GEX engines
Page: Previous  1, 2, 3 ... 13, 14, 15
PostPosted: Tue Sep 25, 2018 4:25 pm    Post subject: Re: GEX engines Reply with quote
sydpup570 wrote:
there heat sensitive material was no longer in the washer
What does that mean? I don't understand this text
You could try taking them to small claims court.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Sep 25, 2018 4:53 pm    Post subject: Re: GEX engines Reply with quote
Many engine builders put a dime sized disc on the engine case. if you overheat the engine the center melts and indicates the engine was overheated. They use that to deny warranty claims.
"Center Melts At 195-200F"
Glenn
Member #1009
#BlueSquare
PostPosted: Tue Sep 25, 2018 5:05 pm    Post subject: Re: GEX engines Reply with quote
Is it really 200F max?
Depending on where it is, that would immediately melt on any of my engines according to my laser thermometer.
Mr. 010
Glenn is offline
PostPosted: Tue Sep 25, 2018 5:07 pm    Post subject: Re: GEX engines Reply with quote
I'm sure there are ones with different heat ranges. But maybe GEX purposely uses ones with a low melting point to deny claims.
Glenn
Member #1009
#BlueSquare
weisswurst
weisswurst is offline
PostPosted: Mon Jan 11, 2021 2:39 pm    Post subject: Re: GEX engines Reply with quote
not me by the way
11 GEX engines "new" in the crates Wink OH BOY.....
https://www.facebook.com/conquesttrikes
GEX
Hi Performance 1914 cc VW engine
Dual 40 or 44 mm carburetor
Bosh Generator
Dog House Fan Shroud
Bosch Blue Coil
009 Distributor
Heavy Duty Oil Pump
Bosch Ignition wires
Big Valve Dual Port Heads
Bolt on Aluminum Valve Covers
Double thrust Cam bearings
8 Dowel Crankshaft & Flywheel
Heavy Duty Swivel Adjusters
Solid Heavy duty Rocker Shaft
69 mm Strike X 94 mm Bore 39 mm Intake & 32 mm
Exhaust valves
110 Cam
Additionally 1700 lb. Clutch assembly and Pro-Street Transmission
It has a first start up guide with each engine.
Shipping to anywhere - buyer expense.
All engine still in original package.
More info by email only.
[email protected]
We do not sell separate only all together as a package.
Total cost $76,612.85
OBO
+3
$49,000 · TAMPA, FL
11 VW ENGINE with 11 TRASMISSION and PARTS
Message
55
9 Comments
Like
Comment
Share
Comments
View 4 more comments
weisswurst
PostPosted: Mon Jan 11, 2021 3:05 pm    Post subject: Re: GEX engines Reply with quote
from the facebook ad Shocked
Marya
Marya is offline
PostPosted: Wed Mar 10, 2021 12:15 am    Post subject: Re: GEX engines Reply with quote
Oh great. A friend of mine saw my engine and pointed out that oh no, I have a GEX engine. He basically said I'm screwed! 😆 Sounds like I probably am! My brother who had the bus before me had the engine installed after he broke down sometime between 1991-1994 I'm guessing. He was very young and wouldn't have known better. I just texted him asking how long he drove it with that engine. Still waiting for his reply (she checks her phone for the third time).
Meanwhile I had several things done more recently using stock parts to help my bus get back on the road regardless, including major tune-up, new master cylinder, I think new distributor, rebuilt carburetor, new heater boxes, breaks, clutch, major cleaning and re-greasing, a few other things I'm forgetting, and had the friggin tranny beautifully rebuilt.
I don't think the bus was driven long after the engine replacement cause then the tranny had issues so my brother gave up and parked it for basically 20 or so years before I had that work done. It hasn't been driven more than probably 60-80 miles by me since then.
Questions:
1. I don't suppose there's any chance they were a better company back in the early to mid nineties, is there? 😆
2. If it does fall apart apart, which I completely expect now, approximately how expensive is it to have an experienced, reasonably priced, self-employed person put together a better quality one including of course the engine/parts? What about vs a a VW shop? I'm guessing those are two pretty different prices. I'm in Portland, Oregon, fyi. Just want to get an idea of how much trouble I'll eventually be in financially, since I'm about to invest in body work then in getting the whole interior put back in (new flooring, insulation and panels then all the original camper furniture). That will all cost a lot (for me) and I never intend on selling (my grandpa bought it new). And it's been a looooong time coming, haha - only 27 or so years since it was last a drivable camper!! I'm going to be so screwed and profoundly disheartened if the engine then decides to effing die on me!!
Ahem. Thank you!
Marya
Marya is offline
PostPosted: Sun Mar 14, 2021 5:27 pm    Post subject: Re: GEX engines Reply with quote
I guess my brother drove his (now my) GEX engine around for a few years without issues (before it was left to sit 20+ years until I had it tuned up and drove it around for a while a few years ago). He took it to Los Angeles and back to Portland Oregon at least three times as well as a couple of other places and it was his daily driver. Hopefully - knock on wood - this is a good sign that I got one of the non-lemons. Knocking on wood again! 😆
1970, Riviera, 1600 cc type I [single port]
6T5 square
6T5 square is offline
PostPosted: Sat Mar 20, 2021 11:13 am    Post subject: Re: GEX engines Reply with quote
Don't let it scare you. Even GEX sold a couple of decent engines. Remember you're only going to hear the bad. You may have found one of the survivors!
John
65 square 1500S (weezer) sold but always on my mind
60 beetle (Ned)
Quoting John Muir -- Open the rear boot. Get out the stool and sit down. Contemplate the air-cooled beauty before you. - How to Keep Your Volkswagen Alive -- Step-By-Step Procedures for the Compleat Idiot
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Sun Mar 21, 2021 5:22 pm    Post subject: Re: GEX engines Reply with quote
As we used to say “ Even a blind squirrel finds a nut once in awhile”
and so it is with GEX.
Mr. 010
Glenn is offline
PostPosted: Sun Mar 21, 2021 5:55 pm    Post subject: Re: GEX engines Reply with quote
A "couple" is 2.
You have a better chance to hit the lottery.
Glenn
Member #1009
#BlueSquare
Ian
Ian is offline
PostPosted: Wed Nov 30, 2022 8:29 am    Post subject: Re: GEX engines Reply with quote
Unbelievable that this hack job company is still in business.
All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA**
Mr. 010
Glenn is offline
PostPosted: Wed Nov 30, 2022 9:27 am    Post subject: Re: GEX engines Reply with quote
New stupid people are born everyday
Glenn
Member #1009
#BlueSquare
vwinnovator
vwinnovator is offline
PostPosted: Thu Dec 01, 2022 6:23 am    Post subject: Re: GEX engines Reply with quote
there a several similar that seem to keep surviving as well...
they must have other stuff going on as well as I have a hard time believing they make enough off basic engines alone..
Page 15 of 15
