gatorjos Samba Member
Joined: April 19, 2003 Posts: 406 Location: San Francisco
Posted: Mon Dec 13, 2004 12:50 am Post subject: Engine Gunk |
I changed my oil today after about 3k miles, and found a lot of gunk on the bottom plate . It had a clay like feel to it and was gray/metallic looking. My engine runs great, but I'm a little worried.
What's a normal amount of sludge? I really want to get a pump with an oil filter on it. Any suggested types?
Thanks,
Jos _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
1972 Ghia cabriolet (full body-off restoration -- stolen after five years of ownership)
2004 Passat 1.8T (manual)
http://21stcenturyhobo.com |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76911 Location: Sneaking up behind you
Posted: Mon Dec 13, 2004 4:03 am Post subject: |
Does it look like this?
When I split the case I found both exhaust lobes on the cam almost round and the lifters badly pitted.
You might have a major problem. _________________ Glenn
Member #1009
#BlueSquare |
Randy in Maine Samba Member
Posted: Mon Dec 13, 2004 6:28 am Post subject: |
Could also be water that has collected in the crankcase due to the engine not gettting hot enough to remove the water from the system.
Longer drives and a properly operating thermostat helps get rid of it. |
Glenn Mr. 010
Posted: Mon Dec 13, 2004 7:26 am Post subject: |
gatorjos wrote: |
It had a clay like feel to it and was gray/metallic looking. |
That's metal.
Condensation is a cream colored mayonnaise like buildup usually on the inside of the oil fill. _________________ Glenn
Member #1009
#BlueSquare |
volksguy Samba Member
Joined: November 24, 2003 Posts: 342 Location: Apple Valley, Ca.
Posted: Mon Dec 13, 2004 9:37 am Post subject: |
Last time i saw a oil drain plate look like that was on my very own race engine a day before a big race when i changed my oil, then on race day a rod bearing ended up spining. So, i think if you see that kind of sludge.... Its defitnitly time to split your case before its too late. _________________ Suck It Easy High Performance Engines |
Posted: Mon Dec 13, 2004 1:29 pm Post subject: |
Dang! It wasn't quite that bad. On mine the sunken in part of the plate was filled flush (not a mountain like in the pic), and the color was a lot more sooty -- pretty much black until I scraped it with my finger. I am guilty of driving my car on cold mornings for short drives without the thermostat installed . I found out someone removed it when I replaced my generator...
I've been thinking about doing a power upgrade anyway. It's just tough to park my only car...
Anybody know anything about his guy on ebay?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?Vi...gory=33615
Pretty good deal seems like....[/quote] _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
Mr. Bubblehead El Chupa Nibre
Joined: October 25, 2002 Posts: 2756 Location: 612 Wharf Avenue
Posted: Mon Dec 13, 2004 3:40 pm Post subject: |
Ive delt with that guy a few times, i never had a problem with him, He shipped my stuff fast,and it was as described,but i just bought parts from him, not complete engines, mostly just crankshafts. _________________ Suck It Easy High Performance Engines |
Posted: Mon Dec 13, 2004 4:06 pm Post subject: |
All right,
I guess his stuff is too cheap to be true.
Thanks for the heads up.
Previous romances:
Posted: Mon Dec 13, 2004 5:23 pm Post subject: |
gatorjos wrote: |
I guess his stuff is too cheap to be true. |
I've found that you generally get what you pay for. _________________ OGST
Samba Member #4862 |
Posted: Mon Dec 13, 2004 7:07 pm Post subject: |
fo shizzle _________________ 1977 Westfalia Weekender Berlin "The Kitebus" aka " Colonel Mustard"
Previous romances:
