ATTENTION: Monday morning, from approximately 5:30AM - 9AM California time (PST) Samba will be unavailable in order to perform a server upgrade.
Bumper Bolts...
Mr. Electric Wizard
Mr. Electric Wizard is offline
PostPosted: Mon Dec 20, 2004 8:41 pm    Post subject: Bumper Bolts... Reply with quote
I have everything I need to mount my Front Bumper except for the bolts...
Does anybody know what the bolt sizes are for the Brackets, and for the Bumper itself?
I'm sure it won't be easy to find this stuff because Home Depot sucks.
"Saying what we think gives us a wider conversational range than saying what we know."
~ Cullen Hightower
(T)exas (C)oalition (B)uses
(H)eidenhammer (B)ully (B)oyz
--1966 De Luxe Camper
dstefun
dstefun is offline
PostPosted: Mon Dec 20, 2004 9:06 pm    Post subject: Reply with quote
brackets to the frame are 10x1.5x20 (#34 on image #N10252.1)
brackets to bumper are 8x1.25x20 (#8 on image, # N10240.2))
VWBobby
VWBobby is offline
PostPosted: Mon Dec 20, 2004 9:54 pm    Post subject: Reply with quote
I've actually found a lot of metric bolts at Home Depot, nothing thats higher than grade 5 though (wich I think is grade 8.8 in metric). NAPA seems to have bolts that the other auto suppliers dont have in my neck of the woods. If you look up "Fasteners" in the Yellow Pages you can usually find a speciality store for metric hardware in your area, there's also True Value/ACE.
Good luck,
-Bobby
Mr. Electric Wizard
PostPosted: Tue Dec 21, 2004 5:59 am    Post subject: Reply with quote
Thanx dstefun your the man...
~ Cullen Hightower
Mr. Electric Wizard
PostPosted: Thu Dec 23, 2004 10:20 am    Post subject: Reply with quote
Hey dstefun,
Do you happen to have this sheet for the Rear bumper also, I just found one...?
Thnx in advance! Smile
~ Cullen Hightower
coolerthanelvis
coolerthanelvis is offline
PostPosted: Thu Dec 23, 2004 10:28 am    Post subject: Reply with quote
You could buy a bumper bolt kit from WW.
Front, including bolts for overriders:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211798002
Rear, with overriders:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211798003
$6.50 for each set.
Shawn
SV2s member #420
'68 Westy
"Do or do not, there is no try."
-Silent Bob
dstefun
dstefun is offline
PostPosted: Thu Dec 23, 2004 10:46 am    Post subject: Reply with quote
Mr. Electric Wizard wrote:
Hey dstefun,
Rear bumpers are in the same diagram above, bolts are the same size as the fronts
brackets to the frame are 10x1.5x20 (#46 on image #N10252.1)
brackets to bumper are 8x1.25x20 (#44 on image, # N10240.2)
-Dave
Radio Questions R Us - what'cha need to know?
"Out! Out! You demons of stupidity!"
Remember - You are required to get older but you are not required to grow up!
62 SC & 66 Bus
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Thu Dec 23, 2004 11:07 am    Post subject: Reply with quote
i think this is a prime example of needing to learn how to read the parts book... im not harping, just pointing out that one of a bus owners best friends should be a copy of a correct year parts book. vintagebus.com has them online and i'm not sure if pc, but I put a copy of each pdf on my computer for the times when i'm not on the net. I do own an og copy and then a xerox copy. I use the xerox copy in the shop and the original is a keepsake. but I digress. go to vintagebus right now and spend a few minutes (or more) and familiarize yourself with it. With this reference and a copy of the torque spec book, you're good to go!
Sounding like a broken record as to why You should be measuring protein during harvest in order to better your agronomic practices.
hazetguy
hazetguy is offline
PostPosted: Thu Dec 23, 2004 12:44 pm    Post subject: Reply with quote
and just to drive people like you crazy David, the front bumper bolts have thinner heads than "regular" bolts (for example the rear bumper bracket bolts). i have seen these thinner head bolts on too many busses to know it's not just a fluke, even though the parts book shows a regular DIN 933 bolt for the front.
anyway, i believe they have thinner heads for clutch pedal clearance, and i kinda remember using a "regular" bolt once and the pedal hitting it.
DaveM
Mad Samba Scientist
DaveM is offline
PostPosted: Thu Dec 23, 2004 12:54 pm    Post subject: Reply with quote
Jon, I do have the thinner headed bolts on the front. Cool
dstefun
dstefun is offline
PostPosted: Fri Dec 24, 2004 11:59 am    Post subject: Reply with quote
Dang - learned something new AGAIN on TheSamba! But the late (67) parts book shows the same part number for front & back. What years have you noticed this on Jon?
62 SC & 66 Bus
jslmc1
jslmc1 is offline
PostPosted: Sun Nov 10, 2019 6:19 pm    Post subject: Re: Bumper Bolts... Reply with quote
Does anyone know where to find galvanized metric bolts in this size? I was pulling the bumper off of a 1964 bus and the bolts came off so well. I think the galvanized treated bolts made it possible. Although we think galvanizing bolts is a cheap process, I believe it has its place for bumper mounting bolts by design. I have google searched, and metric galvanized hardware is hard to find. Say a M10X20 DIN 933 bolt, galvanized. If galvanized is not the way to go, someone convince me that stainless steel hardware, or zinc
is better than OE. Stainless/zinc hardware is easy to find. Then I can put them on knowing that someone in 2074 will have an easy time like me today breaking the bumper
bolts loose again on a split window bus. The bolts also still had the galvanized finish between the bumper and overriders, and between the frame and the bumper mounts.
mandraks
mandraks is offline
PostPosted: Sun Nov 10, 2019 6:57 pm    Post subject: Re: Bumper Bolts... Reply with quote
i think what made the old bolts come out is the wax coating on them. keeps them from galling and rusting. Go in easy, torque good, clamp tight, come out good.
regards
Uli
LAGrunthaner
LAGrunthaner is offline
PostPosted: Mon Nov 11, 2019 4:24 am    Post subject: Re: Bumper Bolts... Reply with quote
Interesting cool wax coating mandraks, I'll assume now most use Anti-seize on the threads but the WW bolts look like they will rust up quickly. What is a good product to put on the rest of the bolt?
Maui Roadsters VW Logo
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote:
j.pickens
j.pickens is offline
PostPosted: Mon Nov 11, 2019 12:52 pm    Post subject: Reply with quote
Dang! An ancient thread gets brought up, and I learned something new!
My sunroof swivelseat kombi hits the bolt head slightly. Thought it was due to my bus being a restored basket case, possibly out of square in that area.
I feel a bit better now...
BeaterBarndoor wrote:
Red Fau Veh wrote:
Clara
Clara is offline
PostPosted: Mon Nov 11, 2019 4:06 pm    Post subject: Re: Bumper Bolts... Reply with quote
Yes, I use antiseize, or even just a smear of all purpose grease.
I have taken apart fasteners 20 years later, and was happy I used that grease. Grease is good. Grease your beam and smear the extra on the underside of the bus.
Very Happy
hazetguy
hazetguy is offline
PostPosted: Mon Nov 11, 2019 5:13 pm    Post subject: Re: Bumper Bolts... Reply with quote
Shocked geez, ancient thread (2004), almost as ancient pics from another ancient thread https://www.thesamba.com/vw/forum/viewtopic.php?t=240707 (2007).
glad i gave you some peace of mind jdot.
