Terran Samba Member
Joined: July 16, 2004 Posts: 326 Location: New Hampshire
Posted: Sun Nov 14, 2004 1:57 pm Post subject: Fuses |
How many extra fuses are there on a 74 SB? i've already used 2 one perminant 12v for my stereo and one ignition one for my windshield washer, but i want to add a cigarette lighter and some more gauges and i want to make sure i'll have enough. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Sun Nov 14, 2004 5:12 pm Post subject: |
There should be no extra fuses. |
Terran Samba Member
Posted: Sun Nov 14, 2004 9:17 pm Post subject: |
mmm um, there were a couple on mine. what should i do for more fuses then? |
Seaside Samba Member
Joined: June 22, 2004 Posts: 165 Location: Augusta Georgia
Posted: Mon Nov 15, 2004 11:53 am Post subject: Put in another fuse box |
Add a fuse box, wire it. _________________ Das nette kleine weiße Auto
78 Triple White |
Terran Samba Member
Posted: Mon Nov 15, 2004 6:29 pm Post subject: |
can you be more specific, like how'd i'd run more ignition fuses and such? |
TeamSpatula Samba In The Rain
Posted: Tue Nov 16, 2004 6:53 am Post subject: |
Sounds like you basically want accessories, which will be powered only when the car is on. In that case, you have to get the power from the downstream side of the ignition, so that will be when they're on. Most Auto Parts places have auxilliary fuse boxes, or you could even run an inline fuse or two, depending on how much you want to add, and how much of a load it will be. _________________ <---Air Cooled Search & Rescue Team - STICKERS & T-shirts for sale!
I NEED A CAMPER!!!! (1971 is ideal but will consider other years)
http://www.TeamSpatula.com |
Posted: Tue Nov 16, 2004 9:21 am Post subject: Extra fuses. |
What you do is think about how many more accessories you'll run. Most likely 8 amps fuses should be ok for most, unless you want to run a snow blower or hair dryer or something. Every thing electrical you put in needs a wire with DC current coming in and one going to ground. Put your fuse/fuse box in line between the source of DC current and the device, to serve as a circuit breaker, and ground your device to the frame, or a ground wire, depending where you device is located.
Think that for each device, you need appropriate gage wire, I guess 12 AWG or 14 AWG would do it for most things.
Tie it all up, tidy it and here you go. Draw it before if you want to think about it. _________________ Das nette kleine weiße Auto
78 Triple White |
Terran Samba Member
Posted: Tue Nov 16, 2004 4:16 pm Post subject: |
but my question is how do i expand the acessories? |
shew Samba Member
Joined: January 04, 2005 Posts: 5 Location: Surrey, England
Posted: Tue Jan 04, 2005 2:17 pm Post subject: |
you would have to make a connection from the existing fuse box or run an additional wire direct from the battery (if you don't mind the accessories being permanently powered). The wire you run would then need to be connected to either an inline fuse before going off to the accessories or a second fuse box fitted by yourself. |
