phastbus Samba Member
Joined: July 26, 2005 Posts: 57 Location: Lakeport, California
Posted: Tue Nov 12, 2019 9:38 am Post subject: Rocker installation height - help with alignment |
I'm installing the cargo door outer rocker right now and will eventually be replacing the floors as well, but not right now. The floor is so gone that I don't have it for a height reference for the rocker and I wanted to know if the top of the outer rocker should be parallel with the inner rocker or slightly higher like I have it in the photo?
I'm thinking it should be where I have it, that the part of the floor that goes over the rocker is the same as the high points in the corrugation, but I just want to be sure.
I don't have a new floor to test fit, so if you could please look at the photo and tell me if the outer rocker vertical location looks correct, or if it should be lowered to be the same height as the inner rocker or somewhere in between. I'd really appreciate it.
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 25173 Location: Olympia Wash Rinse & Repeat
Posted: Tue Nov 12, 2019 10:42 am Post subject: Re: Rocker installation height - help with alignment |
Getting about .210" to .220" above the floor ribs. Since the latch area does have some surface rust, would not be surprised if it was .230" originally. _________________ In Stereo, Where Available! |
Posted: Tue Nov 12, 2019 11:38 am Post subject: Re: Rocker installation height - help with alignment |
Eric&Barb wrote: |
Getting about .210" to .220" above the floor ribs. Since the latch area does have some surface rust, would not be surprised if it was .230" originally. |
Above the low point in the floor ribs right? And by floor ribs you mean the literal floor skin right, not the supporting structure. |
Posted: Tue Nov 12, 2019 11:46 am Post subject: Re: Rocker installation height - help with alignment |
phastbus wrote: |
Eric&Barb wrote: |
Meaning 1 foot scale laid over the top of the floor skin ribs, ends up lower than the top of the latch plate surface. _________________ In Stereo, Where Available! |
DubStyle SBS Hit Squad
Joined: July 26, 2003 Posts: 6250 Location: SBS headquarters: Missery
Posted: Tue Nov 12, 2019 1:25 pm Post subject: Re: Rocker installation height - help with alignment |
Are your doors still mounted? Why not vise grip it in place, close the doors and set it where you have a good gap? In the end you want a good latching point for the doors. _________________ Anthony
SBS #1
SBS #1 on FB
"The original & best lowered Split Bus website/club" |
Posted: Tue Nov 12, 2019 1:44 pm Post subject: Re: Rocker installation height - help with alignment |
Eric&Barb wrote: |
phastbus wrote: |
Eric&Barb wrote: |
Meaning 1 foot scale laid over the top of the floor skin ribs, ends up lower than the top of the latch plate surface. |
Gotcha, Thank you. |
Posted: Tue Nov 12, 2019 1:46 pm Post subject: Re: Rocker installation height - help with alignment |
DubStyle wrote: |
Are your doors still mounted? Why not vise grip it in place, close the doors and set it where you have a good gap? In the end you want a good latching point for the doors. |
They are not currently mounted, and I'm replacing the C-pillar + wheel well - that said, the C-pillar and well is tacked in so I could hang the door to double check the rocker placement. I should do that anyways, thank you for reminding me. |
crofty Judas of the North
Joined: August 09, 2000 Posts: 19702 Location: Land of Whine and Phonies
Posted: Tue Nov 12, 2019 2:01 pm Post subject: Re: Rocker installation height - help with alignment |
DubStyle wrote: |
This. _________________ Your Vanagon sucks, Stop waving at me.
HamburgerBrad wrote: |
I slept on crofty's tent once. I passed out drunk from two bottles of Everett's brother's wine. |
