004 10:36 am    Post subject: Thanks for the link!! Reply with quote
I just read the type 2 article. Very good.
As the author said, i also read Muir's and couldn't found all the info needed.
I was thinking on removing the whole assembly, incluinding the wheels and tires. Do think it's possible?
Because my rear wheels are stuck on the brake drums, and i think will be easier to remove them after the tranny is out.
Anyone did that before? Removing everything together(Tranny+axles+reduction boxes+drums+wheels/tires)?
Thanks
Julio
jardindelalma
jardindelalma is offline
PostPosted: Thu Nov 04, 2004 5:02 pm    Post subject: Reply with quote
i just bought a pitman arm and tie rod puller (combo made for compact cars) at autozone for $10.00 the other day....pulled my pitman like it was nothin! it was so nice to have a good tool and didn't have to pay very much for it! Laughing
Friedpotatoes
Addicted4life
Friedpotatoes is offline
PostPosted: Thu Nov 04, 2004 7:36 pm    Post subject: Reply with quote
we had had to upgrade to a bigger hammer 2 times to get mine out.
56- Wolfsburg Single Cab
57- Oval Window Bug (Agave Green)
dstefun
dstefun is offline
PostPosted: Thu Nov 04, 2004 7:59 pm    Post subject: Re: Thanks for the link!! Reply with quote
Thanks
Julio
The biggest problem is that the emergency brake cables are attached inside the brake drums. You could always cut the cables and replace with new cables but why do that if they are still good? Second problem is the height you would have to support the rear of bus at to clear the wheels. Not safe. Get the brake drums off where they are, it's a common problem and probably easier with everything mounted solidly to the bus anyway.
62 SC & 66 Bus
EvilBus
Samba Art Critic
EvilBus is offline
PostPosted: Thu Nov 04, 2004 10:36 pm    Post subject: Reply with quote
The Pickle Fork should remove the ball joint, there's also the knuckle tool.
Have you also tried heat? It works, and a little will expand the seating area. Use penetrating oil after you heat it, wait a minute or two then reheat. Be careful the penetrating oil may flash and avoid flame contact with the boot.
A tap or two on the side
or another try with the pickle fork should do it.
- JHC de Tejas -
novetti
novetti is offline
PostPosted: Sat Nov 06, 2004 5:57 am    Post subject: Thanks for all info i get from you in this holy forum... Reply with quote
Everything is already out of the bus (engine,tranny,front beam). Check the pics in my gallery.
I will begin my sheetmetal cuts this weekend...
I cut the brake cables. They were too old, rusted and with some kinks...
Took the tranny wit the redux boxes and drums as o whle assembly.
Thanks
Julio
EdZ KG6UTS
EdZ KG6UTS is offline
PostPosted: Tue Oct 17, 2017 9:26 am    Post subject: Drag Link 74 camper Reply with quote
60kombi wrote:
.... If you are a full time mechanic and replace ball joints often fine, buy the tool. I just dont think the ordinary joe out there is going to be doing that.
Mike
I found this post while researching doing the replacement on my 1974 camper. The first ball joint tool bought for $13.50 from NAPA broke! What worked was tool # 27276 from AutoZone. Auto Zone has a tool loaner program I did not know about but for a deposit of $35, the price of the tool, I could borrow the tool at no charge then return it and get my deposit. Not a bad deal at all and the tool was perfect for getting at the drag link ends. You can buy the 27276 for $35.
The replacement drag link is a Mayle from West Coast Metric. It fit fine and the '74 steers just fine now.....no longer runs away from passing semis or side gusts.
EdZ KG6UTS
