Daddybus Samba Member
Posted: Sat Nov 20, 2004 10:49 pm Post subject: '67 w/no high beams |
I can't get my high beams to light up on my '67 bus. When I flip the lever on the signal switch I can hear the relay click, but the low beams stay on. |
ukdj Samba Member
Joined: September 06, 2004 Posts: 389 Location: easley sc
Posted: Sun Nov 21, 2004 1:31 pm Post subject: headlights |
Check all your fuses and your black box if you have one.My highbeams also wouldn,t come on because the bulb blew inside the light new bulbs are only 8.99 ish |
NorCalWeekender Samba Member
Joined: April 13, 2000 Posts: 6531 Location: East Bay, CA
Posted: Sun Nov 21, 2004 4:11 pm Post subject: |
I have this same problem. And from everything I can tell, it's actually that little flasher box. Simple little 3-prong jobbie you can get down at the local Kragen. But it's worth checking the bulbs and everything else, first.
-Taylor _________________ 9th Owner of a 1971 Tintop Westy
"Eventually, we sold to a guy for $500 who towed it away to live in it in his parents' driveway. We didn't think it would ever avoid the junk heap on that day." -The 3rd Owner, 1995 |
OG Velvet Samba Family Man
Joined: February 24, 2003 Posts: 2168 Location: Portland, OR
Posted: Sun Nov 21, 2004 4:17 pm Post subject: |
The flasher is easy to fix too. I sandblasted (very lightly of course) the insides and after that greased the moving parts a little. If you hear the click, then the selenoid (sp?) is working but the little mechanical arm is most likely jammed. Or just replace it. _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Ragman The Sambinator
Posted: Sun Nov 21, 2004 9:24 pm Post subject: Re: headlights |
ukdj wrote: |
This has nothing to do with the 9 pin black box. I just went through all my wiring. Check all your wire connections here,
http://www.thesamba.com/vw/archives/info/wiring/bus_67_USA.jpg
To check to see if your headlight relay is any good, do this...
-> on the headlight relay, put a temp. wire on the S terminal and ground it very quickly to the body while the lights are on. If the relay clicks and the light change from hi/low then the relay is fine, and problem exists somewhere else in the wiring. It is good to determine early in your trouble shoooting if the relay is good or bad.
I found my relay to be fine. My problem was in the turn signal switch itself. The brown wires going to the switch were broken at the soder points, and once I re-sodered them back on the switch, my brights worked again. If your relay is good, you might want to pull apart the turn signal switch and investigate. |
Hella Bro Samba Member
Posted: Sun Nov 21, 2004 9:42 pm Post subject: |
My Hi/Lo beamer went out on 66. I looked at the Wolfsburg West catalog
and saw what they sold to replace the unit, I went to the closest junkyard
and pulled that relay out of a superbeetle. |
jmsmilin Samba's Most Posted
Joined: November 10, 2005 Posts: 3302 Location: Out on Pa-troll.
Posted: Sun Oct 14, 2007 2:09 pm Post subject: |
same thing on my 67, I need to get it fixed _________________ Der Schmutzige Süden.
(o\ ! /o) | o \/ o | (o)=|=(o) [o\|_|_|/o] \m/ |
///Mink Samba Member
Joined: May 03, 2000 Posts: 5051 Location: Fair Oaks, CA
Posted: Sun Oct 14, 2007 2:25 pm Post subject: |
It's likely the High-low relay going bad or possibly a bad ground. As mentioned above, the 9-pin black box has absolutely nothing to do with high beams.
Edit-Just realized how old this thread was and who the last poster in 2004 was. |
60vwnewengland Twin #2
Joined: June 25, 2003 Posts: 1784 Location: District of Columbia & Cape Cod
Posted: Sun Oct 14, 2007 4:40 pm Post subject: |
i've had this problem too....what i was told is to hit the box with a hammer. i did that and my high beams worked again!! so hit it....see what happens, parts get old and gummed up sometimes. i haven't had a problem since. worse side of it is, you waste 10 minutes hitting a box with a hammer, and if it still doesn't work whatever. but hey its was worth the shot. _________________ 77 Westy - Cape Cod Sage
LLAP |
xavi_242 Samba Member
Joined: May 06, 2005 Posts: 1672 Location: Barcelona (SPAIN)
Posted: Mon Oct 15, 2007 11:17 am Post subject: Re: '67 w/no high beams |
tony1 wrote: |
I have same problem, new switch, relay did click and no high beams.
http://www.thesamba.com/vw/forum/viewtopic.php?t=216098&highlight=
or look at my blog, a post from 19 February 2007, called:
'Dimmer relay goes to the operating room'
http://so-42.blogspot.com/2007_02_01_archive.html
If you open it you'll see how it works and can easily if there is a problem
good look
xavi _________________ 1967 Split SO-42 Dormobile |
winmotors Samba Member
Joined: November 20, 2005 Posts: 99 Location: Monterey Park
Posted: Sat Oct 27, 2007 8:34 am Post subject: |
Had the same problem. I jus tbought the headlight relay from wolfsburgwest.com and that fixed it.
Good luck |
Posted: Sat Oct 27, 2007 8:55 am Post subject: |
OG Velvet wrote: |
The flasher is easy to fix too. I sandblasted (very lightly of course) the insides and after that greased the moving parts a little. If you hear the click, then the selenoid (sp?) is working but the little mechanical arm is most likely jammed. Or just replace it. |
Just to clarify my old post. It was the high/low beam relay I was talking about, not the flasher. Just replace the word flasher, with relay... _________________ '67 13 Window
'77 Westy
'69 Sunroof Beetle
'65 Honda Dream |
Posted: Sat Oct 27, 2007 10:12 am Post subject: |
Whack relay with a small section of 2x4 (wood)...should unstick the relay...worked for me. |
