Ragman The Sambinator
Posted: Fri Nov 12, 2004 1:45 pm Post subject: Shift Rod Tube Rust |
Anyone have their shift rod tube rust out? A section towards the front of my bus is rusted out on the bottom pretty good. Rust flakes were grinding on the shift rod, so I opened up the worst section, and cleaned the flakes/chunks out.
What fixes have you done to address this problem? By leaving it open, is it prone to rusting out the entire tube? Or will the opening on the bottom now act as a drain for any water that gets in there? I was thinking about welding a section of metal tube over the open section to seal it up.
what ways do you fix yours?
Thanks |
faster-laster Samba Member
Joined: February 09, 2004 Posts: 288 Location: Cedar Park, TX
Posted: Fri Nov 12, 2004 1:54 pm Post subject: |
I"m not sure about the repair, but a good way to keep it from rusting for the present would be to cake the holy snot out of it with bearing grease. _________________ 62 Mouse Grey Deluxe
66 Westfalia SO-42 "Tigerbus" |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Fri Nov 12, 2004 6:33 pm Post subject: Re: Shift Rod Tube Rust |
Ragman wrote: |
By leaving it open, is it prone to rusting out the entire tube? Or will the opening on the bottom now act as a drain for any water that gets in there? I was thinking about welding a section of metal tube over the open section to seal it up. |
Hi Ragman,
Leave it open and it will be prone to rust due to the dirt & dust getting into there and this will also ruin the rear shift linkage shift bushings because of the added friction. If you weld a repair piece there and this ends up in one of the shift linkage bushings areas, the rough area will chew up the bushing and make shifting a pain. Even if not in a bushing travel area this could make it a real pain to install new bushings.
Best way to fix the problem is to cut off a shift linkage tube off a wrecked bus. Maybe a 1968-79 one will work? Then cut off your rusty one and weld into place.
After that make sure to get the front and rear tube to linkage seals from WW.
Eric&Barb |
Clara Samba Member
Posted: Sat Nov 13, 2004 12:13 am Post subject: |
faster-laster wrote: |
I"m not sure about the repair, but a good way to keep it from rusting for the present would be to cake the holy snot out of it with bearing grease. |
grease is good _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Sun Nov 14, 2004 10:21 am Post subject: Re: Shift Rod Tube Rust |
Eric&Barb wrote: |
Ragman wrote: |
Hi Ragman,
Eric&Barb |
Thanks for the advice. That is what I was expecting; however, I was hoping to be able to fit it without pulling the engine and transmission. Maybe I'll get a temporary piece on there until something permanent can be done. |
