gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Fri Dec 03, 2004 4:32 pm Post subject: Blinkers not blinking... |
My blinkers just quit working for no good reason. I just got a new hazard switch, light switch, flasher, bulbs, fuses
The emergency flasher still operates the blinker fine, so the flasher works as do alll the bulbs, but when I turn on the turn indicator only the dash light comes on!!?
I also tried to wiggle the emergency switch and tap the flasher with the turn indicator on, but no response. The only thing that led up to this is I used the emergency flasher for the first time for an extended period of time.
Suggestions? _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
74Ghia Samba Member
Joined: December 17, 2003 Posts: 2131 Location: Middle of Georgia
Posted: Fri Dec 03, 2004 4:39 pm Post subject: |
Could it be the turn signal rtelay? I'd check there and then look for the easy things first. (poor ground, flasher wire loose, etc. _________________ Allen C.
2012 Silverado
53 FiberFab MG TD Replica (VW)
Life is hard and its harder if you're stupid. |
Banzai KG Samba Member
Joined: April 10, 2004 Posts: 2992 Location: Sunnyvale, CA
Posted: Sat Dec 04, 2004 11:10 am Post subject: |
Hmmm.....probably needs Blinker Fluid
High Quality Synthetic Blinker Fluid -
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough?
Here's your solution. Little do people know, blinker fluid should be changed every 150,000 blinks! KaleCo high quality synthetic blinker fluid meets the highest D.O.T. standards! KaleCo blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause!
KaleCo blinker fluid will not lose its viscosity, even in the most extreme situations! Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car.
http://www.kalecoauto.com/fluids.htm _________________ Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/ |
VWGirl Samba Member
Joined: June 03, 2003 Posts: 2462 Location: Powder Springs, GA
Posted: Sat Dec 04, 2004 12:49 pm Post subject: |
Banzai KG wrote: |
http://www.kalecoauto.com/fluids.htm |
do they sell muffler bearings too? |
Posted: Sat Dec 04, 2004 6:44 pm Post subject: |
VWGirl wrote: |
Yes they do...
$100 Each
$175 Pair
Extra Strength Muffler Bearing -
Do you have an annoying rattling in your mufflers? Are they sagging a little? Don't quite sound right?
That could be the symptoms of a worn muffler bearing. Allow me to introduce the KaleCo muffler bearing! It's unique iron-graphite composite with pre-grease-packed assembly provides over 200,000 miles of smooth muffler operation! It is most likely they will outlast your mufflers.
Also works well on heavy duty exhaust systems. One per muffler.
You can get more of those fine products at: http://www.kalecoauto.com _________________ Jim Kikuchi
Posted: Sat Dec 04, 2004 9:07 pm Post subject: |
I already tried some DOT approved blinker fluid with no success....It worked wonders on my squeeking winshieldwipers though _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
VWGirl Samba Member
Posted: Sun Dec 05, 2004 10:00 am Post subject: |
Banzai KG wrote: |
VWGirl wrote: |
Yes they do...
$100 Each
$175 Pair
You can get more of those fine products at: http://www.kalecoauto.com |
no thanks my local import store has them for $11 a peice |
1964VW Samba Member
Joined: May 04, 2004 Posts: 463 Location: I live where people chew dip,just past the sticks...
Posted: Sun Dec 05, 2004 5:17 pm Post subject: |
Try using beer with extra cow urine to cure the problem _________________ Jonks |
