jberger Samba Member
Posted: Sat Dec 18, 2004 11:41 pm Post subject: 75 R&P |
Howdy,
Does anyone know offhand if the ring and pinion for a 75 tranny is a higher ratio than the 79 unit? I have a chance to by a 75 bus with a reman tranny in it and would love to loose about 5mph on my top end in the 79.
Thanks |
germansupplyscott Samba Member
Posted: Sun Dec 19, 2004 8:04 am Post subject: |
jberger,
it looks like you have to have the serial number of the tranny to now for sure. almost certainly you will have the taller 4th, but it looks like there were 75-75 gearesets that had the tall R&P also. i checked here:
http://sandlizrd.baja.com/gears.htm
i don't have a great deal of expertise when it comes to transaxles. when i have had a question like in the past i have gone to shoptalkforums and posted in the transaxle forum, where there are some real experts who can help. _________________ SL |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Sun Dec 19, 2004 8:54 am Post subject: Re: 75 R&P |
jberger wrote: |
The '75 ratio is 4.86:1 as opposed to 4.57:1 for the '76 up. If your transaxle has not been rebuilt, it will be in the "pyramid" 5 rib case, as opposed to the smooth 6 ribs of the 091. As originally sold, the freeway rpms in 4th gear between the '75 versus the '76 up, was actually taller in '75. The reason for this was the 4th gear ratio in '75 was .82 versus .89 in the '76 up.
Colin _________________ www.itinerant-air-cooled.com |
Posted: Mon Dec 20, 2004 9:59 am Post subject: |
Thanks,
Looks like I will see about getting mine rebuilt with a different R&P |
Posted: Mon Dec 20, 2004 10:12 am Post subject: |
I am curious about what you are seeking here. Volkswagen kept the overall 4th gear ratio extremely consistent from 1975 right through 1989 even with the development of the wasserboxer. The change in r&p's had its most noticeable effect on the lower three gears. What is the torque/horsepower of your current engine?
Posted: Mon Dec 20, 2004 10:27 am Post subject: |
Bone stock rebuild 79 California model. When I added the high top my mph at a given pedal input dropped about 5 mph. So now on the high way instead of cruising at 60-65 it likes 55-60. I would like to restore the rpms to the sweet spot at the lower speed. |
